Old 05-12-2020, 12:57 PM #1
askdrtodd askdrtodd is offline
askdrtodd is on a distinguished road
Door Panel question- what's this thing for?
The yellow foam and textured black plastic bit, it extends into the door, curious what the function of it is? I'm hoping to use sheet metal and dynamat to seal up the door as much as possible when installing the door speakers, but this thing juts into the door cavity (where the clear plastic pocket is), and if it isn't critical I'd love to get rid of it...
askdrtodd is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 01:50 PM #2
KingPrat's Avatar
KingPrat KingPrat is offline
KingPrat will become famous soon enough
KingPrat's Avatar
I'm completely guessing here, but it looks like it provides a bit of stability under the armrest. Thats a fairly big expanse of plastic and it'd get dented in easily.
Either that, or sound deadening.
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
KingPrat is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 02:11 PM #3
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Definitely looks like it lines up with the arm rest, so probably reinforcing it.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 04:38 PM #4
Hm... I'd love to be able to seal the door up and to do so I'd have to cut that thing down some...
Old 05-12-2020, 05:05 PM #5
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
Hmm, I've had my door panels off many times and I do not recall seeing that part. for sure it didn't cause any issue with adding the sound deadening material.
below is a picture of one of my front doors after first layer inside and out.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 08:24 PM #6
Roamer's Avatar
Roamer Roamer is offline
Roamer is on a distinguished road
Roamer's Avatar
Agree. Believe it is reinforcing the armrest.
Roamer is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 08:31 PM #7
Right but you didn't close up the openings (behind the plastic sheeting), I'm trying to seal those up, you get way better sound/response out of the woofers if you do (assuming they're running IB in the doors).
Old 05-12-2020, 10:21 PM #8
Deimos Deimos is offline
Deimos will become famous soon enough
I recently sound deadened all of my interior and didnt have to throw that piece out. I did however have to adjust my material to accommodate it since I couldn't put my panel back on without doing so.
Deimos is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 07:47 AM #9
I didn't close it up because if you do you eliminate all good access into the door. i'm willing to sacrifice the small amount of difference from not doing it. I'm bi-amping my focal front separates so there is no lack of high quality music. I'm not looking for strong base response from front speakers. do I have some yes (I think front woofers stop around 60 Hz) and it's more than satisfactory and leaps and bounds better than stock.
Old 05-13-2020, 02:38 PM #10
Agreed anything is better than stock and Focal makes great drivers, but it can be accomplished without losing access to the door, you just have to do it thoughtfully (make it easy to disassemble the panels by removing sheet metal screws and weatherstripping later). That said, I completely disagree that the difference isn't considerable sealing up the door as much as possible in terms of the response of the midbass driver. Mine are crossed up at 80hz anyway, but still I've never had a vehicle where it didn't drastically improve the woofer response when sealing the door openings up as much as possible
door , installing , plastic , pocket , thing
SR5 flare rear door clippie thing JZiggy Want to Buy/Trade 5 02-10-2017 02:03 PM
Interior Door Panel Question Vitaminc914 Classic T4Rs 3 12-26-2016 04:10 AM
Rear door panel removal with door stuck closed powrguy 3rd gen T4Rs 2 12-10-2014 05:41 PM
Door panel Removal... where is the screw behind the door? dpr422 5th gen T4Rs 16 04-17-2013 05:16 PM
03 4runner door panel question cparise 4th Gen T4Rs 0 08-05-2012 07:49 PM
