Old 05-21-2020, 08:01 AM #1
frank1313 frank1313 is offline
frank1313 is on a distinguished road
I know I know another 5100's question
4runner noob here and have been researching this for the last few on getting my 5100's installed soon and have two questions where i could use the community's feedback and expertise!
1. for the front I would like to level it out, do i set the snap ring on the second slot from the bottom, currently running factory tries for the time being which are 265/70R17. (changing out to a different tire size is not going to happen as of yet as the tires have 100 miles on them at the moment - dealer installed them )
2. i have a third row 4runner which im not sure if i need a rear spacer here do to the extra weight? as in question 1 looking to level our the 4runner. do I just run it with rear 5100's with no spacer? do i add a corn fed spacer with the 5100's to get the truck level and not much of a lift.
4runner noob here and have been researching this for the last few weeks now. front setting i feel im good on, the rear with a third row i couldn't find much on that .
any feedback would be great here or experience.
2015 4Runner SR5 - Third Row - new build !
frank1313 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 12:14 PM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I did 0.85 with air bags in the rear at minimum pressure. Almost level as in photo. 1.75 may be a better level but any load and you will need the air bags. Not sure if spacers would be wanted for 1.5.
I know I know another 5100's question-085-jpg
BobsTrail is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 12:19 PM #3
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
The bottom slot is the same as stock and won't lift at all.
The next slot up will raise the front approx. 0.85" and almost level it while still having a very slight forward rake (front slightly lower than rear). This would be my preferred setting as with the rear still being slightly higher you can load it up some without having a reverse rake. Here's a thread with pics of T4R's with that setting:
Bilstein 5100 - .85 Pic`s
The next slot up will raise the front approx. 1.75". Some say it will be perfectly level while others have reported that the front may be slightly higher than the rear. If I were to put mine at that setting then I would use a spacer in the rear as I personally don't ever want the front to be higher than the rear (with typical use and loads).
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 01:05 PM #4
thanks for the feedback here. .85 it is and no rear lift.
Old 05-21-2020, 01:12 PM #5
BIGpharma's Avatar
BIGpharma BIGpharma is offline
BIGpharma is a jewel in the rough BIGpharma is a jewel in the rough BIGpharma is a jewel in the rough
BIGpharma's Avatar
To give you some perspective,
I have a 2.5" lift in the front, and a 1.5" in the rear with third row seats.
Front hub measurements are 22.5"
Rear hub measurements are 22.75"
With the third row, I am pretty much level but with things in the trunk I am at reverse rake.
0.85" in the front is perfect with third row seats since a 4Runner without third row seats would still have an inch of rake with my lift.
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
BIGpharma is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 02:31 PM #6
Wolfman’s Brother Wolfman’s Brother is offline
Wolfman’s Brother will become famous soon enough Wolfman’s Brother will become famous soon enough
I’m at .85 with stock rear and while it was perfect for 265s and an unloaded rear, the moment I put the 275 K02s on I wished I had done 1.75 with a 1in lift spring in the rear.
The other very minor nuisance is the driver side lean you end up with, without any form of compensation for it.
As a result, as much as it hurts, I’m looking at swapping to 6112s up front as they have 7 notches with smaller increments that enable you to level the front side to side by staggering the drivers side 1-2 notches higher than the passenger side.
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
Wolfman’s Brother is offline   Reply With QuoteReply With Quote
4runner , 5100s , level , rear , spacer
5100 OME 890 question Karbyn 3rd gen T4Rs 12 08-08-2017 07:02 PM
5100 question calcrc 5th gen T4Rs 8 08-08-2015 05:58 PM
5100 Question cgv69 4th Gen T4Rs 6 02-18-2014 01:12 PM
5100 question gfluff 4th Gen T4Rs 3 01-03-2014 11:12 PM
5100 question tprice1985 5th gen T4Rs 4 01-03-2012 10:37 PM
