Old 06-10-2020, 01:02 PM #1
pableaux's Avatar
pableaux pableaux is offline
pableaux will become famous soon enough
pableaux's Avatar
Powered sub installation
I'm about to install a small low-powered sub in my truck and had a couple questions. Already searched and couldn't find exactly what I'm looking for. Creating this thread in case anyone comes across something like this in the future.
The sub I have is a Pioneer TS-WX400DA. I got it because it fits perfectly under the seat and still leaves space for your feet and the OEM all-weather floor mat.
I ended up getting an LC2i line out converter so I could control the bass roll off.
Now, my question is, where should I draw power for the sub? The manual says, "Connect the lead to a power supply terminal from the fuse box which can provide a constant current level of more than 10A." I don't really see anything in the fuse box that I can tap into that's more than 10A. I found something that's 10Am (KDSS - I don't have KDSS installed) but nothing more. The power cable has a inline fuse of 10A so I figured maybe I can tap directly to the radio?
I bought a harness on Amazon (originally bought the "add a sub" from Tacotunes but their customer service is horrible and non-existent so figured I'd try something else) and this harness has a 12v lead. Can I just tap into that for the sub or am I asking for trouble? Also, is it possible to use that 12v lead from the harness to power both the sub (10A) and the LC2i (1A)?
pableaux is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 04:40 PM #2
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
If all else fails😁😎😳😉🤡
Powered sub installation-a7cbb17b-f618-447b-9a62-3febb2ad74e4-jpeg
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 10:00 PM #3
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
I had this Fosgate 10” powered sub installed recently in mine but I bought a wiring kit with it so have a 10g wire coming off the battery to it (fused up front). Maybe overkill but I thought that’s the recommended power source for the Amp, direct from the battery. Wiring kit also handled this 2 Channel Line out converter it needed (off factory deck) heavy duty ground wire, etc. Anyway, I think off the battery is the right way to go.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 11:36 PM #4
4Rums 4Rums is offline
4Rums will become famous soon enough
That subwoofer specs says it has a max of 250 watts. So 250 watts divided by 12 volts, will give you a max current of 20.8 amperes. You will likely have to run a power cable from the battery to power that subwoofer unless you can find an empty 20 Amp fuse. If you tap into a 10 amp fuse, you will be constantly blowing that fuse once you turn up the volume.
4Rums is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 11:44 PM #5
pableaux's Avatar
pableaux's Avatar
Should you be dividing by peak watts or RMS? 20A doesn't make sense to me if there's a 10A fuse installed to the sub's power line arleady. Manual says max power consumption is 9.4A
Old 06-11-2020, 01:31 AM #6
david05111 david05111 is offline
david05111 will become famous soon enough
Why didn't you just go with the factory JBL or some sort of stealth box? I bet that little sub isn't going to do much of anything at all.
On your question, I'd power it right off the battery and run a line. That's what the stereo shop did with mine, except I'm running a JL XD600-1 amp connected to a JL 12W6 in a sealed box. Mine obviously needs more power, but I wouldn't want to mess around with trying to make anything work with the factory fuse box. I'd run a dedicated line and be done with it.
david05111 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 01:59 AM #7
pableaux's Avatar
pableaux's Avatar
I got it for cheap and doesn't take up any space at all. I've got a 3rd row and need to maintain my trunk space. Not willing to shell out money for a custom box.
I know it's not really all that powerful but it will suit my needs. I just needed a little more low end. Don't need to shake any mirrors or anything.
Old 06-11-2020, 10:32 AM #8
Auntie Soshul's Avatar
Auntie Soshul Auntie Soshul is offline
Auntie Soshul is on a distinguished road
I installed the previous version of this Pioneer sub a couple of years ago. First, do NOT tap into the power cable for the radio or any other device. Instead, install an add-a-Tap in your fuse box in a slot that’s at least 10 amps, and run a dedicated power cable to the sub, like the instructions say. There are likely some unused slots in the box. Second, disconnect the battery before starting the install. This cannot be stressed enough.
I used some ideas from @Antman ’s instructions for installing a powered sub, located in the stickies. He ran a heavier power supply than needed, directly from the battery. There is nothing wrong with that, but it isn’t really necessary since the sub doesn’t pull that much power.
2013 SR5 Mag Gray, Pre-leveled, Non-nosedive edition
Plastic license plate frame
Auntie Soshul is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 12:17 PM #9
kadinh kadinh is offline
kadinh is on a distinguished road
I am also looking to add a subwoofer (maybe) to my build. I'm waiting for all the parts to come in, should all be here by Friday next week. I'm wondering if the Infinity Kappa 6x9 (plus tweeters) 135W and Kappa 6.5" 75W are going to be enough for me. If I would have researched before I bought everything (Kappas were a steal of a deal), I think I would have gone with a 5 channel amp, put 2ohm front 6x9s on channels 1 and 2, then put the 4 ohm R rear and hatch speakers on channel 3 in parallel, L side on channel 4 parallel, then have the ability to add a sub easily.
My mistake was getting a 4 channel amp that is 150W x 4 @ 2 ohms with speakers that are 2.5 ohms. I'll be losing my hatch speakers (which ppl say dont really matter anyways) and I don't have an extra channel for a sub.
To answer your question OP, I was looking into shallow mount subwoofers. A few brands have them and they take up much less space that traditional subs and boxes. If I decide to add a sub(s), that is the way I'm going.
kadinh is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 11:31 AM #10
pableaux's Avatar
pableaux's Avatar
Yeah, I ended up just using an add-a-fuse and putting it in the KDSS slot and has been fine so far. The LC2i is tapped into the stereo but barely uses any power so that's good. Super simple install.
Old 06-12-2020, 11:34 AM #11
pableaux's Avatar
pableaux's Avatar
Only pic I took during installation haha.
10a , fuse , harness , power , tap
5100 installation vs. spacer lift installation bandaman 5th gen T4Rs 28 07-20-2015 11:46 PM
Powered Subwoofer installation questions? Updates??? Vegas 5th gen T4Rs 25 02-12-2013 04:57 PM
Under powered cement head 3rd gen T4Rs 4 01-16-2012 08:54 PM
Any experience with this powered sub? SurfToy Engines / Suspension / Wheels / Tires / Audio / Accessories 13 04-04-2010 02:38 PM
Jet Powered MR2 DavidAlexander Off Topic 1 04-04-2009 01:23 AM
