Old 06-09-2020, 05:06 PM #16
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Originally Posted by Chilow View Post
Is there an alternative to using heat? In case I can't get access to a torch? I do have a cheap Harbor Freight heat gun.
One of these guys probably works as well as anything. $15. https://www.homedepot.com/p/Butane-T...E&gclsrc=aw.ds
Not sure of anything else that would be better and cheaper for this task. The focused small flame of a mini torch is a lot better IMO than a larger mapp or propane torch. But they all would work for this scenario. Heat gun might work - but it's pretty hard to focus the heat very well.
The other way is to use a welder to weld on top of the stud and heat it up. But... that's going to ruin the stud so you might as well just break it off with an impact in that case.
Old 06-09-2020, 10:58 PM #17
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Any heat will help, but a torch will apply enough to make it easy.......I don't use red loc-tite on ANYTHING. A proper torque is more important to retention than the wrong torque and red loctite. Blue is all I use when I need any.
83Mule is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 11:26 AM #18
Chilow Chilow is offline
Chilow will become famous soon enough
Thank you everyone for the advice so far. Going to tackle this today in the afternoon. Praying that I don't snap any of the factory studs
Chilow is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 12:11 PM #19
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
You'll be fine. I just went through this. As long as you have a breaker bar, you'll be fine.
If the spacer doesn't come off the hub, it's probably because you have red loctite mating the spacer to the hub. In that case, don't smash the spacer with a hammer (not even a rubber hammer) as you could bend your lugs. Instead, with the nuts taken off the spacer (the ones holding the spacer to the hub), toss the rim back on and lightly bolt the rim up to the spacer (3 bolts will do). Then rotate the rim really fast in either direction.
That will break the loctite holding the spacer to the hub.
I also had to go through that as well just recently.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 12:15 PM #20
Good tip! When you say rotate the rim really fast in either direction, I assume spinning it either forward or backwards? And not yanking on it (as if I was pulling the rim off)
Old 06-10-2020, 12:22 PM #21
Yep. Spin/turn the rim with a bit of gusto clockwise <==> counter clockwise until it breaks loose.
Don't yank on it. I mean, you could yank on it but that could take a lot more effort than necessary and have unpredictable results. You could mar a rim, bang a fender, shoot yourself back in an uncontrolled fashion and then drop your rim on its face, etc.
Old 06-10-2020, 08:51 PM #22
I am pleased to say that they came off easier than I thought they would. Only required moderate effort with a breaker bar. A little tedious using a flathead to scrape off all the residue left on the threads, but glad I didn’t run into any issues. Thank you all again!
loctite , remove , spacers , studs , wheel
wheel spacers (re-torque or loctite)? wum 4th Gen T4Rs 5 11-11-2020 06:56 AM
***SOLD*** Spidertrax 1.25" Wheel Spacers | Brand New | Black | Set of 4 spacers papadop88 For Sale: Suspension/Wheels/Tires 16 01-09-2020 12:17 PM
To Loctite or Not to Loctite (Ball joint bolts to spindle)? M22 5th gen T4Rs 11 05-22-2019 12:59 PM
Loctite on wheel hub bearing assy? thatsbug 4th Gen T4Rs 2 08-01-2018 09:32 AM
