Originally Posted by kaitlyn2004
You are completely right! I don't know why I overlooked this.
I assume if I plug it in (whether cigarette or AC adapter), there's no way that (while actively driving) that I would be draining the car battery more than charging it, right?
It's possible to outrun the alternator, but it's really unlikely in these vehicles. The alternator is IIRC 140 amps. (So about 1600 watts - if you consider that compared to 100w solar panel, you can see that the alternator has a lot more energy output). A fridge as an example typically draws a peak of 7 amps, but normally they draw around 1.5 amps. So the draw is pretty small.
If you add a bunch of electronics and auxiliary lighting and ?? maybe you can exceed the alternator capacity. A 100 watt solar panel probably won't do a whole lot if you're drawing more than 1600 watts already.
