05-12-2020, 10:20 PM
Real Name: Chris
Real Name: Chris
TRD Pro - sway bar rubbing on radiator support bar after lift
Guys,
This has been driving me nuts for a while. I've tried spacing out the radiator support bars, the skid plate, etc., but it still rubs. I'm lifted about 2.5 inches on kings.
Can I just remove the radiator support bars all together?
Thanks,
Chris
2017 Cement Grey TRD Pro
C4 Fab sliders
Prinsu 7/8 roof rack
King Shocks with adjusters
SCS 17x9 f5 with 285 Nitto Ridge Grapplers
05-12-2020, 11:04 PM
Originally Posted by chrissurfr
Guys,
Thanks,
Chris
I’m lifted ~ 2.75”. How does mine compare yours ?
05-12-2020, 11:23 PM
Real Name: Chris
Real Name: Chris
It’s driver side that rubs not passenger
C4 Fab sliders
05-12-2020, 11:42 PM
Have other had this issue? I'm getting ready to put my 2.5 in lift from radflo on
05-12-2020, 11:54 PM
Here’s my drivers side. Plenty of room.
05-13-2020, 12:03 AM
Guys,
Thanks,
Chris
Look at my build thread I solved this pretty easily. These are not radiator supports they are structural supports for the front suspension. So I wouldn’t remove them.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
05-13-2020, 10:14 AM
Real Name: Chris
Real Name: Chris
do you have any spacers on there?
C4 Fab sliders
05-13-2020, 11:53 AM
Spacers where ?
05-20-2020, 10:56 AM
I just removed the support brackets.
2017 Toyota 4runner Off Road Premium
17x9-38 Stealth BR6 - 315/70/17 Nitto Ridge Grapplers - Kings 2.5 Non Adjustable - Baja 30inch Onx6 Light Bar Speed Racer - 4x Baja LP6 - Baja Squadron Fogs - Baja S2 Fogs - Kustom54 AB6 Headlights - Gobi Stealth Rack - Lil B's Fabrication Front Bumper
05-20-2020, 03:29 PM
I have Kings as well. This is a common problem even with the supplied spacers installed. I notched the drivers side brace on my rig. Mark the area you need to remove then take a rotary file and blend out the area. It does not require much. Repaint it and you are done. These things are pretty solid so don't worry about notching it. You are not going to hurt anything.
05-20-2020, 03:43 PM
Guys,
Thanks,
Chris
Do you have pictures of your setup? Kings, Fox and possibly Radflo have spacers to relocate the Sway Bar forward so it doesn't come in contact with the coils. I ended up removing the oem support bracket and bought an ARB kit that has a support bracket that will clear the sway bar with spacers.
Here is the thread from
@ rayofsi
that provided the information, thanks to him I was able to fix my issue:
Arb sway bar rub fix!!! Bp-51 fit kit
It's not TRD Pro specific, mine is an SR5 and have the same issue if going with Fox or Kings.
|2015 Magnetic Grey SR5 Premium|
|Bilstein 6112 Front, 5100 rear Icon 2 inch Springs|
|FN Overlander Wheels| |Duratrac RT 285/75R17||RCI sliders|
|Proline Front Bumper| |Rigid Fog lights|
05-21-2020, 08:18 PM
Never knew there was a sway bar rub issue with aftermarket coilovers..
What's even more amazing is for once the KDSS trucks are easier to mod than the non-KDSS!
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
