05-14-2020, 05:33 PM
Engine Stops After Battery Disconnect
I have a 2020 ORP and, like everyone else, am busy installing lights, radios, etc. The first thing I do every time I start tearing into things is disconnect the negative battery cable. I've had the dash apart several times, removed the front seats, etc., so disconnecting power is always the first step.
What I've noticed is, every time I disconnect the battery - even if that's all I do - the engine stops after about 5 seconds after I put it all back together and fire it up. I can then immediately restart and it continues to run normally. Again, this happens even if I don't disconnect or work on any other systems. Simply disconnecting the battery causes it to happen.
Anyone else seeing this? Any idea what causes it? Should I be worried?
Thanks for your help
2020 ORP; Toytec Lift, SCS Steath 6 Wheels, K02 285R70/17, Borla Exhaust, Console Safe, Rago Modular Panels, My Medic Trauma & First Aid, H3R Fire Extinguishers, Front Runner 3/4 Rack w/dual antenna mounts, Rago 2nd Battery Box w/ARB breather (rear diff & locker) and Rago Compressor/SwitchPros Mount, Redarc BCDC1220, Bluesea LVD, SwitchPros SP-9100, Yaesu FTM-400XDR w/Comet SBB-5 Antenna, Expedition Essentials Dash Kit w/various Ram mounts
05-14-2020, 06:06 PM
Real Name: Woody
Real Name: Woody
I/ve been disconnecting my battery four 4 years now and was assuming it was normal since mine does it every time. Probably got something to do with the ECU resetting.
05-14-2020, 06:52 PM
Yeah, it has done it every-time also. Normal?
2018 SR5 premium -TRD Wheels -Bilstein 5100's-TRD CAI-Borla touring exhaust-LED low's and Fogs
05-14-2020, 06:56 PM
it does it every time you disconnect the battery. First startup dies.
totally normal.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
05-14-2020, 10:12 PM
That’s normal on the 4 runner on the first start it dies but will start up problem on the 2nd try
05-15-2020, 07:38 AM
I noticed the same when I installed my intake. It raised an eyebrow but nothing more, assuming the ECU had a case of "momentary stupid". Good to hear it's normal.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
05-15-2020, 07:45 AM
Normal. Mine does it as well.
05-15-2020, 11:23 AM
Normal. My 2010 Tacoma did this as well.
05-15-2020, 01:31 PM
It's a Toyota thing. My wife's RAV4 did it when I changed the battery and my Corolla did it too when I had that.
2012 Shoreline Blue TE
05-15-2020, 05:13 PM
Yup. That's expected behavoir. I had it happen on my 2011 and saw in noted in my 2020 owners manual.
I will see if I can find it.
05-15-2020, 06:23 PM
2019 Owner's Manual.>
■When recharging or replacing the battery
●The engine may not start on the first attempt after the battery has been recharged or replaced.
but will start normally after the second attempt. This is not a malfunction.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
05-16-2020, 02:15 AM
Found it. Page 515.
https://www.toyota.com/t3Portal/docu...html?locale=en
●The engine may not start on the first attempt after the battery has recharged
05-16-2020, 09:02 AM
Thanks
Thanks to all for clearing that up. Special thanks to itr1275 for the link to the owner's manual. Got that and a PDF copy tucked away for future reference.
Barry
11-07-2020, 11:22 PM
Thanks so much for this thread. Just had this happen for the first time on my 2020 ORP after BMC. All is good again!
2023 TRD OR, Lunar Rock
11-10-2020, 02:30 AM
Pretty much all 5th Gens do this.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
