Old 06-02-2020, 08:20 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Dashcam install: Mounting + wire+trim advice
Just got a new 2020 4Runner. Wondering two things: Mounting location and finishing my wiring.
Pictures here:
4Runner Dashcam Install - Album on Imgur
The front windshield mirror area has the big black box which I believe is part of Toyota's safety system. Then there is also the black dots which I think are the antenna, and could also affect mounting?
Wondering if I should mount it on the left/drivers side, where it seems like there is a bit of a cutout it could fit in and be mostly behind the mirror, or if I should go to the right of the black box "out in the open" on the passenger side? Any thoughts on one location vs another?
I've run most of my wires behind the headliner/weatherstripping, but it's the plastic trim I am having most trouble with. I can use the pry tool to pry it open a bit but I definitely don't want to pry too hard and risk cracking/breaking the trim or one of the clips or whatever is holding it in place. I'm also most concerns with the A-pillar and the other trim beside the rear seats, which hold the airbags. Any advice for running the wires behind these trim pieces? One of the wires is thinner than the other.
Thanks!
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 08:47 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
New Dashcam Install - Blackvue DR900S-2CH
BlackVue Dash Camera Installation (DR650GW-2CH)
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 09:32 PM #3
speedrr411's Avatar
speedrr411 speedrr411 is offline
Real Name: Thomas Reiter
speedrr411 will become famous soon enough
speedrr411's Avatar
I have a 2020 also and I mounted my front camera on the passenger side of the rear view mirror. There is a screw under the air bag badge that you have to remove in order to get behind the trim.
speedrr411 is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 10:14 PM #4
keph13 keph13 is offline
keph13 is on a distinguished road
I mounted a small one to the mirror support (although my 2010 doesn't have that big box). Then, I ran the wires above the headliner and down the passenger A pillar and added (or found? I can't remember) a small hole into the glove box, and pulled power from the 12v plug in there. Works great!
As others have mentioned, there's a screw on the A pillar. The headliner can be gently pulled down from above the door if you pull off the weather strip - you might have to disconnect the grab handle, I can't remember.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 11:10 PM #5
Just to confirm, the grab handle on the A pillar has two covers and screws there. Those aren't just holding the grab handle, but actually the whole A pillar trim? I didn't see any other spots for a screw.
Also the pillar/airbag next to the rear seats did not have any sort of screw/cover/etc. to remove it or deal with it...
Old 06-02-2020, 11:20 PM #6
Hmm, I'd have to look. Usually I give a good tug, and if it doesn't pop off I start looking for screws.
Old 06-03-2020, 03:03 AM #7
Whippersnapper02's Avatar
Whippersnapper02 Whippersnapper02 is online now
Blendmount with the wiring running up the OEM wire track on the windshield. I ran it down the driver side A pillar since the fuse box is there. No problems pulling the headliner down slightly and pushing the wiring it.
Dashcam install: Mounting + wire+trim advice-1a159bc3-132b-4c95-80a3-9128bb458d5c-jpeg
Whippersnapper02 is online now   Reply With QuoteReply With Quote
Old 06-03-2020, 11:22 AM #8
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
I'm trying to get my cables down the passenger A pillar side, and need to remove the vent to thread it the last 24"...
To get the vent out, apparently you have to remove the lower half of the dash / glovebox door because the vent is trapped behind the lower section of the dash.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 11:04 PM #9
A-P-9 A-P-9 is offline
A-P-9 is on a distinguished road
Haven't gotten around to doing it myself, but when I do I certainly won't be using the add-a-circuit kit.
1996 Chevrolet Impala SS
2000 Ford Explorer XLT 4WD (4.0L OHV)
2018 Toyota 4Runner TRD Off-Road Premium
A-P-9 is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 12:00 PM #10
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Go with the passenger side.
I have Roav C2 Pro. It takes about 5 min to install or take out.
The mount is a suction cup and power is USB, which I didn't like the USB at first but it turns out it's not bad. In the 2011 I had it on the passenger side tucked behind the mirror. Then stuffed the wire under the Windshield trim -> A-Pillar -> Weather stripping -> Kick panel -> dashboard -> Console to outlet.
For the most part I never knew it was there.
The 2020 has the goiter over there I tried the driver's side, but found it annoying. So I went back to the passenger side with the same routing, except i plumbed it a USB port on the back of the rear console.
Routing the wires just takes a plastic tool. Don't use metal. Just tuck the wires under the panels, they have enough space that it's very doable.
itr1275 is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 06:07 AM #11
Stephenwreck Stephenwreck is offline
Stephenwreck is on a distinguished road
I just purchased a 2020 Limited 4x4 and I have an old dash cam already with a USB power connection. I was hoping to find a dongle that could hookup to the rear view mirror power, but the new TSS-p has changed the wiring. I did find this wiring diagram for the Toyota dash cam that may help with mounting and wiring.
Dashcam install: Mounting + wire+trim advice-e066b79f-9cae-4aa5-938a-0297c8b38ad7-jpg
Stephenwreck is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 11:32 AM #12
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
I did mine, mounted using double sided tape to glass on camera pad, GPS sensor on top right of windshield also had it. I used terminal splicer blocks and fished wired through headliner, down A pillar and into side of fusebox. Added wire insulation to prevent abrading.
Grug556 is offline   Reply With QuoteReply With Quote
black , mounting , pry , trim , wires
New Dashcam Install - Blackvue DR900S-2CH Naylor99 5th gen T4Rs 121 08-10-2023 07:25 PM
Help me cleanly install my various devices plz! Dashcam, radar detector, car charger khalid74120021 5th gen T4Rs 0 05-25-2018 01:51 PM
DashCAM Review/Install: Compustar Dash Cm3200 gshadow325 4th Gen T4Rs 9 10-23-2015 05:25 PM
Dashcam install ryoko 4th Gen T4Rs 3 07-25-2014 12:41 PM
Trim panel mounting clips GrantK 5th gen T4Rs 0 04-08-2013 06:02 PM
