Originally Posted by honda250xtitan
4th and 3rd gen guys have. you are going to want to make them so the tire is moved forward for more clearance. if you think your cobbled together LCA's are =to a long travel kit from someone like Dirt King or Total Chaos well more power to you lol.
dont forget to also do uppers. and build in caster.
Haha thanks 👍 former high pressure power plant pipe welder. I can weld better than dirt king can. I'm going to build my own with math and geometry, supplied plate dimensions. Uppers are affordable lowers are retarded $. Would still like a set because I'm a cobbler 😂 and I'll have fun.. already on 2" wheel spacers, 33s, 3" lift. Body mount chop was simple and have the clearance already. Uppers will have the castor correction and geometry will be factory.
