Old 05-18-2020, 07:28 PM #1
Rogue-Runner's Avatar
Rogue-Runner Rogue-Runner is offline
Rogue-Runner is on a distinguished road
UPDATE (FINISHED!): What step gave you the hardest time when installing new struts/leveling
My first attempt to install new struts and level my rig was an unmitigated failure. My dad (who is very handy) and I got stuck when it came time to remove the 3 nuts on top of the strut mount. We couldn't get either of the front 2 loose so we didn't even try doing the one in the back. I got some pb blaster today and a 14mm ratcheting wrench (6 point). We're going to soak every nut in every step for a few days then tackle it again next weekend. Otherwise I'm busting out the Dremel. I'm also replacing the rear shocks + 1.5" rear spacer.
So... what's the next step that's going to prevent me from doing this install? Which parts did all of you find most difficult?
EDIT: Although getting stuck was a pain and a major disappoinment, I'm pretty close with my dad, but I haven't had that much fun with him in years. Looking forward to do it again.
Rogue-Runner is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 07:31 PM #2
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
Soak everything in PB. Everything.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 07:34 PM #3
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Cheater bar/ wrench didn't help?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 07:50 PM #4
I didn't have a cheater bar handy, and we didn't try the 2-wrench trick because it wouldn't work on the back one anyways. Hoping the blaster saves me this weekend.
Old 05-18-2020, 08:00 PM #5
chester4Run chester4Run is offline
chester4Run is on a distinguished road
UCA bolt was my nemesis. Doing it alone was just too much. I couldn’t keep everything aligned below while getting that bolt in place from above. I ended up grabbing some help before I lost my mind a burned the whole place down...
It wasn’t bad overall. Some bendy ratcheting wrenches penetrating oil should help a lot with those top bolts. Take your time and have fun with your dad!
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 08:11 PM #6
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
The garbage spring compressor tool that I got on Amazon was my issue. It had a hard time seating on the coil spring correctly. I ended up taking the struts to a near by shop to install the spacer and top hat as I didn’t have time to order another compressor tool as I needed my rig back on the road.
Get a good quality spring compressor tool.
mcat707 is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 08:13 PM #7
Charlievee's Avatar
Charlievee's Avatar
Could try pulling the strut/spring using the "no spring compressor" method for a bit more room for the top mount nuts.
Old 05-18-2020, 09:15 PM #8
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
No spring compressor method is the way to go.
The hardest part for me was loosing the lower control arms after marking the cam bolts with paint pen, then getting them aligned up again.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 01:43 AM #9
Oh ya I decided that I didn't want to mess with that. Luckily I'm installing new struts so I was able to take them to my mechanic and ask him to install the preload portion of the front spacers.
Old 05-19-2020, 01:55 AM #10
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Kdss if you have it. I strapped everything in place help loads. Not even an issue for me now tbh.
No spring compressor method is simple and easy. Tbh most of it’s pretty easy.
My harbor freight jack stands suck. Claws just don’t safely sit on the frame rails. Spent a lot of time just trying to get the truck to sit on them right. Resorted to two on one side and a wheel under the rails just incase. Think they got recalled so I should prob get on that and buy something better.
Watch some vids. Read some threads. Come up with a plan and take your time.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 10:44 AM #11
dschupp dschupp is offline
dschupp is on a distinguished road
I was able to get those top nuts by tapping the wrench with a hammer a few times. I used the loaner spring compressors from auto zone; not easy but was able to get it done. Having a breaker bar handy was helpful especially when it came time to crank down those springs
2018 SR5 4WD
Bilstein 6112's w/ JBA high caster UCA's in front, 5160's w/ Icon 2" springs in the rear, G2 1.25" wheel spacers all around, Pro Comp 285/70R17 A/T's, RCI 5 degree sliders, Rago MOLLE rear window panels, Sprint Booster, Gibson dual side exit exhaust..... to be continued
dschupp is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 12:17 PM #12
Sounds rough. When you align/torque the cam bolts, do you do so after the tires are back on the ground? I read in one jeep forum that you don't align/torque while still in the air, but I've read dozens of write-ups and no one else mentioned that, including instructions from manufacturer websites.
Old 05-19-2020, 12:23 PM #13
Charlievee's Avatar
Charlievee's Avatar
Just have to line up your marks, front and back. It will still need a good alignment, but this gets you close. Good time to pull the cam bolts and anti seize everything.
Old 05-19-2020, 01:59 PM #14
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
PB Blaster for sure but I would also use a mallet on the wrench while its attached to the bolt. Its worked for me in the past. You should have enough room to do that.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 02:23 PM #15
sephv1 sephv1 is offline
sephv1 is on a distinguished road
I didn't have much trouble on the fronts...but the back was a PITA when it came to get thing the trac bar bolt back on. Had to use some ratcheting straps to get the axle to shift over like 3/8" inch so i could get the bolt back in.
sephv1 is offline   Reply With QuoteReply With Quote
install , rear , step , time , weekend
Are there any negatives to installing a front leveling kit?????? pennstater 5th gen T4Rs 14 12-27-2012 10:05 AM
Time to replace shocks/struts. Good time to lift? atalarico 3rd gen T4Rs 0 06-24-2011 09:50 PM
Step by Step Instructions for Installing an Amp? MSBX4RUNNER Engines / Suspension / Wheels / Tires / Audio / Accessories 14 12-30-2010 04:41 PM
Installing Leveling Kit, replace shocks too? clemsonxplorer 4th Gen T4Rs 7 05-18-2010 09:51 PM
need help installing leveling kit in OC ca. DanDLT General Discussions 0 08-26-2009 02:50 PM
