Originally Posted by MaddoxPics
Going to be re-gearing here soon and throwing in a front locker, and it got me thinking about things like the CRAWL and A-TRAC features. Are these systems affected in anyway with a front locker?
I know the A-TRAC is based on tire slippage, so I'm assuming IF I put on A-TRAC for whatever reason, it simply would just not work because there wouldn't be a tire slipping?
CRAWL however is crawl, and while not a true crawl system, I'm assuming it would still function exactly like it would without the locker?
Am I right on this? Or am I going to be experience all sorts of Christmas Tree fun on the dash?
These systems are 'slip' based.. i.e. they function/ intervene only when the vehicle senses a tire slip
A mechanical locker when engaged will not allow for slip, so it should not engage
You can test this with crawl control and rear diff engaged l, it will not modulate any of the rear wheels individually as they are spinning locked together
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
