Old 05-19-2020, 07:28 PM #1
GreenMountainOwl GreenMountainOwl is offline
GreenMountainOwl is on a distinguished road
Help! Won’t start, various lights on, SOS mode?
2014 Limited
Wife drive my 4Runner earlier today and now it won’t start. The SOS switch has a little red light on near it that says Safety Connect. Dashboard shows battery and check engine light. Engine won’t crank. Tried numerous jump packs with no luck.
At one point while trying to start, the screen asked me to put my key fob near the start button. I did that and nothing changed.
My wife is about to leave for a week and I need my vehicle to work!
Suddenly as I wrote this I hear a strange fluttering sort of noise from the brake booster! What the heck? It’s a little cylinder with a yellow label on the top and a hex but in the middle.
GreenMountainOwl is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 07:36 PM #2
Thank you. They are very secure.
Now the battery and check engine lights are still on even with the key fob away from the vehicle. There was a loud beeping sound until my wife walked away with the fob. As if it was telling me it was running and the fob was out of range.
Old 05-19-2020, 07:40 PM #3
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
So weird, I was hoping it was something quick and easy. I haven't got keyless start so sadly, I haven't a clue as far as that goes.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 07:47 PM #4
Update, got out my Schumaker battery charger and it read 5.5v or so and 10 percent charge. I began the charge process and it now reads 10 percent and 6v.
The thing near the brake booster is clacking and making tons of noise. I’m worried about leaving this alone to charge. Or to walk from it away at all.
Edit to add: another clacking sound seems to be coming from the MAF sensor area...?
Another edit: this may be the original Panasonic/Toyota battery...could it simply be dead?
Old 05-19-2020, 08:00 PM #5
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
If your reading 6v off the battery I would call that too dead. You can jump dead batteries but 6v seems really low.
If it's doing weird stuff I would unplug it till you get a fresh battery.
Seems odd tho. I could be wrong.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:23 PM #6
A neighbor brought over a 200A jump starter and it started!
Now the automatic running boards light is flashing...and I don’t even have them!
Voltmeter reading 13.8 under throttle and 13.2 at idle.
Old 05-19-2020, 08:26 PM #7
Banned
Banned
Above my pay grade. Hope you figure it out. Something is definitely not right.
Are your battery terminals clean?
Have you modified your electrical system at all?
Old 05-19-2020, 08:26 PM #8
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
idle/drive it for a while and see idiot lights go away
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 08:35 PM #9
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
If your truck lived in the cold Northeast for six years with the original Panasonic battery consider yourself lucky. That’s really pushing it even for a well tended battery in a mild climate. You can’t even begin to reliably troubleshoot electrical problems with a crap battery or corroded connections. Go get yourself a new battery, install it, then report back your findings.
Old 05-20-2020, 12:35 AM #10
If only my wife would believe my very first suspicions as have been discussed above, that the darn battery is simply at the end of its life!
But she won’t.
Drove around town, parked, sat for a few minutes, and it started up. Drove home and had similar luck.
Silly running board light is still on.
Time to go down to the auto parts store first thing in the morning.
Old 05-20-2020, 08:57 AM #11
00Sebby's Avatar
00Sebby 00Sebby is offline
Real Name: Mark
00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice
00Sebby's Avatar
Real Name: Mark
Yep, as others have said. 6yrs is a good run on modern batteries. When any of my vehicles won't start, I check:
1) Did I leave anything on or open... headlights, dome lights, etc.?
2) Has the season changed? Corrosion between the battery clamps and posts can expand with temp/humidity changes causing a weak connection. Sometimes this reveals itself as a loose terminal if the clamp wasn't real tight to begin with.
3) Is there significant corrosion built up around one of the terminals?
4) Is the battery old? If everything else looks good and the battery is old, I go ahead and replace it. It's not worth the time recharging, hoping it holds up for another few months, etc.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 01:58 PM #12
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Problems with automatic running boards are pretty common. Chances are pretty good they are unrelated to your starting problem. I'd get a new battery - it's time!
Old 06-27-2020, 02:26 PM #13
My apologies for walking away from this thread and never logging back in. My wife had to travel for something that turned out to be a real big deal and life is only now getting back to normal.
The culprit turned out to be simply a dead battery. I replaced it and things have been fine ever since.
Thanks to all who read and responded. I was really stressed out at the time.
Old 06-27-2020, 02:36 PM #14
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
This reminds me that I need to get off my lazy rear and replace mine before it goes bad. Still got the original, bought October 2014, so nearing six years old.
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
engine , light , sos , start , won’t
4WD Issue: Multi-Mode Blinking Lights Wanderlust4 3rd gen T4Rs 6 03-18-2017 10:08 PM
Anyway to keep lights on all the time without enabling JBL nighttime mode pepowdylan 5th gen T4Rs 14 12-09-2013 04:09 PM
multi mode: 4wd button and L4L (no lights on dash though) work but H4L does nothing scuheckler88 3rd gen T4Rs 0 02-28-2011 02:55 AM
Adjusting auto mode headlight sensitivity and LED rear lights THEROK 4th Gen T4Rs 8 12-14-2010 01:33 AM
4WD Mode Locked, VSC + Engine Lights On cbob Maintenance/Detailing 1 11-16-2008 05:31 PM
