Old 05-19-2020, 02:12 PM #1
orcking orcking is offline
orcking is on a distinguished road
Cold start idle
Hi guys:
when I start in the morning, or when cold start, the idle starts at 1500 to 1600 rpm, drops to around 1100 to 1200, drops down a little to 1000, but it does not reach 800 until the temperature goes to normal operating temp(5-6 mins).
Is this normal? I attached a video of starting when 59F outside.
ColdStartIdle2.wmv - Google Drive
orcking is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 02:45 PM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by orcking View Post
Hi guys:
perfectly normal. You don't have to wait for the idle to drop to start driving just don't slam on it but take it easy the first few miles until it reaches operating temps.
Old 05-19-2020, 03:45 PM #3
rivenbbe rivenbbe is offline
rivenbbe is on a distinguished road
Agreed. My last Tacoma had a similar but more fluctuating idle that drove me crazy so I replaced plugs/wires/coils/pcv but nothing. However, mine had a ROUGH idle when I was at park or at a light to the point of almost stalling out. Turned out to be a major vacuum leak. As long as that’s not happening then you should be straight
rivenbbe is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 03:54 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Are all 5th gens like this?
? Regard high start up idle
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 04:23 PM #5
Shadow.T4Runner Shadow.T4Runner is offline
Shadow.T4Runner is on a distinguished road
The cold start high idle on most newer cars is from the secondary air pump. Typically it pump fresh air into the vehicle's exhaust system to help the cats get to temp faster, which promotes a cleaner burn before the fumes exit the exhaust. My 4Runner has idled like you described above since I bought it new.
2019 MG OR - OEM Pro Grill | Bilstein 6112/5160 W/2" ICON Springs | JBA High Caster UCA | Duro Bumps Front & Rear | ToyTech Diff Drop | ArcLights Icarus Interior LED's Red/White | Lots More To Come!
Shadow.T4Runner is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 04:27 PM #6
Whippersnapper02's Avatar
Start it, let it run for a couple of minutes and then drive off but drive easy until it warms up.
Old 11-08-2022, 08:10 PM #7
JLtoTRD JLtoTRD is offline
JLtoTRD has a little shameless behaviour in the past
Posted on the 4th gen thread but finally found the cold start issue on the 5th gen thread.
Everyone is talking about 1500 and 1600 rpms but mine are 2000 rpms. Literally just bought a 2021 TRD Off Road last night and when I fired it up toady it scared the crap out of me when it shot to 2k rpms.
I thought this has got to be normal and an engine warm up thing but that seemed kind of high to me. Thoughts?
2021 TRD Off Road, 1991 Wrangler on F150 axles, 37s, 5.13 gears.
JLtoTRD is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 05:51 PM #8
Matt831 Matt831 is offline
Matt831 will become famous soon enough
It is normal. Enjoy your truck.
Matt831 is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 09:01 PM #9
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
wait till you start it in temps around -40... itll make a nice crunching grinding noise... real grim like. But hey..thats winter right
Grug556 is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 12:17 PM #10
Paui4m Paui4m is offline
Paui4m is on a distinguished road
We have a GX as well and that V8 start-up makes this thing sound pretty tame . They both have a similar mannerism when you shut them down as well.
Paui4m is offline   Reply With QuoteReply With Quote
cold , drops , idle , normal , start
Cold Start rough idle for about 1 min Ktfords 3rd gen T4Rs 13 05-15-2016 10:36 PM
High idle on cold start 808islerunner 3rd gen T4Rs 7 03-05-2016 09:58 AM
Rough idle at cold start runnyrunnerton 3rd gen T4Rs 16 08-28-2014 07:49 AM
Low idle on cold start - '88 22re bishopsRobes Classic T4Rs 1 12-06-2010 11:19 PM
Can idle at start up in cold weather be adjusted? ssjetset Problems & Warranty Issues 2 12-18-2007 07:20 PM
