Old 06-03-2020, 09:13 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Do I need to reposition my dashcam?
Just installed the dashcam on my 2020... was mostly concerned with the black dots and the safety sense black box, but it wasn't until after I installed that I realized the rearview mirror has a sensor (light sensor for auto-dimming I think?) on the front. It's hard to judge if it is in fact below the dashcam or not, if it will affect the dashcam or not?
Anyone have any ideas how the front one works? I thought auto-dimming was only on headlights behind you, anyway...
2 photos of the dashcam+mirror
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 11:39 PM #2
am0767 am0767 is offline
Real Name: Albert M
am0767 is on a distinguished road
Real Name: Albert M
i put one on my 2020. ended up on the left side and it does not affect the mirror dimming feature. as it is, i have noticed that the mirror does not dim itself too often because the factory tint on the back roll down window is so dark that the headlights behind me are not bright enough to cause the mirror to dim.
am0767 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 11:46 PM #3
That white square on the front of the mirror is in fact ONLY for the auto-dimming, right? Nothing to do with safety/high beam feature?
At least I can wait and see if I find bright headlights an issue or not, so long as that's the ONLY feature it *might* be affecting...
Old 06-04-2020, 12:38 AM #4
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
The auto dimming mirror uses two sensors to function.
In layman's terms, the front sensor determines if it is dark outside.
If it is dark outside, then the rear facing sensor will dim the mirror(s) when light (like a following headlight) hits the sensor.
If the front sensor thinks it is light outside, then the rear sensor does nothing - but - if something like a hangtag (or a dashcam) is in the way of the front sensor, then the mirror thinks it is dark outside and any light (like daylight) hitting the rear facing sensor will dim the mirror. This often makes people think that the problem of a dim mirror is caused by tinted windows.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 12:45 AM #5
I suppose a good way to check this, if my dashcam is interfering, is to go in the shade and turn the autodimming on+off? Daytime in the shade, should be basically identical yeah?
Old 06-04-2020, 09:59 AM #6
cb1111's Avatar
cb1111's Avatar
Best way I've found is to put my finger over the front sensor in bright daylight to see if the mirror dims - then shine a light on the sensor to see if it lightens up.
I figured this out a while ago when I thought the dealer had broken my mirror after a service. I was sitting in the car getting ready to call them and pulled off the hangtag they put on the mirror during service to get the phone number - and the mirror fixed itself....
Old 06-04-2020, 05:13 PM #7
frasc frasc is offline
frasc is on a distinguished road
I had that exact issue and posted a thread on here about it. I had to move my camera to the right of the mirror and below the lane departure camera to keep the mirror from dimming all the time
frasc is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 11:49 AM #8
Real Name: Albert M
Real Name: Albert M
im not too sure what its for but i have not notices anything different. now im gonna have to do some more research and find out whats that for.
auto-dimming , dashcam , front , installed , sensor
My new dashcam scanny 5th gen T4Rs 41 06-01-2018 05:38 PM
What dashcam do you use? T4RCanada 4th Gen T4Rs 6 05-20-2015 11:06 AM
Dashcam install ryoko 4th Gen T4Rs 3 07-25-2014 12:41 PM
Which Dashcam To Buy? stevec5000 Off Topic 22 04-13-2014 11:20 AM
