Old 06-06-2020, 02:10 AM #1
SICKwidIT SICKwidIT is offline
SICKwidIT is on a distinguished road
Question Bought Wheels. Now stuck between Tires & Suspension
After spending countless of hours researching, I'm ready to hear from your experiences. With your experience/research, what can you recommend me?
Nothing hardcore. Just So Cal trails & snow but more miles on city/highway as its my daily.
I bought SCS BR6 wheels yesterday. -10 offset.
Tires, torn between 2 choices:
(less noise? thread wear? cost?)
  • Falken Wildpeak A/T3W
  • Toyo Open Country AT3
Wanted 275s at first, but since I'm wanting a lift, I'm considering 285s as well.
Suspension, torn between 2 choices:
Coming from a 01 QX4, I enjoy my 2015 SR5 Prem 4WD stock ride, but I want to improve it.
  • Eibach Stage 1
  • Eibach Stage 1 w/ UCA
  • ICON Stage 2 (buy once, cry once?)
Hopefully I can get some input. Thanks!
15 SR5 4WD
SICKwidIT is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 08:43 AM #2
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I bought the falkens in 285 a month ago. Biggest mistake I have ever made. They are coming off and I'm getting another set of BFG all terrains. Probably will be my 10th set of them? I have heard good things about the toyo's but then again I heard good things about the Falken's too but after it still shaking after 4 trips to the balancer I'm done.
Suspension wise I can't say enough good things about the Eibach springs. I ran bilsteins instead of their shocks but they are quite similar and being in the industry for a while I really wouldn't be surprised if they were identical. Bilstein does make a lot of shocks for Eibach packages. My thought process was it's easier to get a replacement 5100 pretty much anywhere than it is an Eibach shock. I worked for a good sized eibach retailer for several years and they always seemed to have availability issues with anything that included a damper. Because they didn't actually manufacture them.
I would definitely suggest upper control arms too. You won't have enough caster without them and if you're picky you will definitely notice it wandering a bit on the highway. I went with JBA primarily because I liked the fact it uses a readily available bolt-in GM style ball joint. So you can change a ball joint down the road without messing up your alignment. And even if JBA were somehow to go out of business you can always get a replacement ball joint.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 09:10 AM #3
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
TireRack did review on LT-C BFG KO2 vs. other P-metric ATs: https://www.tirerack.com/tires/tests...y.jsp?ttid=249
Surprisingly, KO2 are pretty quiet, pretty decent in rain, and NOT the worst fuel economy offender.
If you plan on off-roading, then KO2 should be at the top of your list.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 11:00 AM #4
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Yokohamas geolanders M/T's are on my list along with the -38 offset BR6 wheels. I have a Old man Emu 3 inch lift and dirt King UCA's inound whenever Dirt king is back in stock.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 12:36 PM #5
Anyone else out there with Tire or Suspension feedback?
So far, i'm thinking of going with the Eibach kit. The Icon Stage 2 kit might be overkill for a daily driver and moderate trails in So Cal.
15 SR5 4WD
Old 06-08-2020, 03:04 PM #6
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
I have the Falkens, and have been impressed with them so far. No issues. I have a Dobinsons kit. It makes my truck feel more solid and handle better on the highway. It wasn't cheap, but it was worth it.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 03:16 PM #7
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
For what youre doing, I'd say get the Eibach kit and use the saved money on skids or sliders (or towards your tires). I know you want to buy once cry once but id recommend trying the Eibachs first, figure out what you like, then advance your offroading skills, and then buy a custom-valved 2.5 body shocked based on your preferences and future added weight of bumpers (probably still overkill for this platform).
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
bought , choices , experience , stage , wheels
WTB wheels/tires and suspension for my 18 TRD OR TrvMac For Sale: Suspension/Wheels/Tires 3 12-01-2017 09:44 PM
Wheels, Tires, Suspension...Oh My!!! Jeffrey_VB 4th Gen T4Rs 0 07-02-2014 12:49 AM
FS: Tires, Wheels and Suspension mysticz Classifieds - buy & sell (no commercial ads please) 8 06-06-2010 10:44 AM
Bought 18" Limited Wheels & Tires!!!! OUTRNNR Engines / Suspension / Wheels / Tires / Audio / Accessories 40 03-02-2008 12:03 PM
