Old 05-17-2020, 05:34 AM #1
tchfall15 tchfall15 is offline
tchfall15 is an unknown quantity at this point
P0705 Code, then clears up
For the past month, my 2014 4runner limited will throw the P0705 code with 4lo blinking, trac off light on, and check engine light on. Is this the neutral safety switch?
How it typically happens, the gear shifter is somewhat stiff going into through the gears, then as I drive the 4lo starts blinking, then a little later the trac off and check engine come on. After that, then the gear shifter is back to normal and the code eventually turns off. Then after awhile, the same thing happens over again.
Is this the neutral safety switch? Or check other things first?
Thanks for your help.
tchfall15 is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 07:33 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a jewel in the rough Bossman is a jewel in the rough Bossman is a jewel in the rough
Bossman's Avatar
First issue with my truck, any ideas what's wrong?
P0705 Error and bad Neutral Sensor Switch
Neutral Safety Switch
NSS/Range Selector Switch - P0705 code
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 04:09 PM #3
Bossman's Avatar
Bossman's Avatar
I recently ran into this very same issue on my 2011 Limited with 169,000 km.
Three dash warning lights activated while driving - the Check Engine light was on; the Slip Indicator was on; and the 4-LO Lowspeed 4WD Indicator was flashing.
Using my OBD II Code Reader, the Error Code P0705 - Transmission Range Sensor Circuit Malfunction (PRNDL Input) came up.
I can't say for certain that I truly noticed that moving the gear shifter was becoming all that difficult over time.
Based on my research, I anticipated that the A/T Gear Position Sensor aka the Neutral Safety Switch (NSS) Assembly had failed.
Toyota Canada Part number for the NSS is 84540-35060.
My independent mechanic confirmed the switch failure, and after waiting several days for the local Toyota dealership to get this part in, the old switch was removed (not easily removed due to the corrosion) and the new switch was installed.
My mechanic showed me the inside of the old switch, and the internal corrosion that was on the internal contacts.
The new switch cost $263.00 CAN.
With the new switch, moving the gear shifter does seem a bit smoother
check , code , engine , p0705 , safety
NSS/Range Selector Switch - P0705 code kenwilliams0803 5th gen T4Rs 12 06-06-2020 09:04 PM
P0705 Error and bad Neutral Sensor Switch hkazmi 5th gen T4Rs 4 06-03-2020 03:39 PM
P0705 code and alternator problems. Is my logic sound? robguitargod1 4th Gen T4Rs 7 10-09-2019 12:08 AM
P0705 engine code PSA 773_T4R 4th Gen T4Rs 1 09-01-2018 03:23 PM
Bumper/Hitch that clears the spare just66horns Classic T4Rs 1 05-02-2006 11:00 PM
