Old 06-07-2020, 11:18 AM #46
JRLTRD JRLTRD is offline
JRLTRD is on a distinguished road
Originally Posted by avo1789 View Post
4. When I initially positioned the box, I made sure to leave enough room for the back seats to recline to the last position. Problem is that when you tighten the turnbuckles all the way it starts going toward the seats. Now I can only recline 2 notches instead of 4 (or 5, can't remember). It would be nice if the front/side turnbuckle mounts could be slightly repositioned toward the front of the car.
I haven't received mine yet its on the truck but couldn't you build a block of some sort that will prevent the box to shift forward?
Boss Strongbox 4runner system-o2svg7s_1-jpg
2020 ORP Mag Gray w/KDSS
Falken Wildpeak A/T 285/70/17 | Bilstein 5160/6112 | SPC Control Arm | RCI Rock Sliders | Rago Hidden Winch Mount | Badlands APEX 12k Winch | BOSS StrongBoxx Drawer System | BlackVue DR900S-2CH 4K UHD Dual-Lens Dashcam | Orange Boxx Molle rack system | Diode Dynamics Low Beam HID Conversion, High Beam LED Headlight, SS3 LED Fog Light
JRLTRD is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 01:21 PM #47
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
I added a 'tension nut' to the existing turnbuckles. It's like a nylon nut minus the nylon insert.
Originally Posted by C3XOG View Post
first post...finally something to add.
I bought one back in October. It has been great.
I have taken it off road. With a lot of vibration and bumps, the turnbuckles they provided would loosen up slightly and I got some squeeking after a few hours. I bought a set with locking nuts from E-Rigging.com and problem solved. Never loosened up again. No more squeeking.
Daikon is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 08:25 PM #48
NoLight's Avatar
NoLight NoLight is offline
Real Name: Charlie
NoLight is on a distinguished road
NoLight's Avatar
Real Name: Charlie
Smart what size nuts are those? I need to do the same thing.
Immune, Steve!
NoLight is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 01:25 AM #49
Daikon's Avatar
Daikon's Avatar
i went with M10 1.5 because my local home depot did not have nylon nuts in the correct size (3/8-16).
I'm replacing the turnbuckle bolt that connects to the box with an eyebolt and bought and new nylon nuts instead (3/8-16 thread through the turnbuckle perfectly). I'm going with an eyebolt because I'm using the molle side panels to attach a fire extinguisher so I don't want to get cut when I'm reaching in on the side.
Old 07-01-2020, 08:52 PM #50
gibburnz's Avatar
gibburnz gibburnz is offline
Real Name: Ryan
gibburnz has a spectacular aura about gibburnz has a spectacular aura about
gibburnz's Avatar
Real Name: Ryan
Wrote an article on Trail4Runner.com
Hey guys...
Just wrote an article about this on Trail4Runner.com. Go check it out:
BOSS StrongBox Drawer System Install + Review For 5th Gen 4Runner
Boss Strongbox 4runner system-boss_strongbox_custom_drawer_system_install_review_5th_gen_4runner_15-jpg
2011 Trail Edition. Black. '17 RRW RRH-6's. w/285 KO2's. Rago molle panels. C4 Fabrication lo pro with 25" Xtreme LED, Smittybilt X20 winch and Agency 6 fairlead/shackle. RRW V3 rock sliders. TRD front skid. Spidertrax spacers. Gobi Stealth rack and ladder. ARB Safari snorkel. AnzoUSA 14+ tails. Blacked out projector/retro-fit head lights. Baja Designs pro fogs, S2 ditches and rear dust lights. Eibach 2.5" lift w/ ICON delta joint UCA's. C4 dual-swing rear bumper.
Check out Trail4Runner.com for more Installs and Write-Ups. Find my author link here.
gibburnz is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 10:01 PM #51
funny, I happen to read that article today as I recently installed mine. Good article!
Old 07-01-2020, 11:33 PM #52
Airwolf's Avatar
Airwolf Airwolf is offline
Airwolf is on a distinguished road
Airwolf's Avatar
Good install article. The Boss Box is BadA$$.
I installed my Boss Strongbox about a month ago and did have a small issue. The lock rods that are attached to the center knob got loose (just screwed in) and one fell out into the channel and was rattling around. This was the only indication something had "changed" as there was no rattles before! I removed the channel cover and re-installed it using Loctite. If you have or are getting one of these boxes you should probably check to make sure they are tight. Simple lock drawer while it is out of the box and see if you can turn the locking rods. easy enough to slightly unscrew and drop a drop of Loctite on the threads and re-tighten.
Also I installed a 3/4" high by 1.5" thick synthetic board the length of the Boss box between the rear of the box and the rear seat stop. This gives something secure for the box to go against.
Mike S.
2020 TRD PRO Army Green
2011 Metallic Gray SR5 3" Lift - SOLD
Airwolf is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 10:00 AM #53
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
Nice. I'm going to try and make a little platform that sits on top of the drawers when they're fully opened. I'll run the underside down the table saw to create grooves for the board to sit in so it can serve as a nice platform to food prep on.
Old 07-02-2020, 07:58 PM #54
Bronc Bronc is offline
Bronc is on a distinguished road
The right side lock rod fell out on mine as well, installed loctite. I contacted the company and they said that they would start applying loctite to the rods and fasteners. Also, check the central bolt that holds the lock arm in place, mine was very loose.
Sent from my SM-T813 using Tapatalk
Bronc is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 03:16 PM #55
LA260's Avatar
LA260 LA260 is offline
LA260 is on a distinguished road
LA260's Avatar
Anyone knows what's the max weight that can go in top?
Sent from my moto g(7) plus using Tapatalk
2020 Venture KDSS. Dobinsons C59-314/IMS574 3", C59-725/IMS701 2". Dobinsons UCA's. 285/70/R17 Cooper Evo M/T. Prinsu Full Rack. RSG Sliders/KDSS skid.
LA260 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 06:27 PM #56
GlacialSpeed GlacialSpeed is offline
GlacialSpeed is on a distinguished road
This is a cool looking product. Lock nuts on the turnbuckle is a great tip.
2016 MGM Trail
GlacialSpeed is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 01:56 PM #57
SpaceBanana's Avatar
SpaceBanana SpaceBanana is offline
SpaceBanana is on a distinguished road
Does anybodys box shake and make noise when driving. Ive taken it off and tightened it and it still does
SpaceBanana is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 02:14 PM #58
CollinJ's Avatar
CollinJ CollinJ is offline
CollinJ will become famous soon enough CollinJ will become famous soon enough
CollinJ's Avatar
Looks great, I saw the article on T4R. It’s what I’m looking for in a storage box, something that could be removed if needed for some reason but also well built.
Sadly I’ve got the stupid factory sliding tray so no luck there! Maybe they’ll have an option for a sliding tray in the future.
CollinJ is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 01:20 PM #59
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
You can install the BSB with the sliding tray, it just won't slide anymore! The turnbuckles it comes with will extend that much further down and lock the box in place on top of the sliding tray.
Old 07-09-2020, 01:28 PM #60
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
If you throw a bolt on to the top and bottom of the turnbuckles, it prevents the turnbuckle from loosening up.
4runner , boss , ready , strongbox , system
Toytec Boss Suspension System w/KDSS NC_High_Country Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-08-2019 08:26 PM
*NEW* '96-'02 4Runner 2.0 BOSS Resi with Adjuster! ToyTec Lifts Toytec Lifts 7 04-26-2017 11:37 AM
ToyTec's New BOSS Suspension System ToyTec Lifts Toytec Lifts 19 05-17-2013 06:05 PM
