Old 05-29-2020, 08:56 AM #1
jtice's Avatar
jtice jtice is offline
jtice will become famous soon enough
jtice's Avatar
Upper Arms - Worth it? (Eibach Pro Truck Lift)
I have a 2016 SR5 4Runner with an Eibach Pro Truck Lift in stalled now for a few months.
Love the lift, nice improvement over stock.
Before I bought the lift I read that you do not need to change any A-Arms with it, since you are only lifting about 2" or so.
While the ride and handling of my 4R is not bad, I wonder if it could be better.
I do notice a bit more feedback from the road into the steering.
Doesnt wander or anything like that, you just feel the ruts and potholes in the steering a bit more.
Has anyone had this lift, or one like it installed for a while, THEN installed A-Arms?
Did you notice a difference you think made it work getting the arms?
Here is the readout from my alignment.
www.johntrottocreations.com
2016 SR5 - Eibach Pro Truck Lift, Freedom Offroad UCAs, 255/75/R17 BFG KO2, C4Fab Lo-Pro Bumper, Smittybilt 9.5 Winch, Rocky Road Super Sliders, SSO Roof Rack, Boss Strong Box.
jtice is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 09:00 AM #2
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
My thoughts are that your caster is definitely too low. I'd try another alignment shop and see how much additional caster they can get while keeping everything else in spec. If 1ish degree is all they can do, i would look into some upper control arms for sure. Your handling will improve significantly.
tm965 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 09:12 AM #3
jtice's Avatar
jtice's Avatar
What should the caster be at ideally?
And any recommendation for decent arms that wont break the bank?
Old 05-29-2020, 09:15 AM #4
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Your caster is really low # should be ~4*, that feedback through steering column over potholes will be gone when you get high caster UCA . I had same problem but with deferent setup . Good luck
ax2021 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 09:18 AM #5
mid 3s to low to mid 4s
Old 05-29-2020, 09:36 AM #6
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Aftermarket shocks can add about an inch more down travel which factory UCAs so not accommodate. Aftermarket UCAs do.
delloro is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 12:28 PM #7
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Had similar numbers when i did my lift. Drove fine but handling wasnt the same. Eventually replaced them and the car drove much better on and off road (3.9 castor). Few options out there but i think the more affordable ones are jba, spc, and dobinsons. All 400 to 550ish. Others have tried more affordable but lesser known brands but not sure how its going for them.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 12:40 PM #8
tire wear might be fine but adding uppers brings the drivability to a whole new level. So, not necessary, but man you notice it immediately and it's a great feeling. highway driving requires way less input, steering feels less twitchy.
Old 05-29-2020, 03:10 PM #9
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Not worth it... I say keep your stock upper control arms until you HAVE to change them, I.e. if the stock ones no longer clear your aftermarket coilovers
Don't let the marketing BS fool.you, the stock ones are plenty strong, quiet, and maintenance free throughout their useful lifetime
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 03:26 PM #10
KEVIN C.'s Avatar
KEVIN C. KEVIN C. is offline
KEVIN C. will become famous soon enough
KEVIN C.'s Avatar
Totally worth it. JBA UCA @ ~4.2 degrees caster w/ Eibach Pro-Truck lift. Makes a big difference and drives like a dream now - handling improved significantly.
KEVIN C. is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 12:39 AM #11
biratley biratley is offline
biratley will become famous soon enough biratley will become famous soon enough
I have the Eibach and JBA arms
Sent from my iPhone using Tapatalk Pro
biratley is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 10:58 AM #12
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I ran mine with a set of OME 883 springs and stock upper arms. Even at about 1.75" of lift I had decreased caster and I could tell. Especially on the highway. I swapped out to Eibach springs in the front and put JBA arms on at the same time. I already had Eibach rear springs. WAY better handling and the tracking on the highway is vastly improved. I went through the same thing on an 05 tacoma a few years back. On that one I used SPC arms but boy what a difference in how it drove afterwards.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 08:32 PM #13
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
I put the Eibach Pro Truck Lift on my 19 ORP last week.
Had it aligned a couple days ago- tech had no issue getting caster to 3.4L and 3.2R. This is with stock UCA's.
I'd had asked him to get as much as he could but was not able to verify he did or just put it in the middle of the factory spec.
It had 2.0 caster when I finished the lift before it was aligned.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 12:18 PM #14
SICKwidIT SICKwidIT is offline
SICKwidIT is on a distinguished road
What kind of wheels and tires do you have?
Seeing a lot of mixed reviews on having UCAs or not. So far I see a lot recommends it.
15 SR5 4WD
SICKwidIT is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 03:04 PM #15
tacoyota tacoyota is offline
tacoyota is on a distinguished road
2 inches or below you dont need it. The op needs a new alignment shop.
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
tacoyota is offline   Reply With QuoteReply With Quote
a-arms , arms , installed , lift , steering
Eibach Pro-truck lift f-it 5th gen T4Rs 2388 09-28-2023 10:42 AM
TRD Pro Kit vs. Eibach Pro Truck Lift Kit @jrfordlandia 5th gen T4Rs 12 10-20-2020 07:14 PM
T4R Special - Eibach Pro Truck Lift Kit Battle Born Offroad Engines / Suspension / Wheels / Tires / Audio / Accessories 8 08-08-2019 12:06 AM
FS: Ft. Worth, TX / 5th Gen 4Runner / Total Chaos Upper Control Arms Aznisegi For Sale: Suspension/Wheels/Tires 3 05-14-2018 12:39 AM
FS: 4th Gen, V8 OME Lift, LR Upper Control Arms, RB 1.25” Body Lift $850 shipped tacopie For Sale: Suspension/Wheels/Tires 16 01-01-2014 05:11 PM
