Old 06-08-2020, 10:10 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Removing Wheel Spacers Loctite
Purchased new wheels and will need to remove my current Spidertrax wheel spacers. I installed them about two years ago and used the included red loctite. How hard will it be to remove? I’m worried that I might damage the factory wheel studs. Any tips or tricks?
Has anyone here removed them successfully without damaging any of the studs?
Chilow is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 10:15 PM #2
Jtw13 Jtw13 is offline
Jtw13 is on a distinguished road
Heat, get a map torch and warm it up. Impact after that.
Jtw13 is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 10:26 PM #3
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
+1 on the heat...or a long cheater bar.
Either way, depending on how much used, be ready to wire brush/wheel the residue off the lug studs.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 07:47 AM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
"It can be difficult removing LOCTITE® red threadlocker, and it's a common vehicle maintenance question. While the strength of the red threadlocker is formidable, and meant to be a permanent assembly method, don't believe the myths: red threadlocker can be disassembled with the right technique."
"When disassembling red threadlocker, the process is a little different than for other threadlockers. The key is to apply localized heat greater than 550° F. Then, once the threaded assembly is hot, the bolt can be unthreaded. Without applying heat to the assembly, it’s likely that over time, a bolt would break before coming loose."
How to Remove Red Threadlocker - Henkel Adhesives
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 09:05 AM #5
Thanks all for the replies. I’m just worried that if I use a breaker bar, I might end up snapping the original studs.
Old 06-09-2020, 10:49 AM #6
DaddySteve DaddySteve is offline
DaddySteve is on a distinguished road
do like the others have said use a torch and heat the stud. The bolts will break loose with ease.
DaddySteve is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 10:54 AM #7
DEF4Runner's Avatar
DEF4Runner's Avatar
In a pinch, I used a breaker bar when I needed the nut off, but didn't have access to a torch. It worked without snapping anything, but it DID leave a adhesive-like residue behind on both the stud and inside the nut. If I remember correctly, even using heat to loosen the grip will also leave some residue behind once it cools off. That said, be sure to clean the threads on both ends (or just the studs if you get new nuts with the wheels) to make sure you don't get a false torque once the nut tries to run through the residual loctite.
Old 06-09-2020, 11:08 AM #8
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Hopefully they come off easy. I don't understand the logic behind loctite on spacers. Do your wheels commonly fall off? If not, why would properly tightened spacers come loose?
Old 06-09-2020, 12:35 PM #9
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
I was always told it has something to do with them being made of aluminum and the heat cooling cycles , expansion contraction and what not.
Arnezie is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 12:40 PM #10
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Most wheels are aluminum. If that were the case it would be the same situation. My guess is that spacer manufacturers want to cover their ass and direct to use loctite to lower liability of sub par install.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 01:53 PM #11
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
I need to do a brake job shorty and have red locktite holding my wheel spacers on. Good info on the heat, I'd have hit it with the impact without heat for sure.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 01:55 PM #12
kenwilliams0803 kenwilliams0803 is online now
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Heat is a great idea. I have never had to use it for red loctite though. It's not as strong as it's made out to be.
kenwilliams0803 is online now   Reply With QuoteReply With Quote
Old 06-09-2020, 02:11 PM #13
spartacus's Avatar
spartacus's Avatar
Also buy a few oem wheel studs just incase and have them on hand for replacement if necessary.
Old 06-09-2020, 02:47 PM #14
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
I think red Loctite is only meant to be permanent with less than 5/8" diameter bolt, or something close to that size?
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
JPOVS is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 04:29 PM #15
Is there an alternative to using heat? In case I can't get access to a torch? I do have a cheap Harbor Freight heat gun.
loctite , remove , spacers , studs , wheel
wheel spacers (re-torque or loctite)? wum 4th Gen T4Rs 5 11-11-2020 06:56 AM
***SOLD*** Spidertrax 1.25" Wheel Spacers | Brand New | Black | Set of 4 spacers papadop88 For Sale: Suspension/Wheels/Tires 16 01-09-2020 12:17 PM
To Loctite or Not to Loctite (Ball joint bolts to spindle)? M22 5th gen T4Rs 11 05-22-2019 12:59 PM
Loctite on wheel hub bearing assy? thatsbug 4th Gen T4Rs 2 08-01-2018 09:32 AM
