Originally Posted by kenwilliams0803
Oooh I like this. Wonder if they could take the max axe weight. It's a little heavy on one side because if all of the attachments. It would get it off my floor though.
It's gotta be less than the 25 lb rating per side, I'd just be worried about the mounting screws pulling out. Especially if someone slams the trunk closed.
You could use more than 2 mounts and it might help. Could also do a more secure mount by removing the panel and mounting with machine screws and a fender washer and nut on the back side. I think the screws pulling out of the panel would be the most like way it would fall off.
Also - if you put too much weight on, the door won't want to say open. I'd open the door and put the max axe on top of the open door to see if it will stay open before you try mounting it if that's an issue.
