Old 05-31-2020, 09:55 PM #1
MadeInMaine's Avatar
MadeInMaine MadeInMaine is offline
Real Name: Owen
MadeInMaine will become famous soon enough
Real Name: Owen
front end squeak.... help!
The front end squeak started after I upgraded to ToyTec COs, I did not change UCAs.
It happens on slow little bumps/speed bumps. Probably when I am driving faster, but I can't hear it.
I have attached 2 videos, one from driver and passenger side, of my applying a bit of weight to my C4 bumper.
Please help with any knowledge of the where the squeak is coming from and how to fix it.
Thank you so much
Owen
YouTube
YouTube
2016 Magnetic Gray SR5 premium 4x4
- Toytec Boss lift, C4Fab LoPro w/ Baja light bar and Smitybilt winch, Baja SpyUtil rack, SwitchPro to control my lights, REDARC Tow Pro elite brake controller, VTX rims, KO2 rubber, T9 head unit, 4.56 gear upgrade
- Turtleback Trailer
https://www.toyota-4runner.org/5th-g...ut-surely.html
MadeInMaine is offline   Reply With QuoteReply With Quote
Old 05-31-2020, 10:17 PM #2
spartacus's Avatar
spartacus's Avatar
Can't see the videos they are currently private. Do you have any poly bushings they do tend to squeak.
Old 05-31-2020, 10:25 PM #3
Real Name: Owen
Real Name: Owen
It is public now, you can watch the videos. Thanks for letting me know.
Poly bushings? I didn't replace any when I upgraded the COs, so I would assume not.
But to be honest, I don't know. Sad, sorry.
Old 05-31-2020, 11:30 PM #4
spartacus's Avatar
spartacus's Avatar
That's fairly louder then a squeak. Préassembled coil overs? Sounds to me like the lower control arms or sway bar bushings are binding. Get under there and have someone else jump on the front bumper. you could also recheck the bolt torques and if everything is goodntight then you can also use wd40 water resistant silicone spray safe for rubber. Good luck.
Old 05-31-2020, 11:31 PM #5
Real Name: Owen
Real Name: Owen
That's fairly louder then a squeak. Préassembled coil overs? Sounds to me like the lower control arms or sway bar bushings are binding. Get under there and have someone else jump on the front bumper. you could also recheck the bolt torques and if everything is good night then you can also use wd40 water resistant silicone spray safe for rubber. Good luck.
Preassembled COs, yes
Old 06-01-2020, 08:49 AM #6
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
holy moly that sounds like a goose is stuck in there
I second the above, you're going to have to get under there while someone rocks the truck. something is rubbing on something else. It should be pretty obvious when you can get under there and touch stuff
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
end , front , side , squeak , weight
Constant squeak from the front left FrontRange4Runner 5th gen T4Rs 41 12-26-2020 12:37 PM
Squeak/creak from front end Rwm514 3rd gen T4Rs 3 08-22-2018 05:20 PM
1997 4runner front end squeak. Project_Mutt 3rd gen T4Rs 3 06-18-2014 02:32 PM
Front end squeak? Anybody? adam2562 5th gen T4Rs 11 11-02-2012 08:41 AM
Front End Squeak mecaliman 3rd gen T4Rs 5 05-30-2010 08:28 AM
