Old 05-15-2020, 11:11 AM #1
rigtimmins rigtimmins is offline
rigtimmins is on a distinguished road
Did most tire manufacturers just stop making C load 275/70 r17?
I think I've decided I'm throwing 5100 on all corners with Dobinson coils front and back. I'll probably keep stock 265/70 r17, but I would at least consider 275/70 r17 if I could find any decent ones in a C load.
I've seen folks posting about having a lot of tires in C load like Cooper At3, BFG Ko2, etc. in C load as recently as 2019, but I can't find them anywhere. Just don't need an E load tire and not lookin to grab Falken Wildpeak in C 275 at 58 lbs a tire.
Did folks just stop making them in that size recently?
rigtimmins is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 11:27 AM #2
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
It's an uncommon size and I don't think it was made in C load by many manufacturers. Falken I believe has it, but it weighs more than some of the similar size E load tires for some reason. Kumho also has it available in their AT51, but that seems like a pretty "mehh" tire from reports out there.
You can get a bit more in C if you go to 255/75R17, which ends up actually a bit taller than a 265/70R17, but generally about .7 inches narrower. This was the stock size on MT equipped Wrangler JKs.
Most people you see mention C are either running 255/75R17 or 285/70R17 from what I can ascertain.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 11:42 AM #3
Ya I definitely get that...Just kinda dig the size, and I saw this article (from 2018, but C load AT3) Cooper Discoverer A/T3 Tires Review on 5th Gen Toyota 4Runner
Prob just gonna grab some 265 KO2 C and call it a day.
Old 05-15-2020, 11:58 AM #4
Got it; I didn't even realize Cooper used to make that tire in a C load at that size. I think they split the AT3 into the LT line and P-metric lines in the last year or so and probably deleted it at that point (since they probably figured the E load would be more than enough for an oddball size that isn't OEM in most cases).
I'm contemplating running something E-load in 275/70R17 since I'd rather minimize my chance of having to trim much (been there, done that on my previous 4Runner with Falkens in 265/70R17 if you can believe it with SCS wheels due to offset) once I pull my Terra Grapplers off.
None of the tires I'm really interested in come in that size though .
Old 05-15-2020, 12:26 PM #5
Ya I could see that. Definitely not a whole lot to choose from! I'd almost rather have the Cooper tire after hearing about all the balancing nightmares from KO2.
Old 05-15-2020, 03:21 PM #6
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
The 255/75r17 size is very popular. You should give that size a look. It’s also available in just about every load range. It’s a little narrower, but 32” tall.
ads2539 is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 05:56 PM #7
Xetabur's Avatar
Xetabur Xetabur is offline
Xetabur will become famous soon enough
Xetabur's Avatar
My Falken Wildpeaks are C load.
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
Xetabur is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 06:22 PM #8
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
And also heavy as ****, which was previously mentioned...
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 07:19 PM #9
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
How do you like the c loads noticeably harsh? I'm running E's at 285 and it's a bit overkill but I wanted to jump to the xtreme and know first hand.
Honestly with E load 285's it's heavy, but I barely notice the weight increase, and what does it honestly matter? These aren't race trucks and runners would make fairly awful ones at that.
To people crying about weight I ask... What does it matter if you barely see a decrease in mpg?
I shredded the stock tires on these jagged desert rocks and blew out two. I now can air way down without a worry. Only complaint about the E load is how harsh the ride is. Will definitely be going to a C load without hesitation.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 05:14 AM #10
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
The KO2’s are not available in a C rating. I have KO2 275's and they only come in a E rating. I did a 1.5/1" spacer lift to level out my Pro. I'm satisfied with the look and result, plus I had to do zero mods for fitment. No rubbing and clearance issues fully articulated and I like running my front mud flaps. BUT, at 57 lbs. and a slightly harsher ride than I would like, I will eventually go to a 285 C rating. I think the 285-70-17 is the best size (looks/off road performance) tire on the 5th gen without sacrificing too much. There is a lot more selection on 285's, and due to selection, if you blow a 285 out, it is easy to find another one no matter where your at. It will also still fit in the spare area underneath. A 285 KO2 116Q C rated tire only weighs 50 lbs. The Falken 275 C rated tire is 58 lbs. The 275, size wise is a great compromise between a 265 and 285, but, due to the small selection I would not do it again.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 10:28 AM #11
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
We really need some C load range tires in 275/70r17.
Please write to the tire manufacturers
osideplayer is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 06:16 PM #12
nacocoug nacocoug is offline
nacocoug is on a distinguished road
What wheels do you have and what is the offset? I am going to do a 1.5" level on the front and put 275/70 Wildpeaks. The wheels are SCS BR6s with a -10 offset. I am really hoping I wont have to trim.
nacocoug is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 06:55 PM #13
Nick B Nick B is offline
Nick B is on a distinguished road
I think Firestone makes some of their AT tires in that .
Nick B is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 07:32 PM #14
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I did 275 KO's first then went to 285 C's............should have just gone 285's to begin with. It "Fits'' the Truck best and is easy to find. They also fit my 9'' Rim correctly where the 275's were too ''Square'' on the sidewall.
83Mule is offline   Reply With QuoteReply With Quote
find , load , r17 , recently , tire
bfg ko2 load c vs load e (discount put on wrong tire) 4by4runr 4th Gen T4Rs 27 06-02-2021 01:13 PM
Tire help - which load rating & tire--- Any input on the Kumho KL61 P vs KL78 E ?? FLynFish Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-13-2013 10:40 AM
Tire making leaking sound? Sloan 3rd gen T4Rs 4 12-07-2008 11:33 AM
