Old 05-29-2020, 12:48 PM #1
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Air Locker w/ A-TRAC/CRAWL
Going to be re-gearing here soon and throwing in a front locker, and it got me thinking about things like the CRAWL and A-TRAC features. Are these systems affected in anyway with a front locker?
I know the A-TRAC is based on tire slippage, so I'm assuming IF I put on A-TRAC for whatever reason, it simply would just not work because there wouldn't be a tire slipping?
CRAWL however is crawl, and while not a true crawl system, I'm assuming it would still function exactly like it would without the locker?
Am I right on this? Or am I going to be experience all sorts of Christmas Tree fun on the dash?
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 12:54 PM #2
Whippersnapper02's Avatar
ATRAC simply wouldn't be triggered up front with the locker engaged and mall control would still work fine since it still reads your speed.
Old 05-29-2020, 02:51 PM #3
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
These systems are 'slip' based.. i.e. they function/ intervene only when the vehicle senses a tire slip
A mechanical locker when engaged will not allow for slip, so it should not engage
You can test this with crawl control and rear diff engaged l, it will not modulate any of the rear wheels individually as they are spinning locked together
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 03:25 PM #4
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I don't have a front locker, but have an ARB in the rear and ATRAC combined with that works pretty well. There will be plenty of situations that you won't be able to engage the front locker and the atrac will help. Turning with the front locked in tight areas is no fun either from what most people have said. So you will still be able to use the atrac at certain times. I would think that if the front is locked you definitely want to turn atrac off, as it would just fight the locker if and when slippage does happen.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
a-trac , assuming , crawl , front , locker
4H/4L - A-trac/crawl control & Multi-terrain settings? Ripper238 Off-Roading 7 07-09-2019 10:50 AM
Tru-Trac locker? ebg18t 4th Gen T4Rs 6 03-29-2013 10:34 AM
Using A-Trac with the E-Locker Dlak 5th gen T4Rs 2 07-25-2011 07:52 PM
