06-07-2020, 12:24 AM
Accessory audio through OEM speakers
I have two ham radios that I would like to run the audio for through the OEM speakers and have it cut off the radio, etc. the same as a phone call through Bluetooth but still retain that ability and have a phone call take priority..
Any ideas..?
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
06-07-2020, 01:09 AM
Real Name: Bob
Real Name: Bob
Any ideas..?
My 2011 SR5 had a ⅛” jack next to the 12v plug below the AC controls and if memory serves, it did what you wanted it to, however audio from the ham unit only came out of the left dash speaker. Think my 18 ORP has the same jack in the glove box but I haven’t tried it that way
I’ll putz tomorrow with it
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
06-07-2020, 01:49 PM
Real Name: BobH
Real Name: BobH
The jack works. I used it for my CB for a while. It appeared to play through all speakers if you use a stereo 3 pin plug. I left the plug in all the time, plugged it in when needed and selected external input on the radio.
06-08-2020, 10:02 AM
I wired up a small speaker in the kick panel and placed a small amp under the seat to boost the line audio from my ham radio. It can be louder than my car stereo if I want it to. I did a lot of searching and the only setups out there were hundreds of dollars to do what you want them to do. My option cost me approximately $20.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
06-08-2020, 10:06 AM
What amp did you use..?
