Old 05-27-2020, 12:36 PM #1
Rogue-Runner's Avatar
Rogue-Runner Rogue-Runner is offline
Rogue-Runner is on a distinguished road
Where do these washers go on a TRD Pro Suspension?
I'm just buttoning down everything after installing a 2017 TRD Pro Suspension on my 2016 SR5, although I'm not sure where these washers go or if they're necessary (see pic). I have two sets of these, so 4 washers in total. Two have a little cross etched in them. I've checked the parts and repair diagram on the front and rear suspension but I'm not seeing them anywhere. I've looked at pictures and can't tell from that either where these go. Others show some black washers that are connected to the rubber piece but none show these additional nickel washers. Can anyone identify these? I'm pretty sure they go on the rear somewhere, but I could be wrong.
Also, the little hooked tab that you use to mount the bracket to mount the reservoir fell inside a little hole inside the frame and I think it's lost forever... Anyone know if a hardware store would carry these or if I need to go to Toyota? Thanks!
Rogue-Runner is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 12:37 PM #2
Old 05-27-2020, 12:59 PM #3
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Those remind me of UCA washers.
delloro is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 02:04 PM #4
Wow I think you're right! The TRD setup that I bought came with UCAs but they're the same as SR5 so I didn't bother with them. You'd think there would be 8 washers instead of 4 though. I'll double check. Thanks!!
Old 05-27-2020, 03:09 PM #5
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
All stock 4Runners have the same UCA's, even TRD Pro's. So unless you changed out your UCA's then you should be fine.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 04:43 PM #6
Yup. I just hope that's what these washers are for and not for some other component that's going to have them missing. Still not sure why I only have 4 though.
Old 05-27-2020, 07:27 PM #7
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
These are used to mount your rear reservoirs :-)
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 11:40 AM #8
Sbenis Sbenis is offline
Sbenis is on a distinguished road
Yes those mount in the frame to mount the rear resi
Sbenis is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 12:06 PM #9
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
That washer looks to be one of the washers for the rear shocks
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 03:30 PM #10
Right, it's just the big washers I was confused about. I think the comment above belonging to the UCAs is correct (at least I hope because it's all done!).
The picture cut the words off in the middle of my post, but my problem was that when trying to install the reservoir bracket the little screw tab fell inside the hole and is currently inside the frame. I don't think I can get it back (unless I were crazy enough to slice open the frame). I'm not too worried about it though. The reservoir is mounted, but I don't think it's rattling or anything. I might call the dealer about getting an extra one if I can't find one at Lowes.
inside , mount , suspension , trd , washers
5th gen headlight washers SnowYeti 5th gen T4Rs 0 11-16-2019 11:23 AM
Crush washers turbo8 3rd gen T4Rs 11 11-06-2019 12:53 AM
crush washers mendozer 3rd gen T4Rs 2 02-24-2016 03:19 AM
washers - help Gecko123 4th Gen T4Rs 6 02-04-2014 07:40 AM
