Old 05-19-2020, 03:24 PM #16
rocketnuts's Avatar
rocketnuts rocketnuts is offline
rocketnuts is on a distinguished road
rocketnuts's Avatar
Originally Posted by chester4Run View Post
UCA bolt was my nemesis. Doing it alone was just too much. I couldn’t keep everything aligned below while getting that bolt in place from above.
Same issue. It seems straightforward enough, but you really need 2 people in 2 different places. Had my brother in law stop by and work the bolt from under the hood while I was underneath keeping everything aligned. Wiggling the UCA while the bolt was being pushed through seemed to make it go easier.
1990 Volvo 240 wagon
2019 TRD Off Road - 6112/5160s wT13. JBA UCAs. RSG sliders. SSO slimline
rocketnuts is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 09:58 PM #17
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
I didn’t loosen the cam bolts so it was pretty tough getting the new shock and longer spring in place by myself could use an extra set of hands.
Arnezie is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:37 AM #18
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
I can rip apart each side of my truck including removing the coilover and CV in less than 20 a side. You learn what order or what as you go over time.
Originally Posted by sephv1 View Post
I didn't have much trouble on the fronts...but the back was a PITA when it came to get thing the trac bar bolt back on. Had to use some ratcheting straps to get the axle to shift over like 3/8" inch so i could get the bolt back in.
You don’t need to actually remove it. Just loosen the bolt enough to have free play.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 02:02 AM #19
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Back is the easiest part dude!
Maybe your truck wasn’t level. It was minimal effort getting that bolt back in both times I’ve done the rear. If it doesn’t line up you shove your jack under the pumpkin and pump the whole axle up till it lines up.
I can do the whole rear suspension with kdss in about a half hour + or -.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 03:09 AM #20
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
Originally Posted by Rogue-Runner View Post
I got stuck when it came time to remove the 3 nuts on top of the strut mount. We couldn't get either of the front 2 loose so we didn't even try doing the one in the back.
Like some others, I too used a hammer or mallet to hit the wrench to loosen it when I installed spacer at the time. The PB blaster should make easy work of it now hopefully.
Sounds rough. When you align/torque the cam bolts, do you do so after the tires are back on the ground? I read in one jeep forum that you don't align/torque while still in the air, but I've read dozens of write-ups and no one else mentioned that, including instructions from manufacturer websites.
Yes. Do this and torque your bolts while it's on its own weight. From what I've learned those bushings don't pivot in the LCA but rather they stretch. So torquing them down while fully drooped would stress them while the vehicle is on it's own weight. I'm almost certain I trashed my LCA bushings with my OEM lowers at the time because I torqued them all the time while it was in the air.
Maybe these are just tips. But for me, ripping my ABS sensor wire and not marking where my alignment tabs were before completely removing LCA bolts.
I'm not certain if you'd have to but I would remove the bolt that holds the ABS sensor wire at the upper control arm. Peace of mind so you don't rip it.
And not that you would need to remove the LCA bolts, but do mark them if you loosen them. In short, I set my alignment cams to neutral because I didn't mark them (too excited to remove everything and install my new LCAs) and didn't know how they were oriented. At the end of it, the middle of steering wheel was pointed at about the 10 o'clock position and that in combination with one hard lock turn, destroyed my clock spring inside the steering wheel.
The fix was more expensive than the LCAs I installed. It sucked.
I have an expensive live and learn experience. I don't like it.
Hope the install goes well and do enjoy the time with your Dad.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 10:28 AM #21
toxicity toxicity is offline
toxicity is on a distinguished road
UCA bolt.
Didnt realize the bottom of the bolt was a hex.
Tried to wrench down and turn to tighten =|
2017 Toyota 4runner Off Road Premium
17x9-38 Stealth BR6 - 315/70/17 Nitto Ridge Grapplers - Kings 2.5 Non Adjustable - Baja 30inch Onx6 Light Bar Speed Racer - 4x Baja LP6 - Baja Squadron Fogs - Baja S2 Fogs - Kustom54 AB6 Headlights - Gobi Stealth Rack - Lil B's Fabrication Front Bumper
toxicity is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:24 PM #22
sephv1 sephv1 is offline
sephv1 is on a distinguished road
Believe, I tried jacking the axle up umpteen different ways, it wouldn't line up.
I spent more time getting the bolt back in than I did on the rest of the rear. Other than that, it was a piece of cake.
sephv1 is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:25 PM #23
I was just following a video and he had removed one of the bolts to let everything drop and move around easier. not sure why mine had so much trouble lining back up.
Old 05-24-2020, 07:17 PM #24
Rogue-Runner's Avatar
Rogue-Runner Rogue-Runner is offline
Rogue-Runner is on a distinguished road
UPDATE (HELP NEEDED!): We got the three nuts off and got the driver's side strut in no problem. We moved to the passenger side but the strut seems off centered (see pic). Rotating it 180 degrees doesn't help. I think the shop that installed the preload spacer did it incorrectly. I found some threads of people having the same problem and they put a screwdriver or something longer through the eyelet and pulled in order to force it to rotate. I've tried this but it feels like I'm going to damage something. The torsion down at the bottom end is too far removed from the top that needs to rotate. Do I need to take the strut back to the shop to have them realign the strut? I don't see how I can get it to fit without compressing the spring and removing the top nut to rotate it.
If anyone can help I'd really appreciate it! The wife is none too happy about the 4Runner having to stay on jack stands for a week...
Rogue-Runner is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 08:33 PM #25
fbksurferjoe fbksurferjoe is offline
fbksurferjoe is on a distinguished road
Screwdriver or punch and twist it. You will not damage it. It is meant to rotate. Move the a arm down a little bit and twist.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
fbksurferjoe is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 11:24 PM #26
I was finally able to twist it enough to partially fit it into the mount. If I let up, it would twist back out. With it partially in, I was able to hammer it into place and tighten the nut and torque once on the ground. It's got torsion right now, so hopefully it's ok.
My hopefully last issue (apart from grease coming out of the sway bar endlink bushing) is the sway bar endlink nut keeps spinning as I try to tighten it. Wasn't an issue on driver's side. I'm aware of the Allen hex. Holding it in place with an open end wrench still allows the back side to spin. The only thing that helps is using vise grips but you can't get it flush with the grips on there. Open to any tips. Thanks!!
Old 05-24-2020, 11:54 PM #27
Never mind, everyone. With a different set of grips I was able to tighten it. Front end is all done! Moving on to the back this week hopefully before my tires get here on Thursday. I really appreciate everyone's help!
Old 05-26-2020, 09:26 AM #28
Nice job. Hard part is over. The rears required me bending a bit of the metal around the top shock nut for access but otherwise you shouldn't have an issue.
Old 05-28-2020, 03:59 PM #29
UPDATE: TL;DR: It's done, track bars suck, thank you to everyone, and my dad rocks!
I finally drove my rig home around 4 a.m. this morning. The rear took longer than the front, which I wasn't expecting. Part of that was that the suspension kit that I bought included some parts I didn't' need like UCAs and UCA washers, only I didn't know they were UCA washers, so I spent a lot of time trying to figure out where they went.
After everything, the hardest part was reinstalling the track bar! I made the mistake of installing the shocks and the stabilizer links before the track bar (or my mistake may have been removing one of the track bar bolts in the first place). At 1 am I had literally washed my hands and given up because the bar was coming up about a quarter inch short no matter what I did. Before leaving my dad said let's try removing the shocks and see if we can make the geometry work. I thought I was going to have to buy an adjustable track bar or something. But with the shocks out of the way, we were able to get the axle in a position to bolt the bar back on. From there it was relatively smooth sailing, but we're slow so it took another two hours to put everything back together.
Overall, I'm really glad I did it even though some parts were frustrating. If you're debating whether to do it yourself, I say go for it! If I can do it, anyone can. I'm a lawyer and not mechanically inclined at all. I had never so much as changed a tire before last week. My dad is a custodian and is handy but has never worked on cars. That's a huge thanks to this community and everyone willing to share their experiences and help, so thank you!
Also, I've got the coolest dad in the world who was willing to pull 4 late nights in a row to help me do all of this because the only time I had was after 11pm. If anyone has any good father's day gift ideas, let me know cause he totally deserves it!! I'll post pics once new tires I ordered are installed this weekend.
Old 05-28-2020, 06:12 PM #30
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Glad you got it squared away OP. Your pops sounds like mine, hard working blue collar guy that isn’t afraid to get down and dirty and do what it takes to get the job done. My father is a 86 year old military Vet and is retired and is always looking for something to keep him busy and would be happy to help me tear down my suspension if I asked him to. I remember he would wear his $12K Rolex to change the timing belt in his old Lexus.
mcat707 is offline   Reply With QuoteReply With Quote
install , rear , step , time , weekend
Are there any negatives to installing a front leveling kit?????? pennstater 5th gen T4Rs 14 12-27-2012 10:05 AM
Time to replace shocks/struts. Good time to lift? atalarico 3rd gen T4Rs 0 06-24-2011 09:50 PM
Step by Step Instructions for Installing an Amp? MSBX4RUNNER Engines / Suspension / Wheels / Tires / Audio / Accessories 14 12-30-2010 04:41 PM
Installing Leveling Kit, replace shocks too? clemsonxplorer 4th Gen T4Rs 7 05-18-2010 09:51 PM
need help installing leveling kit in OC ca. DanDLT General Discussions 0 08-26-2009 02:50 PM
