06-28-2020, 12:45 PM
#76
were you able to access the document
Originally Posted by Coyotegray
I'm getting the following message...
Getting same error -let me know if you were able to see it and or download it
06-28-2020, 12:51 PM
#77
Originally Posted by Whizz
Even if I can't access the manual, thanks OP for all the hard work it's appreciated.
So I have the PDF sitting on my desk top but I can't open it as all my PDF readers tell me it's not in the correct format. Any clues fellas?
File size is 416.4Mb
Using iMac running 10.15.1
Trying to open in native Apple Books
Thanks in advance
Were you able to unzip it using 7Zip? Password is in the post #1
06-28-2020, 12:57 PM
#78
Okay - got it to work
if other have problems - recommend opening a new google window and starting over from beginning. This worked for mee.
Thanks for all the work in getting this done!!!!!!!!!!!!!!!!!
06-28-2020, 05:21 PM
#79
Thanks for the post! Downloaded but can't get the PW accepted? Has it changed? I tried posting the full "x*x*x*_Do_NOT_Post_This_Link!!!_7ha6S1I6Cs83" and several variations such as the three x* only.
Thanks again!!!
06-28-2020, 06:33 PM
#80
Thanks again!!!
I just copied and pasted it and it worked for me but i had to use 7-zip
07-06-2020, 01:33 AM
#81
Hi, I cant seem to be able to get the link to work. When I click on Download it opens a page for 7ZIP but only to download the program. My computer already has 7Zip but it does not go on form that point.
Any tips please.
thanks
07-06-2020, 10:43 PM
#82
Any tips please.
thanks
Don't try to "download" the file with any programs. When you do that, Google tries to OPEN the file by first downloading the file to a temporary directory, then uses the selected program (7-Zip in this case) to directly open that file.
Instead, don't use any program to "download" this file from your browser. Simply download it to your computer locally, then left click on the downloaded file, scroll over "7-Zip" then select either "Extract files..." or "Extract Here". Then, you will be prompted for the password. Enter:
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
07-07-2020, 01:56 AM
#83
Hi,
Thank you, I was able to download today.
Lots of reading material.
Thanks.
08-14-2020, 11:24 PM
#84
Thank you!!!t
This is great OP. Thank you so much! It's garbled when I open with BlueBeam, but I'm able to open it with Microsoft Edge and it looks fine. I assume it's a font issue, but I have no idea how to fix that. Beggars can't be choosers . Anyway, just wanted to thank you for your effort in putting this together for everyone here!
08-15-2020, 10:22 AM
#85
Real Name: Mark
Real Name: Mark
It's a pdf. Did you try Adobe Reader? It opens great in Adobe Acrobat.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
08-15-2020, 10:53 AM
#86
No. I know it's a pdf, but haven't tried Adobe. Edge opens it just fine interestingly enough. It's just that I use BlueBeam for all my pdf stuff, so was hoping it would work. Either way, it works with Edge, so nbd. Thanks though
08-19-2020, 04:24 AM
#87
I can only see the attached link image, and it is not working.
it says "Sorry, unable to open the file at this time.
Please check the address and try again"
no clickable URL
thanks
08-19-2020, 06:43 PM
#88
When you type in the address and go to it, what does the title say?
If you look through the other comments, I put in instructions on how to check, step-by-step how to tell what the problem is. If there are a lot of people downloading this at once, then it can give you an error like that.
I hope this helps.
08-20-2020, 07:13 PM
#89
I've been lurking for a while, but I joined now just so I could say THANK YOU!!
08-21-2020, 06:07 AM
#90
I hope this helps.
I appreciate your reply but every time I type the google drive address and hit enter, it says "Sorry, unable to open the file at this time.
Please check the address and try again. "
I tried different browsers.
I'll keep trying.
