Old 05-23-2020, 11:25 PM #1
NWsuperwhiterunner NWsuperwhiterunner is offline
NWsuperwhiterunner is on a distinguished road
Boss Strongbox 4runner system
I'm about ready to order this 4Runner Drawer System — BOSS StrongBox has anyone else purchased one ?
NWsuperwhiterunner is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 11:39 PM #2
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
nice looking box for a decent price too, looks like it has side access too, that's a plus. a bit deep (ie tall) for my taste, I would be able to see in my fridge
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 11:42 PM #3
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
No experience but use code "Fieldcraft" for 25% off.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 12:03 AM #4
Bronc Bronc is offline
Bronc is on a distinguished road
I've had mine for about 2 weeks.
Pros: Easy to install, quality build and great storage. I was concerned that the top wing would not clear the JBL sub in the TRD Pro but there is about an inch of clearance.
Cons: Had an issue with squeeks, but a felt adhesive pad above the sliding drawer seems to have cured that. The MOLLE cutouts on the side of the box would be hard to access anything due to the top wings. I look at them more as a function for weight savings than extra storage. You will lose the accessibility of the storage area that holds your tire jack.
Overall, I would purchase again. Its a solid piece of kit.
Sent from my SM-T813 using Tapatalk
Bronc is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 12:27 AM #5
jrandom's Avatar
jrandom's Avatar
Ah bummer, it looked like they might have been hinged, they don't move then? if not bummer. I pretty much expected them to lift open, like most other fitted kits.
2013 TE w/ KDSS Nav
Old 05-24-2020, 12:30 AM #6
That is correct, they are bolted on and will not hinge.
Sent from my SM-G960U using Tapatalk
Old 05-24-2020, 01:09 AM #7
jrandom's Avatar
jrandom's Avatar
Thanks for confirming, regardless it is a nice, sturdy looking setup, at a pretty decent price.
2013 TE w/ KDSS Nav
Old 05-24-2020, 01:28 AM #8
Smile
Wow Holly crap Thanks for the code
Old 05-24-2020, 01:31 AM #9
did you use the turnbuckles to install it ? I want to be able to remove it if needed and love not having to drill to install it, but I'm a little concerned about it shifting around especially off road
Old 05-24-2020, 01:51 AM #10
sn_85's Avatar
sn_85's Avatar
You're welcome, just wanted to pass some savings along!!! Heard one of the guys say it on the fieldcraft survival podcast a couple months ago. Glad to know the code still works.
Old 05-24-2020, 01:58 AM #11
sn_85's Avatar
sn_85's Avatar
I wonder if you could still modify it though. It looks like the top wing parts are bolted on. I'm sure if you got creative enough you make it so that it hinges up. Or maybe not even install the top wing parts and just use it as a template for a wood wing kit and install your own flip up hinge.
Old 05-24-2020, 10:02 AM #12
Yes, I used the turnbuckles. Nice and secure with no movement.
Old 05-24-2020, 10:04 AM #13
Yes, you have to install the wings on after you install the box. So, you could leave them off if need be or build your own pretty easily.
Old 05-24-2020, 01:44 PM #14
Talking
Nice, the specs say the drawers are 32 in long, by coincidence a 14.5 pinned and welled collapsed AR should fit
Old 05-24-2020, 01:52 PM #15
jrandom's Avatar
jrandom's Avatar
Oh, I am sure you could. That gauge steel is easy to work with. You easily pop rivet a piano hinge and attach a form fit carpeted piece of ply or mdf . There is just so much usable space on the sides.
Sadly, box is too deep for me. I will keep and eye out and see it they come out with some different depth boxes.
2013 TE w/ KDSS Nav
4runner , boss , ready , strongbox , system
Toytec Boss Suspension System w/KDSS NC_High_Country Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-08-2019 08:26 PM
*NEW* '96-'02 4Runner 2.0 BOSS Resi with Adjuster! ToyTec Lifts Toytec Lifts 7 04-26-2017 11:37 AM
ToyTec's New BOSS Suspension System ToyTec Lifts Toytec Lifts 19 05-17-2013 06:05 PM
