05-30-2021, 12:46 AM
Question - Recommendations for alternatives to BFG KO2?
Hi All
Good evening...!
So my wife's daily driver, a 2018 ORP, has reached 50K+ miles now and I would need to replace the tires. I had it installed with BFG T/A K02 from the dealer when we bought it new... Thus am looking for comparable alternatives.
We do a light to medium off-roading and/or overlanding a couple of times per year, thus, maybe something for economical than a KO2...? Though price is not an extreme driver for the question; more of, what are the others out there?
Thanks in advanced!
_
05-30-2021, 12:53 AM
I got some Toyo Open Country AT3's in the stock size... they seem nice.
Same amount of road noise as OEM but a different sound not louder really.
The Toyos are maybe $20-30 cheaper each than the BFGs if I remember correctly.
2021 4Runner TRD OFF ROAD V6 with KDSS Classic Silver Metallic
1999 4Runner 2WD 4cyl Natural White TOTALED at 190K
05-30-2021, 01:07 AM
Thank you. I will be checking them out.
_
05-30-2021, 02:04 AM
BTW - are you going with a standard load rating?
I would believe that an E rating is just overkill for the 4Runner although what is currently is "E" from the dealer.
TIA.
05-30-2021, 02:12 AM
+1 on the Toyo OC AT3, it's a great tire. E loads are hardly overkill for a 4Runner. I suspect 98%+ of people who suggest they are have probably never even ran an E load.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
05-30-2021, 04:02 AM
Coming up on 50k miles and probably have another 10k left with current stock tires. I do little to no off roading and would like the aggressive look yet good daily driver.
Options after searching, all seem to be a good choice just personal preference. As for the E load its hit miss on rough ride it seems.
Falken Tires Wildpeak AT3W
BFG KO2
Nitto Terra Grappler
General Grabber ATx
05-30-2021, 04:34 AM
Once my KO2’s are worn down enough, I’ll be doing Falken Wildpeak or going back to Nitto Terra Grappler. I love the design of the Goodyear Wrangler Duratrac, but tried those on my last truck and two were out of round so they warrantied them only for the two replacements to be out of round.
05-30-2021, 07:25 AM
I’ve ran most popular AT tire over the years between the 4Runner and my truck. I have the Ko2 on the 4Runner and had never had an issue with them. On my truck I’m on my second set of Cooper at3lt. They’re not as aggressive looking but they’re way quieter, better in the rain and last longer. They come in a C and E just like the ko2.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
05-30-2021, 10:07 AM
TIA.
E load rating is good if you do some serious off roading over rocks --not round smooth rocks, but rocks with corners and edges. The extra plys of an E rated tire stands up to those better than a lower rating.
I've owned several sets of KO2 over the years and like them. I currently have KO2 E rated on my 4Runner and find they are just as smooth riding and as quiet as the OEM tires.
05-30-2021, 10:36 AM
I did 2 years of back and forth with tons of research but still felt uncertain when it came time. lol
I finally decided on Duratracs in a C load since i live on the east coast with some decent snow and rain. I also do some moderate off roading but didn't want to lose too much of my on road mannerisms, I also didn't want the additional ~10lbs of an E load burdening my 4R.
So far a great tire and really good wet traction.
05-30-2021, 10:57 AM
I've gone through this 3 times. Stocks after 60k or so to LTX M/S2 for 60k or so and hated them. Put on KO2's C rated and went 91,000 miles! Just put another set on 2000 miles ago. I thought about switching to the Firestone Destinations or one of the other tires you are considering, maybe even a mud terrain, but after getting 91k on the KO2's how could I switch? I do a good bit of mixed driving around 100 miles per day and off-road a good bit during summer to get to those fishing holes. Remember a c rated tire may require an increase in PSI over the stock P rated tires. This affects the life of the tire a good bit. I run 44psi on my C's. Rotating every 5k is a huge deal on the more aggressive tread tires. Good luck!
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
05-30-2021, 11:08 AM
Hi All
Good evening...!
Thanks in advanced!
_
Since you only do light to medium offroad, what about the Yokohama Geolandar G015?
https://www.tirerack.com/tires/tires...dar+A%2FT+G015
Great reviews, did very well in testing, better wet traction than KO2s, and also comes in E rated if you decide to go that way.
Between outfits.
05-30-2021, 11:11 AM
Nitto RIDGE Grappler are a great looking tire and ride really smooth and quiet and are plenty capable off-road.
05-30-2021, 11:46 AM
I really like duratrac 265/70r/17 im running, but I wish they made them in 275/70r/17
05-30-2021, 12:05 PM
I went with Pirelli Scorpions. KO2s were my first choice, but I went cheap this round as it was for city driving. Sidewall/thickness and load ratings were something i wasn’t concerned with this time, but next time will be since Ill be spending more time off pavement.
2017 SR5 4WD Premium
2003 SR5 4WD V8 (2010-2017)
