Old 12-06-2020, 02:53 AM #61
onaquest's Avatar
onaquest onaquest is offline
onaquest is on a distinguished road
onaquest's Avatar
Originally Posted by Gonecamping View Post
This is why I made my own rack
looks good! I like the Greenlane Offroad style gutter blocks.
onaquest is offline   Reply With QuoteReply With Quote
Old 12-06-2020, 11:37 AM #62
otter7's Avatar
otter7 otter7 is offline
otter7 is on a distinguished road
otter7's Avatar
I just installed my Prinsu full length no drill yesterday. I used silicone underneath the 8 supplied black round spacers and am hoping that is enough. I am thinking of pouring water on it to test and see later today. My question is the front mounts are secured by 3M tap that you have to cut away the weather stripping to place. Has anyone had any issues with this? Seems like now that the weather stripping is cut and there is no continuous seal, water is going to get in and not drain properly. Not sure how everyone else's Prinsu racks have held up.
Bruce the 2020 Super White TRD ORP
IG: @bruce_the_4runner
Suspension: Bilstein 6112/5160. Wheels: Method 305-NV Bronze. Tires: BFGoodrich K02 285/70R/17. Pro Grille. Plastidip black emblems and valances. Fog light Bezel.
otter7 is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 11:59 AM #63
Gonecamping's Avatar
Gonecamping Gonecamping is offline
Gonecamping will become famous soon enough
Originally Posted by sn_85 View Post
I'd be curious where you got that rubber gasket.
It's a high temperature silicone rubber sheet I cut to fit (actually had it laser cut).
McMaster-Carr has a bunch of different options (thickness, shore, shapes, color, etc.).
McMaster-Carr
Gonecamping is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 12:13 PM #64
uh0h50 uh0h50 is offline
uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about
On the whole rack or sealing/mounting feet?
I basically looked at all the systems available and blended a bunch of them (for the rack and mounting system).
It’s not done yet, still have to make the faring and get some stuff powder coated but it’s close!
The whole rack. Those spacers look legit.
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
uh0h50 is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 12:50 PM #65
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
This is exactly how I'll be doing my rack next year. I have the RA rack, but I'm still uncomfortable with the mounts even though they seem pretty solid (it's still essentially a cup so if any moisture gets into the spacer, it just sits there which I'm not comfortable with). To be 110% sure about leaks, I want to get aluminum spacers fabbed up.
Would you be willing to share the dimensions/measurements by chance? I found a fabrication shop, but wasn't planning on getting aluminum blocks fabbed up until the spring.
Thanks!!
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 02:50 PM #66
Thanks!!
As of right now I am not going to share dimensions. Couple reasons...
1) I want to finish the rack and use it for a while (and test water intrusion)
2) I used greenlane offroads idea they termed "gutterblock"
Its 100 percent my own measurements and made to my own CAD models, but still their original design idea.
I'll share some photos when the rack is finished!
Old 12-07-2020, 04:11 PM #67
Gotcha. Greenlane is where I got the idea from as well. Unfortunately they don't sell just the spacers.
That's cool, I'll let the fabrication guy figure it out.
On either side of the silicone sheet, it might be advisable to slap a bit of butyl rubber on either side to really make things stick. I'd also dab a bit on top of the heads for the bolts that are holding the spacer.
Old 12-07-2020, 04:12 PM #68
Chevrolegs Chevrolegs is offline
Chevrolegs is on a distinguished road
For those with the prinsu rack.. Did anyone try installing the front mount underneath the weather strip instead of cutting it? Possible ?
Chevrolegs is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 04:40 PM #69
Weird. I didn't have to cut the weather strip at all for my prinsu install when I had it.
Old 12-15-2020, 08:03 PM #70
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
I feel like my research keeps going in circles.
Do you guys think the Sherpa Crestone or the Greenlane Offroad rack is "better"?
They both went with novel approaches to the mounting, though greenlane still uses silicone. Sherpa includes more crossbars.
Otherwise they sorta seem so similar... and I haven't seen either in person.
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 09:25 PM #71
NotaTRD's Avatar
NotaTRD NotaTRD is offline
NotaTRD will become famous soon enough NotaTRD will become famous soon enough
NotaTRD's Avatar
Unless someone here has experience with both racks, it’s going to be hard to say one way or the other. What I can say is that, so far, I do really like my Crestone and would purchase again if I had to do it over.
2017 SW SR5
NotaTRD is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 11:52 AM #72
aaron_clt aaron_clt is offline
aaron_clt is on a distinguished road
looks like sherpa does sell their mounting feet that come with the rubber inserts, wonder if these would work with some other racks
Adjustable Leveling Mounts — Sherpa Equipment Company
Mounting Feet — Sherpa Equipment Company (optional include rubber)
Bonded Washers — Sherpa Equipment Company
aaron_clt is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 12:17 AM #73
08StangGT_CS 08StangGT_CS is offline
08StangGT_CS is on a distinguished road
Great thread. I’ve been spending hours on YouTube watching installation videos and some of them
Look horrible. Glad people are starting to notice this.
08StangGT_CS is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 12:12 PM #74
Jon4RSD Jon4RSD is offline
Jon4RSD is on a distinguished road
Just installed the Sherpa Crestone on my 21 TRD PRO, simple install and fully seals the factory mounting points.. 👍
Jon4RSD is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 12:20 AM #75
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Originally Posted by david05111 View Post
While I'm in this thread, why is it that the factory racks don't seem to have these issues? I hear this sort of thing all the time with aftermarket racks, but that the OEM racks from the factory are GTG.
Why is that? Do they do an amazing job of sealing them or something? IIRC, the TRDP racks are port-installed, so they can't even be factory...
If you look at the RA mounts they have this spongey looking rubber foam seal; that's basically what Toyota uses on most if not all their roof racks. Basically rubber foam washers that compress a lot and fill the nooks and crannies; they work pretty well. Though we have seen some issues with the new Rav4s leaking from the front "clips" because Toyota went to a, IMHO stupid way to mount the roof rack to the vehicle compared to how they did it on every other Toyota.
Originally Posted by Phade View Post
I have the Victory rack waiting or go on. With all of the people running racks how come there aren’t more posts of this kind of corrosion taking place?
I’ve seen the one or two mentioned but not outside of that.
Really want to avoid leaking and rust living in the salt belt.
Honestly? Same reason a lot of customers get shocked when I show them how extensive rodent infestation gets in their cars sometimes. Any/all the water will for the most part follow the curves of the body and headliner, being shuttered to the A, B, C, and D pillars where they'll likely just drain down out of sight and out of mind.
I have seen entire junction blocks ruined by poor windshield sealing after a replacement (usually the upper corners & top edge), it just flows along the A-Pillar, down the open corner in the dash and drips on-top of the junction blocks. Most people won't notice unless the leak is bad enough to make the carpet squishy/soggy or when they start noticing a moldy/musty smell (even then some people don't even notice it).
Basically it's one of those things that unless it's dripping on you or in your field of vision or causes an electrical or functional issue, most customers/owners won't notice or complain about it.
BlackWorksInc is offline   Reply With QuoteReply With Quote
drill , rack , roof , silicone
Baja or Prinsu No drill roof rack Mvrocky 5th gen T4Rs 13 12-09-2018 02:08 AM
review of no drill full length roof rack options aj1978 5th gen T4Rs 13 07-16-2018 03:39 PM
Drill bit recommendation to drill out and tap 8mm skid plate bolts to 10mm 07V8 4th Gen T4Rs 10 01-12-2017 11:20 PM
Can I drill into this part of the roof rack? EricHartley 3rd gen T4Rs 10 06-03-2014 12:28 AM
