Old 06-05-2020, 02:42 PM #1
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
TPMS doesn't show spare on a 2020 TRD Pro
My 2020 TRD Pro does not show tire pressure on the spare. Should it?
It seems to show the spare in the owners manual.
I tried reregistering the sensors again but still does not show the spare.
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 04:27 PM #2
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
You didn't state it so I thought I would ask, did you crawl under there and look to see if your spare is even equipped with TPMS?
I would guess to say that it isn't unheard of that a dealer may have needed and swapped out a spare then replaced.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 04:53 PM #3
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
What's interesting is that my 2020 TRD Pro does not either (and just assumed it did not have a TPMS reading for the spare tire).
I wonder if it's an artifact of the change over to the different tires and wheels as these vehicles come into port. They actually left an o-ring out of the TPMS sensor of one of the front tires that resulted in a persistent slow leak from the day I got the vehicle delivered, so my confidence is not high .
I plan on upgrading tires pretty soon including the spare (since the stupid highway tire is there), so will see how that plays out then.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 05:04 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
As I remember from previous threads about TPMS, the Limited is the only trim with a TPMS in the spare. It's because other trims have a steel rim for the spare which the TPMS sensor won't fit; while the Limiteds have a spare rim that matches the others. However, this may differ depending on what year we're talking about. I still think it's pretty lame that you need a computer and Techstream to even read the TPMS values that do exist.
Old 06-05-2020, 05:08 PM #5
It looks like I need to lower the spare to see the top side of the wheel to see the valve stem.
Old 06-05-2020, 05:13 PM #6
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Mine doesn't either. I'm assuming it's not supposed to. No other vehicle I've had since TPMS became a "thing" has either.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 05:41 PM #7
On the 2020 you can display all the tire pressures right on your information screen. Huge improvement from the previous ones (and great when running offroad).
Actually helped me realize I had a tire going down with a nail on it during a drive to Salt Lake for a ski trip earlier this year. Literally watched the pressure coming down 1 PSI or so an hour.
Old 06-05-2020, 09:49 PM #8
Seems like spare tire pressure would be a handy thing to know since it's hard to get to.
I'm hoping I can add a sensor to the spare.
Old 06-05-2020, 10:30 PM #9
flyrv9's Avatar
flyrv9's Avatar
AZ Craig - thanks, good to know. On our 2013 all you get is a light when a tire is low; and it doesn't tell you which one. It did come on once when my wife was out. Turned out to be a nail; so I put the spare on. Former Tempe resident here!
Old 06-06-2020, 03:24 PM #10
jrandom's Avatar
jrandom's Avatar
You can buy sensors. They are about $50 each give or take, add the fifth in techstream (my 2013 supports five) I have know idea if the sensors work with steelies.
I bought my last set of sensors on Amazon of $33 each, genuine Denso 550-0103 TPMS 315mzh Sensor (Pacific) Cross check for compatibility, I am pretty sure it is still the same sensor, I do now the actual toyota part number has changed ten or so times.
2013 TE w/ KDSS Nav
Old 06-20-2020, 07:55 PM #11
I can conform that adding a tpms sensor to the spare of a 2020 TRD Pro does not work. It seems to only confuse the system and none of the sensors register.
2007 FJ
pro , show , spare , tpms , trd
2020 4R TPMS Sensors - Part Number niadh0 5th gen T4Rs 5 11-03-2019 08:21 PM
Can't Lower Spare Tire-Tool Doesn't Line Up JMat 3rd gen T4Rs 15 06-24-2019 09:55 PM
TPMS (4th gen) - flat spare tire, no TPMS light pipspeak Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-17-2018 11:31 PM
SR5 Spare, no TPMS, right? blackie2 5th gen T4Rs 12 02-27-2017 06:11 PM
Hmm, buy tires/wheels with no TPMS, and check pressure light doesn't come on! LI4runner 5th gen T4Rs 24 02-18-2013 07:41 PM
