Old 05-26-2020, 01:12 PM #1
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
Transmission fluid (ATF) change (using the cooling line) 5th gen 4runner.
I did my Transmission fluid (Toyota WS ATF) change using the cooling line this past weekend.
Primarily I used info that was posted in 4th gen section (big thanks to OP (46Runner) for a write up and for all info there!), here is the link: ATF Exchange (using the cooling line)
Couple things to note for 5th gen owners:
1) I have spent some time making sure I am selecting the correct (return) line to be used for the drain of old the fluid… in my 2013 4runner (and I would believe it would apply to all 5th gen) possibly best connection for that is located near the top of the engine bay next to radiator expansion reservoir (see attached picture below). I have disconnect rubber house at that connection and attached 3/8" ID vinyl hose to the metal tube for the drain (I have also plugged the rubber hose for the duration of the process-not sure if that is needed or not).
Toyota actually marks that return line with blue paint (that is the one you want for drain!) and marks the line going from transmission to radiator with red-which is very nice indication of what each line means.
2) I have used "gravity feed" method to fill the transmission with new fluid instead of “Fluid pump”, I have routed 3/8" vinyl hose from the engine bay to the fill location on the transmission (make sure the vinyl house is not touching part of exhaust system) and attached small funnel on the top (see picture)- that made the fill process very easy and fast!
I was surprise to some degree of the color of smell of the old fluid- my truck has 77K, but the fluid looked great (IMHO)… it was just slightly discolored and had smell of the new fluid…
I guess I was expecting worse, considering that I use my truck off road and for towing… I think I should have waited until at least 100K or even longer to do that… I guess that is the price I have to pay for my OCD… LOL
Hopefully, above info will be beneficial for all 5th gen owners that are planning to do Transmission fluid change.
Transmission fluid (ATF) change (using the cooling line) 5th gen 4runner.-return-line-connection-jpg  Transmission fluid (ATF) change (using the cooling line) 5th gen 4runner.-gravity-feed-jpg
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 01:39 PM #2
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Good stuff
I just wanted to point out you did the swap at the RIGHT time.. if the fluid has already burnt out and you do a late swap, could lead to transmission problems later on.
I did my first trans fluid swap at 60k miles, and it was still ok with minor burn in. I dropped the trans pan and swapped the metal filter mesh while I was there... Quite surprised how much debris was on the pan magnets!
In the end I would say the fluid swap is a must if you use the truck heavily or off-road.. or even if you plan to keep it a long time and want some peace of mind
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 01:42 PM #3
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by borfoo3 View Post
Good stuff
When you say swap, does that mean the same as a flush (full)? Or is it an exchange?
On previous cars, I have always flushed the trans at 30k. Was thinking about doing it with the 4runner as I have gotten the temps beyond 220F a few times.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 02:00 PM #4
borfoo3's Avatar
borfoo3's Avatar
It's not a full flush, as you don't get 100% new fluid by the pan drop method. Basically you are unbolting the transmission pan along with any fluid in it and whatever drips out... some of the previous fluid is still in the transmission internals.. so guess it's more like a partial flush. This is how I prefer to do it for my cars just to allow some break-in and not shock the system with new (heavier) fluid
I also got the temps beyond 220F several times. Hence why I now have a trans cooler on. I plan on doing 60k fluid changes + metal filter mesh. No need to worry about it too much.
Old 05-26-2020, 02:26 PM #5
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
I was in the same exact situation as you and used the same technique. Took my sweet time doing it to minimize mess. I changed my 2015 camry's at 60K because it had some real nasty slippage between 3rd,4th, and 5th gear. OEM ATF is not lifetime. I am now a believer that no lifetime fluid is actually good for a lifetime as advertised.
I used the cheapest synthetic I could find and that was Valvoline Maxlife ATF from walmart.
Gravity-fed system is simply the cleanest and easiest method. Used the same funnel and hose for rear diff and probably gonna use the same for transfer case and front diff as well when the time comes. Don't worry friends, I clean the hose out real good to avoid cross contamination.
As for the 4runner I did mine right around 75k and wished I had done it at 60k instead. 4runner definitely shifted w/ less hesitation between gears.
And as for the Camry, it definitely cured the nasty slippage between 3rd,4th,5th. I was ready to overhaul the trans because i let the idea that lifetime fluid shouldnt misbehave that soon.
Maxlife ATF has been in both vehicles for roughly 10k and its been running great w/ no problems.
1jzgte is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 10:56 PM #6
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
5th Gen Fluid Guide: Beginner Fluid Maintenance
I do mine every 50k. To each their own. Here's a diagram I found on the Toyota website and I drew on the flow direction and best place to drain from. Hope this can help anyone else that maybe wants to do it from a different connection.
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 11:44 PM #7
Seattle206's Avatar
Seattle206 Seattle206 is offline
Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice
Seattle206's Avatar
Thanks for the write up and pictures. The original DIY thread from the 4th Gen forum was easy to follow. I just did my tranny fluid exchange at 81k on my '14 SR5 and the initial 4.5 quarts I got out was near black. So glad I did this job, wish I had done it sooner though. The temperature check was easy, the overflow streamed out some fluid, then trickled until I plugged it back up. In all I put in 13 quarts of the ATF WS fluid.
Seattle206 is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 07:10 AM #8
ParlaySlow ParlaySlow is offline
ParlaySlow is on a distinguished road
Anything wrong with using the sending line (trans->radiator) instead? I can just as easily disconnect that line and point it straight into a bucket.
ParlaySlow is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 10:45 PM #9
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
We have 360K miles on the transmission in our 2014 and have used Valvoline Maxlife since the first fluid change. I always get a good chuckle out of the posters here who only use Toyota WS. It just highlights their fear factor because they donít know anything technical.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 06-02-2024, 10:37 PM #10
LWN's Avatar
LWN LWN is offline
LWN is on a distinguished road
LWN LWN is offline
LWN's Avatar
You certainly can, but if you use the return line then you'll also be flushing all the old fluid in the radiator/trans cooler. No sense leaving all the old fluid in there IMHO.
2010 Black Trail Edition w/ KDSS/Nav & BFG 275-70-R17 AT TA KO's, "LWN Blue Wire Mod" for locker & ATRAC in 4H
LWN is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 11:27 PM #11
JailbreakOverlandr JailbreakOverlandr is offline
Real Name: Richie From Boston
JailbreakOverlandr is on a distinguished road
OEM trany fluid alternative
I already used it once ut cannot remember the name of the alternative to Oem fluid, help me out fellas
JailbreakOverlandr is offline   Reply With QuoteReply With Quote
5th , fluid , gen , line , transmission
2011 toyota 4runner V6 limited just pass 100k mileage change transmission fluid? bapsdds 5th gen T4Rs 3 08-18-2020 11:20 PM
Transmission fluid change vicpick58 5th gen T4Rs 27 08-18-2020 11:00 PM
Transmission Fluid line Flow Confusion alumarine 3rd gen T4Rs 5 10-14-2016 11:44 AM
2004 4Runner, V8 Transmission fluid change jacktahoe Maintenance/Detailing 9 01-01-2011 04:02 PM
Transmission fluid change BadHabit Maintenance/Detailing 2 03-26-2005 04:46 PM
