05-14-2020, 12:45 PM
Recovery Points for 5th Gen with KDSS?
The majority of recovery point add-ons I've seen (ARB, for example) do NOT work on KDSS enabled 4Runners. Has anyone come across bolt on recovery point options that do?
05-14-2020, 12:51 PM
Real Name: BobH
Real Name: BobH
Use the big front rings already there. For the rear, use the hitch.
The photo is a 1984 T4 helping me out of a snow pile with the front ring.
05-14-2020, 01:05 PM
Yep. Use the ones it comes with. They work perfectly fine.
05-14-2020, 01:46 PM
Real Name: Jonathan
Real Name: Jonathan
^^ Haha. Yep. Don't fall for any BS you read on here or elsewhere about them being tie down loops. They work fine for recovery. You won't break them unless you're doing something really wrong or stupid or probably both, and even then you probably won't break them.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
05-14-2020, 01:48 PM
wrap the chain around the KDSS piston and sling shot yourself outta whatever mud hole youre stuck in ;)
05-14-2020, 04:20 PM
Agreed^ You could also use a bridle with it.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-14-2020, 05:45 PM
Get an LFD hybrid bumper and install it.
We've included solid recovery points, welded through the bumper and in-line with the frame.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
05-14-2020, 09:12 PM
Yeah but you’re not overland af unless you have the red arb ones.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
05-15-2020, 02:37 AM
i personally just picked up the treaty oak offroad ones. spoke to kyle there and he confirmed with me that it does work with KDSS.
i was always under the impression (through research here) that the hoops were indeed just tie down points, which is what lead me to buy the recovery points. i guess it's not the general consensus here anymore?
ig // @ja.emz '17 trd off road premium
05-15-2020, 03:28 AM
If I recall correctly it was just misinformation in a manual somewhere.
I've recovered and been recovered using the stock loops maybe 10-12 times... some with more force than I'd prefer and they haven't even budged.
@offRoadxp | 2019 4Runner TRDO ⁌ RSG Rock Sliders ⁌ RCI Skid Plates ⁌ ICON Stage 2 Extended Travel w/ SPC UCAs ⁌ ICON Rebound Wheels ⁌ 285/75/17 Yokohama Geolandar G003s ⁌ Prinsu Full Roof Rack ⁌ FSR Evolution RTT ⁌ SSO Offroad Bumper w/ Smittybilt 12k Winch
05-15-2020, 03:49 AM
Youll never get a general consensus on this one haha. But it has worked well on many occasions for several folks who wheel hard. Up to you really to decide what works best for you!
05-15-2020, 04:31 AM
Yes, the stock "tie-down" points will work perfectly fine during a recovery that is anything approaching normal. However, if you're buried up to your mirrors in mud that is pretending to be quick-set concrete, you might need to upgrade to something else... like how to pick a better line between, around and over obstacles.
"Sometimes I sit and think. Sometimes I just sit."
05-15-2020, 12:28 PM
That.
05-15-2020, 01:32 PM
Real Name: Jonathan
Real Name: Jonathan
If they were tie down points only Toyota way over engineered them. Tie down points for transport look like this.
