05-18-2020, 07:51 PM
Hi Lift Jack
I'm wondering what everyone is using when off roading to change a tire if need be. Right how I just have the jack that comes with the 4runner and not sure if it will work on dirt roads or not. 3 inch lift on vehicle and also not sure if a hi Lift will work with the predator step sides or not.
Any recommendations.
05-18-2020, 07:56 PM
Real Name: Sparky
Real Name: Sparky
I keep a hi lift inside the vehicle and use a rock rail adapter. I also have a off road foot plate thingy for use on soft/uneven surfaces.
The only time so far I've used the hi-lift was in a parking lot, tho.
Old and (c)rusty.
05-18-2020, 08:09 PM
first thing I'd do is practice in my driveway with the factory jack. You'll have to measure to see if it will work with a flat - or let the air out of a tire. A flat steel plate or at least a board will help if you are on soft ground off road; and or make up the difference with your lift.
Also, if you haven't lowered the spare before using the put together rod and handle, then I'd practice that too. It's not something you want to do for the first time on a dark rainy night!
As for the hi-lift jack - the question would be where to place it.
05-18-2020, 08:11 PM
I have used a hilift off road to change a tire and break a bead to replace a valve stem. Works but now i just use one of those bottlejack/jackstand combos. Stock jack with a wood base works fine too. I still have the hilift in case.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-18-2020, 09:36 PM
Originally Posted by JsinLegacy
Ok... With that out of the way. I'm wondering what everyone is using when off roading to change a tire if need be. Right how I just have the jack that comes with the 4runner and not sure if it will work on dirt roads or not. 3 inch lift on vehicle and also not sure if a hi Lift will work with the predator step sides or not.
You will not be able to lift the truck with the hi-lift using those steps. You'll need either a proper set of frame mounted sliders, metal bumpers with jacking points, the wheel lift straps that hi-lift sells or a combination of the three.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
05-18-2020, 11:07 PM
When not on 4x4 trails I carry this around. I keep the Hi-lift in the garage so it doesn't rust. Mine is 48", others recommend a 60". I haven't been in a situation when I needed a 60" but who knows. 60" is pretty damn big and heavy. I also bought this adapter. Obviously won't work if you don't have sliders.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
05-18-2020, 11:30 PM
Like vegas said. Also, unless you pile rocks or something under the bottle jack and deflate the spare you won’t be able to lift your truck. This is sketchy and not ideal. You will also need an air compressor.
Also, if you are lifted on 285s, I hope you have the correct size spare on a matching width and offset wheel.
If you carry the jack inside you will need to secure it well so it doesn’t bounce around and become a projectile. If stored inside and u have to use it then be ok with a dirty interior.
Those wheel straps may help free your truck but won’t help with tire change.
05-19-2020, 02:24 AM
Banned
Real Name: Tobias Fünke
Banned
That’s what wood is for. Plenty of serious off-roaders use the oem toyota bottle jack. I’m lifted on 285’s and I use mine. In fact I don’t even own a hi lift I just have two bottle jacks. Oem and a 5ton hydronic with some wood. I’ll buy a high lift when I can safely mount it. Otherwise it takes up a ton of space.
05-19-2020, 05:03 AM
I don't do enough off road driving to warrant carrying a hi-lift, but I do use mine on the farm occasionally. A bottle jack or scissor jack may fail and cause your truck to fall down, but those jacks themselves won't kill you. A hi-lift has a pretty slim margin of error, so unless its something you have practiced with in difficult situations (soft ground, uneven surfaces) there are better/safer choices.
05-19-2020, 09:09 AM
They are an invaluable tool off road if your truck is properly equipped to leverage one (Rock Sliders/Metal Bumpers). I've use mine a decent amount to troubleshoot mechanical issues on the trail and also to get out of bad stucks. Most are correct that you can usually use an OEM bottle jack and some wood. However those of us with longer travel suspension and large tires can't do that if we need to unweight the suspension.
If you do decide to get one make sure you study how to use one safely and practice use before relying on one offroad. Also, please don't use them on your predator steps. You're, going to just bend them into your rocker panels. Not sure why people have those things they are completely useless and hamper breakover clearance.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
05-19-2020, 10:45 AM
What has been said above about safety and knowing your equipment and how to use it is valuable and important information. Regarding the Hi-Lift I'd reiterate that it's only valuable if you have viable jack points to use it on or the accessories to make it work on your vehicle. The only additional thing I have found that is helpful for a Hi-Lift is a can of spray lubricant as Hi-Lifts rust easily, especially if they live on your rig 100% of the time. (I don't recommend this BTW) As far as using the OEM bottle jack, I'd get it out and extend it all the way to see how it will do for your situation. You'll definitely want some sort of base plate, that will work for both the bottle jack and the Hi-Lift. This doesn't need to be anything fancy. I've found that something with a bit more surface area is helpful for soft conditions. As far as increasing the lift height 2x4's will work or I carry these:
6 Ton 3" Universal Lift Pad – Safe Jack
6 Ton 6" Jack Extension – Safe Jack
As was said above a full sized spare is a good idea although you can limp out on a smaller tire. Also consider carrying a tire repair kit and emergency valve stem replacements.
It can be really challenging to get the spare out from underneath the truck in some off road situations. Repairing the tire on the truck may be a better option sometimes. So then obviously a compressor becomes a necessity as well.
As was said above I'd encourage some dry runs of all this so that in the time of need it's all familiar
05-19-2020, 11:52 AM
The factory jack is perfectly fine for changing tires including 285s. It has plenty of height. I would not use a high lift to change a tire unless I had to. They're not a good jack for that purpose if you have a flat place to use a normal bottle jack.
05-19-2020, 03:55 PM
Thanks everyone for the advice and suggestions. Greatly appreciated. Truly.
05-19-2020, 04:51 PM
it won't, not many options for a hi-lift without sliders and/or bumpers
you can strap and lift a wheel, that can help you get unstuck but obviously doesn't help you change a tire
05-19-2020, 05:10 PM
I have used high lift Jack out in the desert on the border because that's what they gave us. It kicked back once but I didn't get hit, fortunately. Another co-worker got his teeth knocked out. After that I placed a jacket over the Jack handle and kept it tight to my body all the way down and up. It's the distance and force of the kick back that can kill you. Kind of like a shotgun with rifled slug if you don't hold it tight, but that shouldn't kill you. Anyway, I had my wife get me a 60" Hi-Lift for Christmas. Then I found it wouldn't fit safely in my 4Runner. So I need to get a roof rack with Jack mounts. Not necessarily a bad thing. Probably could have made do with 48", but I didn't want to. Come up short. Also, at least on sand, solid plywood 1" thick by 12" square worked well.
