2016 Magnetic Gray SR5 premium 4x4
- Toytec Boss lift, C4Fab LoPro w/ Baja light bar and Smitybilt winch, Baja SpyUtil rack, SwitchPro to control my lights, REDARC Tow Pro elite brake controller, VTX rims, KO2 rubber, T9 head unit, 4.56 gear upgrade
- Turtleback Trailer https://www.toyota-4runner.org/5th-g...ut-surely.html
Can't see the videos they are currently private. Do you have any poly bushings they do tend to squeak.
It is public now, you can watch the videos. Thanks for letting me know.
Poly bushings? I didn't replace any when I upgraded the COs, so I would assume not.
But to be honest, I don't know. Sad, sorry.
That's fairly louder then a squeak. Préassembled coil overs? Sounds to me like the lower control arms or sway bar bushings are binding. Get under there and have someone else jump on the front bumper. you could also recheck the bolt torques and if everything is goodntight then you can also use wd40 water resistant silicone spray safe for rubber. Good luck.
That's fairly louder then a squeak. Préassembled coil overs? Sounds to me like the lower control arms or sway bar bushings are binding. Get under there and have someone else jump on the front bumper. you could also recheck the bolt torques and if everything is good night then you can also use wd40 water resistant silicone spray safe for rubber. Good luck.
Preassembled COs, yes
holy moly that sounds like a goose is stuck in there
I second the above, you're going to have to get under there while someone rocks the truck. something is rubbing on something else. It should be pretty obvious when you can get under there and touch stuff
