Originally Posted by rheosibal
So long the plywood has supports towards the middle of the cargo area, then you'll be okay. The yellow dot areas CAN support weight, but only if the weight is evenly distributed.
If you plan on using plywood to rest only on those yellow dot areas (without supports), then you'll definitely have issues with the plywood bowing and/or causing damage
As for the blue dot areas, it is also fine to have support beams without pushing through the panel.
There are plenty of folks who have the idea you've mentioned. I assume your intent is to have front support beams on the blue areas only, and no beams in the rear (just resting on the wheel wells). If that's the case, the amount of weight that you intend to put on this shelf will be the biggest hinderance as the plywood will bow.
Hmm, good point about some type of middle support. I suppose I could add one, though it would "Separate" the left+Right side when sleeping (maybe a good thing! ha!) but as a result also makes dealing with a mattress more difficult - can't just be one larger inflatable mattress...
I guess another option is to actually provide support via the roof, but I imagine those anchors are even less ideal for supporting decent weight?
Obviously tons of people with diff cars with sleeping platforms and drawer systems, but I'm not finding nearly as much options for base sleeping + shelf above. Maybe there is a reason...
