Old 05-18-2020, 07:45 PM #16
BlakeA BlakeA is offline
BlakeA will become famous soon enough
Originally Posted by BlakeA View Post
I did what was suggested in the above second paragraph, with a 500w Jackery lithium. I use a Dometic CFX3 35. I plug it into the 12 volt outlet on the Jackery, and charge the Jackery from the 12 volt 4Runner outlet while driving. I have a Goal Zero 100 watt solar panel to charge the Jackery when camping. I don’t have the slide on cargo tray but do have a DFG Off-road fridge slide mounted on a platform I made. I’ll try to post a picture of it.
BlakeA is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 07:58 PM #17
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by Bumbo View Post
Depending on the fridge power requirements, it could be possible to see issues with the inrush current from compressor startup as the battery voltage decreases.
When the voltage is lower, it requires more current to push the same power, and the OEM wires are pretty small.
Personally I ran some 10 AWG with an Anderson plug which I can use for various items, including the fridge.
Originally Posted by blackened_offroad View Post
you might as well be speaking Portguese. Electrical is not my strong suit.
It's called ohms law and has to do with resistance over the electrical path under load... but you are in luck, I happen to know how to translate Portuguese.
If your battery was a milkshake and your fridge wants to drink it, it needs a wire straw.
The closer to empty the milkshake battery is, the colder the milshake becomes, and the harder it becomes to suckie suckie.
If it's too hard to suckie suckie, your fridge is going to give up.
It will appreciate a bigger straw... because it's much easier to suckie suckie with bigger wire straw.
Old 05-18-2020, 08:22 PM #18
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Lmao this is gold
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 09:55 PM #19
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Now I am hungry, thanks.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 01:46 AM #20
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
gotcha. I haven't tried a fridge, but an electric kettle and a few other things gave up on the suckie suckie.
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 11:58 AM #21
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Mack1611 is offline   Reply With QuoteReply With Quote
area , cargo , rear , thing , yeti
20% off ARB and Dometic Fridges @ REI sn_85 General Discussions 5 11-09-2018 09:25 PM
ARB Fridges Freeze-Out CLOSED Babyjake16 Group Buys 23 03-06-2018 11:05 PM
Bears and ARB fridges alirawk General Discussions 42 02-12-2018 05:00 AM
Engel fridges on sale!! Mgyver1 General Discussions 11 03-14-2017 12:16 AM
Are all non-ARB fridges garbage? Cheers! Off-Roading 13 07-27-2015 05:30 PM
