Old 05-11-2020, 06:26 PM #1
christurnerrr's Avatar
christurnerrr christurnerrr is offline
Real Name: Chris
christurnerrr is on a distinguished road
Real Name: Chris
Question HELP - Brake light issues
Hey guys - sorry if this has been covered somewhere, but I searched for a while and couldn't find anything that matched the issue I'm having.
Was driving a uhaul behind the wife who was in the T4R the other day and noticed that there were no brake lights. Once we stopped again, I tried to trouble shoot. Top brake light works as normal. Neither tail light brake function works. All other lights in the tail lights work. Red running tail lights also work, so I know the bulbs aren't bad.
What could be causing this issue?? I've had no luck finding anything.
Thanks in advance.
christurnerrr is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 06:58 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Well depending on what year your T4R is, you could have a bulb problem. Bulbs with filaments (vs LEDs) use a different filament for the brake light. So tail / turn filament in the bulb could be good and the brake light filament bad. Granted it's odd that both are not working. A fuse should include the third brake light - but I'd check just the same.
Also, there have been threads involving issues with the tail light assy. They all center around poor connections in the crimps of wires in the socket. Apparently a bad design. Once again odd that both are bad. Time to get the meter out and start checking. Or if you're under warranty - take it in. Safety issue.
Old 05-11-2020, 07:49 PM #3
Real Name: Chris
Real Name: Chris
Angry
This feels unlikely, but worth mentioning I suppose.
I recently tripped ABS/Trac lights when installing new UCAs and had to replace my ABS/wheel speed sensor harness on front passenger side. When I hooked up the new one, my lights went away.
Is there any way any of that would cause this issue? It's the only thing I can connect to a braking problem? Super bizarre
Old 05-11-2020, 08:14 PM #4
Real Name: Chris
Real Name: Chris
Quick update: busted out the multimeter. I have 12v power all the way to the socket. Still no brake light. Could this be a strange socket problem?? Or bulb?
I'm baffled
Old 05-11-2020, 08:49 PM #5
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Brake Light not working - SOLVED!
BOTH brake lights not working. Anyone any ideas?
Brake light gremlins
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 09:26 PM #6
flyrv9's Avatar
flyrv9's Avatar
Use your meter remove and check the bulb/s. On the ohms scale it should be close to a direct short. And, check that the bulbs are seated properly in the socket/s.
Old 08-31-2020, 06:28 PM #7
Perfection's Avatar
Perfection Perfection is offline
Perfection is on a distinguished road
Perfection's Avatar
Howdy folks. Reviving this thread with same problem, new twist.
2012 Trail Edition. So my driver's side brake light won't light up, center and right work fine. Both filaments are fine in the bulb, and the socket isn't the problem.
The problem is the blue wire feeding into the grey wiring harness that plugs into the taillight housing. I can wiggle it, and at times the brake light comes on, but I cannot get it fixed/working consistently. Can I purchase this specific harness from Toyota or elsewhere? Is there a part number or way to find it? Or do I have to pay the stealership to fix?
Thanks in advance!
CURRENT
'12 TE Black | KDSS | Nav | Interior LEDs | WeatherTech Floormats | Husky Weatherbeater Cargo Mat | Focal IS 165s | Audio Control LCQ-1 | JL Audio XD400/4 | Kicker HS8 Hideaway | Sound Deadener Showdown Deadening | Philips H9s
SOLD
'98 SR5 Auto | 265/75/16 Goodyear Duratracs | B&M 70268 Cooler | Deckplate mod w/K&N | 190k |
Perfection is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 09:44 PM #8
flyrv9's Avatar
flyrv9's Avatar
Previous threads have indicated the wire crimp of the socket contacts to be the problem. Can you determine where the wire is bad? If so, splicing in a new section should fix it.
Old 09-01-2020, 08:20 AM #9
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Thanks in advance!
Glad to see another 2012 TE! I haven't had that problem but i know what you are talking about. I have worked on wiring harnesses before and I would bet that you can fix it with some patience and research on how to undo the harness without breaking it. I say go for it yourself. If you fail and don't have time to keep trying, then I would bite the bullet and go to the dealer, assuming it's one that you trust.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 08:45 AM #10
Perfection's Avatar
Perfection's Avatar
That's awesome, mine is also black. We call her Black Betty. 190k and rolling.
I was able to find a part number on the harness, really tiny writing, it's 6-pin 90980-12349. The blue wire doesn't appear to be damaged and that it's just a loose connection in the harness. Tried pushing it in and adding some dielectric grease. Now it won't work period. I guess I'll try buying the harness and replacing it.
CURRENT
SOLD
Old 09-03-2020, 02:03 PM #11
Nick B Nick B is offline
Nick B is on a distinguished road
Any updates ? I have the same problem with my 2010 TE .
Being a safety issue I’m surprised there isn’t a recall or at least a technical bulletin out on this .
Nick B is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 03:15 PM #12
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Just a PSA:
People seem to have the wrong idea about “dielectric” grease. It is not conductive. It’s a silicone-based grease that has properties that can withstand high temperature, and is an insulator. It’s a lubricant that won’t damage plastic or rubber parts like petroleum jelly will. When you fill connector pins with it, like in your trailer brake light connector, and re-install the mating connector, the metal pins are tight and they squeeze and displace the grease at the metal interfaces. And a little bit of metal is also displaced. The electrical connection is made and is surrounded by a protective layer that keeps out moisture and air, thus no corrosion.
What you did was the wrong application. It’s really hard to clean the grease out. You will have to replace the wire and connector pin, maybe the whole connector would be easier.
brake , light , lights , tail , work
2010 Brake/tail light issues keep blowing fuse mbshaw88 5th gen T4Rs 14 05-31-2023 12:42 PM
Help needed with brake issues (multiple issues) Terminator03 4th Gen T4Rs 11 10-17-2018 10:26 PM
Is the rear Brake light above the lift gate the same as the brake light on the spoile bassmacka 4th Gen T4Rs 2 10-13-2017 10:20 PM
Brake light issues GrampsT4R 3rd gen T4Rs 2 11-10-2014 06:02 PM
Brake Light Issues sagedd13 Maintenance/Detailing 1 10-04-2013 03:29 PM
