05-20-2020, 06:23 PM
Need New Tires
I need to get new tires for my TRD Pro and I will admit I'm a bit of a poser in that it probably will never go off-road but I do like the appearance of a bigger tire. What do you recommend for that bigger look but not needing the ruggedness of say a KO2?
05-20-2020, 06:31 PM
I would get a good street tire, but just bump it up a size from stock. You probably don't want any weight that you don't need. 275/70/17 will fit fine with no rubbing, but will give you the size you're after. Michelin defenders have been great on my wife's car.
This is assuming you're not dead set on an AT tire, even though you don't need it.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
05-20-2020, 06:35 PM
Real Name: Sparky
Real Name: Sparky
The KO2 is halfway between a poser tire and a true MT, so I'd go with the Rugged Trail as one step below that.
Old and (c)rusty.
05-20-2020, 06:39 PM
Need New Tires
If it's appearance you're going for and not going off road, then Ridge Grapplers in a passenger load seems like the best choice IMO. Ridge Grapplers come in passenger versions in 265s and 285s depending on the size you want. I think the 265s still measure a bit larger than factory 265s.
05-20-2020, 06:48 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
05-20-2020, 07:29 PM
Real Name: Don
Real Name: Don
Hope you don’t go thru what I just did. I have 2020 Pro and tried 10ply Falken in stock size. Love the aggressive look. Problem could not get them balanced. I had them mounted on my new SCS wheels and between 50 and 60 wheel shake. Tried another set same thing. Had them switch to the 4ply Falken same thing. Had them put back on stock Nitto Terra grapplers G2’s. Steering wheel no shake. Can you believe that. I was not going thru getting them road force balanced. There are posts on where guys tried that and still did not work. Just a little info.
05-20-2020, 07:43 PM
Real Name: Danny
Real Name: Danny
Cooper AT3 ... Loved those tires and served me great when I hitting 5 minutes of dirt at the time.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
05-20-2020, 07:56 PM
I can believe it. I've never owned a Goodyear tire I liked. Sumitomo was in business for several years with Goodyear. Sumitomo is the parent company of Falken. I felt it was likely that some of Goodyear's poor quality might have trickled down...
Recently a buddy of mine and manager of a national tire chain told me his company has had lots of problems with Falken tire uniformity.
Based on his recommendation for a moderate A/T, and my own research, I went with the Yokohama Geolandar A/T G015. It is as quiet as the Dunlops that came on my 4Runner, but these are much better in the rain, snow, and the trails it's been on since they were installed. Much better in the rain than the KO2's I had on another vehicle.
No vibration or shimmy up to 80 mph. They are a firmer ride than stock being LT265/70R17 E, but it doesn't bother me.
05-20-2020, 08:01 PM
Real Name: Jim
Real Name: Jim
Wildpeaks. You'll never regret getting them.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
05-20-2020, 08:06 PM
Real Name: Don
Real Name: Don
There the ones I had issues with. No good for my 4runner.
05-20-2020, 08:50 PM
Had an issue where 4 out of 5 of mine were out of round (Early 2019 manufacture group). Tirebuyer got me a new set that was made a few months later and had no issues.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-20-2020, 09:26 PM
Falken wildpeak AT3 !
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
05-20-2020, 09:30 PM
Need New Tires
Falken Wildpeak AT3 plus added benefit of 3 peak snow traction.
05-20-2020, 09:32 PM
2nd this!
05-20-2020, 09:42 PM
Real Name: Jeff
Real Name: Jeff
For what it’s worth, I’m on my second set of Falkens with no issues. They do tend to take more weight to get them balanced compared to other tires though. Back in March I had a mobile guy come out and transfer the tires from my factory wheels to a new set of FN wheels and he confirmed the same thing. He said they sell a bunch of the Nitto and Toyo tires and they usually don’t take much weight to get them balanced. When these Falkens are done, I’ll probably try something else.
2015 Limited, bone stock for now
