Old 05-29-2020, 06:19 PM #1
TomsPro TomsPro is offline
TomsPro is on a distinguished road
Coolant leak maybe?
2018 completely stock Pro with 5000 pampered miles on it. Can you guys tell me what I'm looking at here (serpentine belt area)? A major repair? Was there a recall on this? Truck is less than 3 years old so I assume under warranty, but has not seen a dealer since I took it off the lot new. Yep, not happy about this. Thanks.
Coolant leak maybe?-coolant1a-jpg  Coolant leak maybe?-coolant2a-jpg  Coolant leak maybe?-coolant3a-jpg
2018 blue Pro 4Runner
TomsPro is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 06:39 PM #2
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
Diffidently a coolant leak...can't tell where it's coming from. Should be covered under warranty.
ProLee is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 06:50 PM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Water pump likely at worst or weak hose connection at best.
<<<< is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 07:25 PM #4
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Yes. Can’t tell from where.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 07:29 PM #5
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
You need a clean view to determine the source. I would use a water hose to wash off the area, then drive around a bit. Then take a look--maybe you can see the leak origin. If the leak is really slow, may take a while for obvious coolant leak to appear. As another said it could be just a loose hose clamp if you are lucky--or water pump seep--no so lucky. Good luck!
TOYO74 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 08:13 PM #6
Yep, I'll do that tomorrow.
Old 05-29-2020, 10:25 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
If you're taking it to the dealer, I'd leave it alone. Why remove evidence that may help them determine where the leak is?
Old 05-29-2020, 10:32 PM #8
alextmullis's Avatar
alextmullis alextmullis is offline
alextmullis will become famous soon enough
Don’t clean it. Take it in as is.
alextmullis is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 09:25 AM #9
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
if you don't plan on replacing a water pump (at worst) or doing the repair yourself while it's under warranty, then leave that as-is and take it to the dealer. If you wash it off and its a dribble, you're going to be coming home with a new hose clamp on your first visit, or something like that.
leave the severe mess in place.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 09:29 AM #10
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
I can't believe nobody else has asked the obvious - OP, did you perhaps run over a unicorn?
delloro is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 07:02 PM #11
TOYO74's Avatar
TOYO74's Avatar
Good point You (and others) have about leaving evidence if going to a dealer. I figured the OP did his own work because he had not been to a dealer since buying .
OP--If planning a dealer evaluation--certainly leave the mess as is. Good luck
Old 05-30-2020, 07:16 PM #12
Well crap....
Didn't read these replies this morning and went ahead and cleaned it up. Topped off the reservoir (it was empty), checked the radiator (it was full) drove around for awhile and checked it. Not a drop. I'll just keep a close eye on it for now. Did not really want to take it to a dealer unless I know what the cause is so I can ensure they will not screw with me. I have till early next year under warranty.
Thanks for the replies.
assume , coolant , dealer , warranty , years
coolant leak johnwoo 3rd gen T4Rs 14 12-02-2019 08:09 PM
rear coolant leak, NOT rear coolant bypass block... delgadog Classic T4Rs 11 06-13-2014 12:16 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
