Old 06-04-2020, 01:54 PM #1
bokehshooter bokehshooter is offline
bokehshooter is on a distinguished road
SD Offroad SwitchPro 9100 Mount Tray for 2020
Hey all! If you have a 2020 4Runner and have been looking for a mount tray solution for your Switch Pro 9100, SD Offroad MT has come up with a great solution. I needed one myself and assisted them with some measurements to help get one made, and am very happy with the final product. Just wanted to share some install photos of the new Tray.
To purchase one, you can contact SD_Offroad on the forums here or via IG, @sdoffroadmt
New Mount Tray
The reason for a new one is the 2020's have the relay box in the spot that most Trays would normally fit right into
There are 2 bolts holding in the relay box. Remove the relay box and remove the bracket as you will need to make a cut or 2. You will need to use a Dremel to cut off the little hook on the right side. The left side, it is up to you to decide if you want to cut and shave down. I will explain in a min.
The reason the left side is optional is you can have that portion of the bracket between the mount tray and the fender OR you can have it insert between the tray and the bolt.
Photo below is how it will look if the bracket is behind the mount. A friend of mine did it this way and seems solid.
I opted to have the bracket between the mount and the bolt like below and I felt it seemed more flush and solid to do it that way.
In order to do so, you will need to cut and shave down the left portion of the bracket so the SP can fit properly onto the mount.
If you want to run a fuse block, the terminal block will be mounted to the rear of the mount.
I am not running a fuse block (only the terminal block), so this is how my final install looks.
There is also a support bracket on the left side of the mount that attaches to the fender which helps keep it solid.
Let me know if anyone has questions but me and my 2 other buddies are very happy with the way this tray turned out!
bokehshooter is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 05:38 PM #2
SpaceBanana's Avatar
SpaceBanana SpaceBanana is offline
SpaceBanana is on a distinguished road
New Mount Tray
Great write up! Im about to install mine today. Which connections did you use for the switch? Did you use the relay box outside or inside the cabin.
SpaceBanana is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 09:29 PM #3
I routed then to the fuse box inside. Used the Tail and IGN#2. Pink is just capped off for now.
Old 07-26-2020, 12:37 PM #4
SD Offroad SD Offroad is offline
Real Name: Derek
SD Offroad is on a distinguished road
Real Name: Derek
Thank you for this post, really helps people understand what needs to be done to the bracket.... which, is not much really! Thanks again!
SD Offroad is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 07:20 PM #5
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
Awesome, thank you!
I have all the parts (I think) ready to install. But I have a question about how you attached the SwitchPro module wires to the terminal block. I'm new to automotive wiring, but not new to electrical (I build guitar amps). Are you just wrapping the bare wire around the terminal screw posts? Or have you attached some sort of spade connector? Does it matter? I see heat shrink and colored tubes of some sort that you've used. My SwitchPro came with a bunch of these blue/yellow connectors. I'm not sure what they are and how/why they're used. Any tips?
Thanks!
FourT6and2 is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 11:03 PM #6
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Originally Posted by FourT6and2 View Post
Awesome, thank you!
Thanks!
You want to use ring connectors (like this - right gauge) which you crimp onto the end of the wire then use a heat gun to shrink the tubing, which helps keep the whole thing somewhat water tight. Then the rings attach to the screws.
Different mounting plate (pre-2020) but maybe this gives you an idea ... what mine looks like (although I have all 8 slots filled right now).
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 12:54 PM #7
Birchwhitehd Birchwhitehd is offline
Birchwhitehd is on a distinguished road
Does anyone have a current email to contact Derek about
Getting this mount for my 2021 4 runner…..???
Birchwhitehd is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 02:03 AM #8
Ridemyt4r Ridemyt4r is offline
Ridemyt4r is on a distinguished road
How to order bracket
Hi SD Offroad,
New member here. Can you please provide instructions on how to order this mounting bracket if I don’t use Instagram? I would like to purchase one asap.
Thanks!
Ridemyt4r is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 07:45 PM #9
Real Name: Derek
Real Name: Derek
Shoot me an email at sdoffroad@ hotmail
Originally Posted by Ridemyt4r View Post
Hi SD Offroad,
Thanks!
block , bracket , cut , mount , tray
Switch Pro 9100 on 2020 SpaceBanana 5th gen T4Rs 22 09-11-2022 10:36 PM
2020 spod/stec/switchpro/relay box position thegreatchangsby 5th gen T4Rs 22 06-05-2021 01:31 PM
FS: 5th Gen OEM Sliding Tray Organizer/Carpet Mat/License Plate Mount - OKC/DFW Jemplyr77 For Sale: T4R Items 4 05-26-2019 01:31 PM
Hitch-mount caro tray TT4RLtdV8 4th Gen T4Rs 4 10-31-2017 02:50 PM
CA:Pelfrey fuse tray and Pro Clip mount DEMIK For Sale: T4R Items 1 09-07-2017 11:27 AM
