07-01-2015, 08:00 PM
2011 4Runner Starter...
Does anyone know why its so hard to find a starter for 2010-2015 4Runners? I need to replace the one on my wife's 2011...none of the auto parts stores around me carry it (AutoZone, Advance...). I havent tried the stealership yet but I will if have no other choice.
Thanks in advance for the help...
Matt
07-01-2015, 08:21 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Because they rarely break.
07-01-2015, 09:00 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Originally Posted by BlackWorksInc
Sorry next time I will be PC and talk about supply side economics and how low demand leads to low supply.
07-01-2015, 09:11 PM
Let me know how well this self change out goes. I have replaced plenty of starters on previous vehicles I owned. I hope Toyota made it easier on the 4Runner than the Tundra's. I had to have my 07 Tundra towed to the dealership when it's starter went out. Apparently Toyota decided to put the starter on the 5.7L behind the exhaust manifold and behind a heat shield on the passenger side of the motor. $1300 later my truck was retuned to me fixed and running. BTW on the 4.7L Tundra the starter is under the intake manifold inside the motor. Good luck let us know how it goes.
Wellll you seeee what had happen wuz.....
07-01-2015, 09:23 PM
have you tried your local junk yard?
2009 Highlander Limited(traded for Tacoma)
2012 Corolla
2015 Tacoma(traded for 4Runner aka "Beast")
2015 4Runner(aka Beast II)
2003 Honda Shadow Cruiser(motorcycle daily driver)
07-01-2015, 10:04 PM
I havent tried a junk yard or any other avenues yet...just the local auto parts stores. Not sure if I want to trust a used starter anyways. I agree that the demand is probably low, as the 5th gen 4Runners are the most reliable vehicles ever built, but normal wear and tear parts in general are hard to find in my area (Virginia Beach) for some reason. Even something as simple as Fram extra guard oil filters are not sold or in stock locally here...anyways I will keep everyone info-ed on the install once I get my hands on one... Im hoping the hardest part of the starter change out is taking off the skid plates...
07-01-2015, 11:19 PM
Replace the solenoid contacts and be done. Under $20 ?? at the dealer.
Brad B.
Durango, CO
2015 SR5P 4x4 (Faux Pro)
2007 Tacoma 4x4
07-01-2015, 11:40 PM
I would much rather have an OEM starter out of an engine with 100K+ miles, than a new one from a parts store.
07-01-2015, 11:47 PM
That's why I gave him the Denso SKU and Toyota Part Numbers, I really wouldn't trust much else to be honest with you.'
Assuming the issue is the contacts and not the solenoid coil, armature, brushes, commutator bar, and/or any other component in the starter that can wear and/or fail sporadically. (though usually it is the contacts, but that's pretty damn early for a starter to go out on a Toyota...)
07-02-2015, 12:16 AM
This is exactly what I did when my starter went out on my '85 SR5 pickup with less than 30k miles on it.
I saw it's an '11, did he say how many miles?
2012 Trail Edition
How 4WD works
07-02-2015, 12:17 AM
As far as location goes, my understanding is that the starter is on the drivers side and isn't too bad to get out.
I agree with BlackWorks, very early for a starter to go out on a 4Runner, even if you have high miles doesn't mean your starter is close to wearing out. Nearly 200k on mine in my 02' never done anything to it. Did have a 1MZ V6 Camry that it went out at 186k.
Car-part.com is a great resource. I have gotten great deals on nearly new parts for a fraction of the cost like a $500 charcoal canister for $50 with 35k miles warrantied for free for 1 year.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
07-02-2015, 01:14 AM
I guarantee it will be harder than changing skid plates.
What are the symptoms you are experiencing?
07-02-2015, 07:35 AM
Real Name: Jonathan
Real Name: Jonathan
So what do parts stores there sell, only those stick on fake engine vents?
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
07-02-2015, 08:26 AM
Yep, that's about it around here
