Old 05-15-2020, 11:09 AM #1
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
2020 TRD Pro - Remote Connect Challenges?
Hey folks, so I picked up my 2020 TRD Pro back in November and had zero luck initially with the Toyota Remote Connect app that was out at that point (couldn't even get the software to recognize my VIN).
I gave up for a bit figuring I'd give it a shot again coming into the summer when remote starting would be more desirable (since I honestly had little need for it to be enabled).
Anyway, it appears Toyota updated the app software and I was able to get it to register and recognize my vehicle. My new problem is that when I go into the Apps option on my 4Runner, all 3 of them including the Remote Connect Authorization (or whatever it is called) is grayed out.
I did some searching around on the net and found some things saying to make sure a phone was plugged in, try disabling different projection options, and what not. Played around for about 10 minutes with different settings this morning and nothing I did would get those 3 apps to allow me to select them.
I'm thinking I'm missing something stupid and did look in the owners manual for the Infotainment system, but that was quite limited in information also unfortunately.
Anyone with a Pro, Limited or Nightshade have this figured out or know what I'm doing wrong?
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 12:04 PM #2
Yep, trials are all good to go at this point. I'll see if I can do an Infotainment system update and also turn the car on and lock everything down (I thought I had my doors locked, but may not have to be honest). Will report back later if I have any luck (wife has the car out right now).
Old 05-16-2020, 10:30 AM #3
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
Are you sure it came with remote connect? Should be on the window sticker.
It also should remote start via the OEM keyfob if you have it. Press lock 3 times, but hold lock on the third press. Lock, lock, hold lock.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 12:15 PM #4
steelevo steelevo is offline
steelevo is on a distinguished road
All 2020 Pro’s come with Remote Connect and remote start. The key fob trick may not work, if the truck is not programmed from the dealer properly.
When I first picked up my 2020 Pro, we couldn’t get the remote start to work with the key fob or the remote connect to work. The connect light would flash red and green, alternating, then the light would go off. After the road trip home from the purchasing dealer, I dropped it off to my local Toyota dealer. They tried everything to get the car to connect to the Remote Connect satellite/ servers. Day one was a no go, so I had to bring it back another day. On the second visit, they were able to get Toyota on the phone with the master tech. They found out that some part of the vehicles Remote Connect system was still set up to the port/ in transit setting. The original dealer didn’t change this setting to dealer/ delivered, during the PDI. They changed it to The dealer/ delivered setting, and the car was able to connect to the servers within about 2 hours. It had a voice prompt that came on over the cars speakers and the connect light went to solid green.
Sorry for the long post, but I hope this helps someone.
steelevo is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 02:17 AM #5
I have started it remotely with the key fob, so I know it's capable of it. Have not had a chance to play with the system more yet though (busy weekend).
Will try to find a bit of time this week to try some of the suggestions...
Old 11-08-2020, 01:27 PM #6
NorthernKy4runner NorthernKy4runner is offline
NorthernKy4runner is on a distinguished road
Just came across this post as I too am unable to get past the “grayed out” options on my 2020 TRD Pro. Did u ever find a solution.
NorthernKy4runner is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 02:28 AM #7
I actually sat on my butt for a few months early during the pandemic due to not driving the car much, but did manage to do all the software updates (including getting the new Android application) and everything is working great now.
Not sure what the problem was to be honest; it seems like the updated phone application works a lot better than the version that was available the end of 2019 when I got the vehicle.
connect , limited , pro , remote , trd
2020 Remote start adrtoy 5th gen T4Rs 130 04-15-2021 01:26 PM
2020 4Runner remote start? PoobRunner 6th gen T4Rs 8 03-11-2021 02:51 AM
2020 4Runner remote start? PoobRunner 5th gen T4Rs 1 02-17-2020 05:36 PM
2020 Plug and Play remote Starter IS DONE!! gshadow325 5th gen T4Rs 0 01-04-2020 12:38 AM
2020 Plug and Play remote Starter almost here gshadow325 5th gen T4Rs 2 12-30-2019 08:43 AM
