Old 03-26-2021, 11:02 AM #76
danyo492's Avatar
danyo492 danyo492 is offline
danyo492 is on a distinguished road
danyo492's Avatar
So I have a Prinsu full rack, non drill, showing up next week. I think what I am going to do is use the Permatex Ultra Black + the rubber chemical washers from McMaster Carr and I think I will be good to go. I'm going to use the washers around the white plastic pieces on the roof and where the top screw/bolt attaches to the bracket.
If anyone needs the P/N for the McMaster Carr washers, see below. These are the "weather resistant" red washers.
P/N 99604A123
danyo492 is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 09:45 PM #77
Crob42 Crob42 is offline
Crob42 will become famous soon enough
Prinsu no drill No silicone option. Use a gasket under a custom spacer, and two o rings on the bolt shank to stop water intrusion down the threads. All McMaster Carr stuff.
1/16 thick x 0.75 EPDM gasket
0.75 wide x 1.00 high Delrin spacer. Cut to 4.25 long
Drilled thru holes 35/64 inch diameter
1/8 buna o rings -203 size
Non Drill roof rack (no silicone)-8e5ca3ad-ef3b-46e0-bdd8-726189416b2d-jpeg  Non Drill roof rack (no silicone)-79fdf9d3-251c-40c5-8349-52c1024222c0-jpeg  Non Drill roof rack (no silicone)-fbeb0797-d4d8-4ad8-89d2-dfb4e1408b15-jpeg
Crob42 is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 11:30 PM #78
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
This is great! What did you search for to find the derlin sheet? Also are the prinsu spacers 1” tall? I can’t get to mine to measure, but I love this idea.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 12:26 AM #79
The delrin comes in .75 x 1.0 part number 8662K52, you pick the length. Had to sand the sealing side to take out the grooves.
The prinsu spacers are 1.0 x .75 OD X .50 ID.
Standard 1/8 o rings ID of .296 fit great on the .308 bolt shank from prinsu, but are too thick (0.574) for the .5 ID of the prinsu spacer, so one needs a slightly larger bore diameter. Hence the 35/64 drill at .547 dia. This is a good amount of o ring compression but not too much that it can’t be assembled. One would be fine but you get a pack of 50 so double up.
Used a 1/16 epdm sheet for the bottom. PN 8990K71
Old 05-24-2021, 03:58 PM #80
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
If I understand correctly, you put the prinsu spacers inside the delrin block? I'm thinking of taking your idea and applying to my UpTopOverland rack when I get it, looks clean!
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 04:18 PM #81
Naw. Threw out the prinsu spacers. Just referenced them to confirm the heigh needed was 1.0 inch. The pics I posted are all that I used. So the delrin spacer has the 35/64 thru hole that the OD of the o ring seals against. The ID of the o ring is on the bolt shank.
Old 07-20-2021, 10:27 PM #82
ssyota4runner's Avatar
ssyota4runner ssyota4runner is offline
ssyota4runner is on a distinguished road
Lock washers no longer needed on Prinsu no drill roof rack
So I just received my Prinsu No Drill Roof Rack. All the lock washers were not in the bag. I’ve emailed the dealer and I am being told that those are no longer needed. Anyone else heard of this?
Thanks
Steve
ssyota4runner is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 07:00 PM #83
Thanks
Steve
Problem solved
Old 10-18-2021, 12:50 PM #84
WildSockets WildSockets is offline
WildSockets will become famous soon enough
That is great. I’m completely going this route.
I’m still waiting for my 4Runner and am just wondering if you can recall how far apart the mounting holes are center to center? I’d like to pre make these so it’s all ready to go when I get my 4Runner in a month.
WildSockets is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 08:31 PM #85
Sorry. I didn’t save my measurements. I didn’t take the rails off first though. You can pop off the plastic covers easily and measure the bolt head spacing. It’s easy if you grab a couple sockets of similar diameter and put them on the heads. Easier to measure the edge of two cylinders than guess at the hex center or deal with two hex heads edges that are not aligned.
I did the same spacing for all but measured all 4 locations first to note consistency.
If I were to do this again I’d make my spacers 4.125. Otherwise no complaints so far. Also, the delrin is easy to drill but you must have a good clamp and drill press or equivalent. Drills in plastic want to grab, so prepare for that.
Old 10-18-2021, 11:28 PM #86
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
Not as cheap as DIY but for $45 you can get the SSO delrin spacers with butyl rubber tape. I have had the SSO rack installed with these spacers for 6+ months with zero leaks throughout the many many crazy rain storms we've had this year. Very happy they started offering these:
Roof Rack Spacers and Butyl Tape | Southern Style OffRoad
Sent from my Pixel 5 using Tapatalk
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 04:35 PM #87
No problems. I’ll wait until I get the runner to measure.
Thanks for the advice.
Old 10-19-2021, 04:37 PM #88
I already got all the supplies from McMaster-Carr, but this is good to know. I would’ve gone this route if I knew of this earlier. Thank you.
Old 10-19-2021, 08:54 PM #89
What’s the height of the spacers? 1”?
Old 10-20-2021, 01:42 PM #90
smeerun's Avatar
smeerun's Avatar
No prob! How much was the total parts cost from McMaster? I'm betting around $30?
Just went out and checked, they are exactly 1" in height.
drill , rack , roof , silicone
Baja or Prinsu No drill roof rack Mvrocky 5th gen T4Rs 13 12-09-2018 02:08 AM
review of no drill full length roof rack options aj1978 5th gen T4Rs 13 07-16-2018 03:39 PM
Drill bit recommendation to drill out and tap 8mm skid plate bolts to 10mm 07V8 4th Gen T4Rs 10 01-12-2017 11:20 PM
Can I drill into this part of the roof rack? EricHartley 3rd gen T4Rs 10 06-03-2014 12:28 AM
