Old 05-10-2021, 07:41 PM #1
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
Low Frequency Pulsing Noise @ 40 MPH
Recently my 4runner has been making a low frequency pulsing noise peaking at 40 mph. It is very pronounced and clocks at 80 decibels , 20 above normal ambient driving noise. At first I thought it was the dreaded needle bearing issue but this noise does not go away when in 4H. In fact, it continues in all gears, and in neutral as well. It starts at about 25 mph peaks at 40, and fades away at 55. I also thought maybe it was the tires, Ridge Grapplers with 32K on them but I replaced them with Toyo AT3's and the noise continues. There is no associated vibration or anything else, just the loud, pulsing noise. Any suggestions?
zonzin is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 07:46 PM #2
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Are your windows, including the rear, fully closed?
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 08:12 PM #3
zonzin's Avatar
zonzin's Avatar
Yes they are.
Old 05-11-2021, 04:19 AM #4
Bry n Bry n is offline
Bry n will become famous soon enough
Have you ever been abducted by aliens? I’m just trying to think outside the box here
Bry n is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 07:38 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Drive shaft spiders lubed? how many miles on the runner? Changed the oil in the diffs? Transfer case? Check your wheel bearings. Alignment? I would think tires, but you say you swapped them.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 11:08 AM #6
zonzin's Avatar
zonzin's Avatar
It has 90,000 on it, mobile one 75/90 front and rear diffs, changed every 20,000 . Drive shafts lubed every 5,000 transfer case changed every 20,000 with royal purple. Alignment done dead on.
Maybe it is the needle bearings and mine just presents it a little different than everybody else's?
Ironically I have a set of East Coast gear front rear diffs on the way (4.56). Maybe that'll take care of the issue.
Old 05-11-2021, 11:51 AM #7
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
When my needle bearings were noisy, the symptom was exactly as yours except that it did go away win 4hi. But, the speed, the type of sound -- all that was identical. Of course, ECGS bushing fixed it for good.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 01:01 PM #8
zonzin's Avatar
zonzin's Avatar
Yeah because it does not go away in 4hi on mine I'm looking into wheel bearing failure. Researching now.
Old 06-03-2021, 01:11 PM #9
Jivewalker's Avatar
Jivewalker's Avatar
Jack your truck up, spin wheel, place hand on spring. If you feel vibration in spring there's a good chance wheel bearing is bad. this isn't a tell all, it could still be bad even if you don't feel vibrations.
I am fragile.
Not like a flower.
But like a bomb.
continues , frequency , mph , noise , thought
Pulsing noise Cumby 4th Gen T4Rs 5 11-14-2019 06:04 PM
Oil change frequency RainCityShecks 5th gen T4Rs 70 11-14-2019 02:56 PM
Low frequency vibration and new belt slip noise Jakeskate 3rd gen T4Rs 11 12-03-2015 03:40 AM
Low Frequency Vibration During Acceleration BulletBarry 3rd gen T4Rs 23 11-27-2015 09:18 PM
