Old 06-01-2020, 08:41 PM #1
umidkusername umidkusername is offline
umidkusername is on a distinguished road
New 5th Gen Syndrome
How long did your ďbrand new carĒ syndrome last with your 5th Gen? I lasted a little over 4 weeks of washing twice a week, parking at the back of the parking lot, going 1 mph over railroad tracks, etc.
Iím kinda relieved that itís over! Now I wash once a week and park with everyone else. New 5th Gen SyndromeNew 5th Gen Syndrome
umidkusername is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 08:49 PM #2
Fool-on-the-Hill Fool-on-the-Hill is offline
Fool-on-the-Hill is on a distinguished road
I've had mine a week and a half and haven't washed it yet.
The fact that we keep getting afternoon thunderstorms may be a factor though.
Fool-on-the-Hill is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 09:21 PM #3
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot has a spectacular aura about Friggin Idiot has a spectacular aura about Friggin Idiot has a spectacular aura about
Real Name: Luke
Did you know you actually cause more wear to your suspension slowing down over railroad crossings?
Done at slow speed, that's a lot of rocking back and forth. Done at an appropriate speed the suspension doesn't fully articulate over the individual bumps, hence travels less and wears less. You also don't get the side to side motion with each bump, hence no whiplash. You also miss out on the blaring horn and middle finger of the guy behind you.
The only railroad crossings worth slowing down for are:
1) the one that requires you to stop for the train actually crossing your path
2) the ones where you're not crossing at a road way and therefore require 4WD or a Dukes of Hazzard method to cross.
The 4Runner is a more capable vehicle than many of its drivers. Any of the 4Runner suspensions can handle a few bumps of less than 3" at an appropriate speed. If the crossing has bumps more than 3" it's in need of repair and I suggest you contact local law enforcement office or government official to pass along a repair request.
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 09:30 PM #4
m
Definitely donít care about that. The guy behind me can worry about himself and keeping a safe distance.
What is a safe speed since you mention there being a safe speed to go over railroad tracks?
Also, do you get outside of your 4Runner and measure railroad tracks to see if theyíre less or more than 3 inches before going over them?
Old 06-01-2020, 09:50 PM #5
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet is on a distinguished road
Had mine about a week and a half and the front bumper fairing got ripped off in a deep puddle, along with my front license plate.
Bought the black pro one and it went from there.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 09:57 PM #6
You know itís funny you mention that. It seems my TRD Pro takes water pretty hard. I would figure with a standard lift and big tires it wouldnít be so bad but itís actually quite rough!
Old 06-01-2020, 09:57 PM #7
Old 06-01-2020, 10:08 PM #8
SilverFox2020 SilverFox2020 is offline
SilverFox2020 is on a distinguished road
Less then a week after driving mine off the lot, I put some mild trail stripes on her while exploring some forest roads in Tennessee.
SilverFox2020 is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 11:02 PM #9
Real Name: Luke
Real Name: Luke
m
Definitely don’t care about that. The guy behind me can worry about himself and keeping a safe distance.
Also, do you get outside of your 4Runner and measure railroad tracks to see if they’re less or more than 3 inches before going over them?
If you're slowing to 1mph to cross the tracks, you might as well stop on the tracks and measure 3"! (That's what she said!)
I never mentioned safe, I said appropriate. I've crossed railroad tracks at 75mph, and others I've creeped over at 5mph. It's what is appropriate to the conditions, which are often defined by the speed of the idiot in front of you.
WARNING: SCIENCE/NERD ALERT
Simplified, the suspension movement is with the physics of simple harmonic oscillators and interference waves. In this case destructive interference is your goal, the smoothest ride, created by the harmonic return of your spring (suspension) out of phase with the wave of the ground form (railroad crossing). The issue is that the crossing is significantly less than ideal, flat waveform, and is often irregular. So while a speed X might produce a flat waveform at the first several bumps, that same speed might provide constructive interference on the 2nd set of tracks. Hence your desired speed should be the one that produces the flattest waveform, or smallest deflection of your mass (wheel assembly) on your spring (suspension). By reducing to the minimum speed, you're attempting to ride the waveform up and down, actually creating a situation of constructive interference. Which is why the bumps feel much more significant at slower speeds.
Can you do the math on every railroad crossing on your daily commute? Sure. But who has time for stuff like that, and with CommonCore you'd probably lose your job before you found an answer. The best advice, learn the tracks you drive on a regular basis. Approach them at varying speeds and see which provides the smoothest ride. It could be the speed limit, 10 over speed limit, 7mph, 34mph, you won't know until you try. While the unsprung mass changes very slowly (weight of wheel assembly) the weight of the vehicle may change on a daily basis, fuel level, passengers, cargo, gear, etc. That determines the amount of force already on the springs, and hence their ability to absorb more force along the waveform.
Though Luke & Bo preferred the physics of ballistic arcs, thereby negating the interference from the crossing, as demonstrated by acceleration over an inclined plane.
Old 06-01-2020, 11:05 PM #10
jhguth jhguth is offline
jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light
I had mine offroad when I still had temporary tags
Its scratched to hell now from trails and it's great because I don't have to worry about how it looks
jhguth is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 11:12 PM #11
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all
Took it to an offroad class the following week after I got it.
I think the toughest part to get over was pinstriping. Ok with it now but I detail it when I can.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/GS59-705 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor and MORRFlate kit
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 11:19 PM #12
SmithRunner20's Avatar
SmithRunner20 SmithRunner20 is offline
SmithRunner20 is on a distinguished road
Going on 2 months here New 5th Gen SyndromeNew 5th Gen Syndrome
2020 TRD Off-Road Premium
Barcelona Red Metallic
Barcelona Red
SmithRunner20 is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 12:06 AM #13
3rdCoast Runner's Avatar
3rdCoast Runner 3rdCoast Runner is offline
3rdCoast Runner is on a distinguished road
From the dealership to the ranch.
Got the west Texas pinstripes from the mesquite and cedar within days. I do wash and wax it once a month on average. I still like it after 4 years and 8 months.
New 5th Gen Syndrome-c9ca4474-d5ac-43e8-9ca6-577fcdc11e54-jpg  New 5th Gen Syndrome-66cee3cc-37e8-45ed-9306-90a5129998b0-jpg
3rdCoast Runner is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 12:15 AM #14
Ry'sRunner Ry'sRunner is offline
Real Name: Ryan
Ry'sRunner is on a distinguished road
Real Name: Ryan
Made it three months before getting some pinstripes from an oak branch on a narrow trail. Followed by the first real wash I've given it. Hopefully the next time won't hurt so much!
Ry'sRunner is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 12:39 AM #15
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 will become famous soon enough Ryance39 will become famous soon enough
Real Name: Ryan
Put 40 miles or so worth of dirt roads on it the day after I bought it. Nothing serious but some solid dirt driving and articulation the day after buying.
Iíve never understood buying a car capable of something specific, and not using it for that. I get not wanting to inflict damage but most forest roads are quite a bit more rough than some railroad tracks.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
2020 Super White ORP
2013 BMW X3 F25
Ryance39 is offline   Reply With QuoteReply With Quote
5th , gen , parking , syndrome , week
Touchy Brake Syndrome madbomber08 3rd gen T4Rs 32 06-21-2016 01:40 AM
Saggy Seat Syndrome CanukRunner 3rd gen T4Rs 12 01-08-2016 04:49 AM
The dreded dead clock syndrome 4SKIN 3rd gen T4Rs 13 05-16-2015 08:35 PM
Hydrolic Clutch Syndrome blueseasons 3rd gen T4Rs 7 12-03-2013 10:13 PM
The short wife syndrome. Nunyabiz 3rd gen T4Rs 32 04-29-2011 05:07 PM
