Old 06-18-2020, 12:56 PM #31
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Originally Posted by MeefZah View Post
Solo, I remove half the backseat bottom and use two Thermarests on top of each other, with a 8 gal Rubbermaid tote in the footwell. All my gear is in the half of the cargo area not taken up with the mattress. I use 2 Thermarests just because I've got two available and they're easy.
If you have a non third row model or a non cargo deck slider model, you need to build a spacer or otherwise pad the cargo area, as it is 2.5" lower than the flat surface created by the seat backs.
If you do it right then you can make a flat surface from rear hatch to back of front seat.
How far forward does the front seat have to be? Can you drive with them in place?
delloro is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 01:39 PM #32
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
All the way; no.
But when it's just me I slide the passenger seat up and leave it like that when driving.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 01:56 PM #33
jlensky5656 jlensky5656 is offline
jlensky5656 is on a distinguished road
I guess it depends on how much you want to spend. If money is not a thing then I agree with a couple others about the Exped Mega Mat as it is super comfortable (at least I seem to think so I know mattresses can be subjective). I find it is the next best thing after your home mattress itself. When I first started car camping I also used my thin backpacking inflatable pad and it worked just fine and for most people it will be just fine but I wanted something a little more comfortable for the back of the vehicle. I was also in the back of a jeep grand cherokee at the time and the rear seats do not fold flat like the 4runner so half the sleeping area was angled a little bit and since the backpacking pad was so slim i felt that angle all night long. So I first used what I had and used an older Coleman twin inflatable mattress that was a lot thicker than my pad. So when I tried it was way better then the thin mattress pad and the thickness absorbed the angle better if that makes sense. If you are on a budget I would go that route since coleman ones can be picked up for cheap and it shouldn't get punctured on anything that is naturally in the back of a 4runner if you have anything extra back there well I guess it depends on what it is. Then once I started sleeping a lot in the back of my vehicle on trips thats when I invested in the Exped and I can never go back now haha. I haven't personally done this but I have a friend who used a thick piece of memory foam (you can order them custom sizes online) and his is not the basic 3" topper his is like 5-6" thick way thicker than a topper and he loves it as he has a memory foam mattress back at home so it gives him a similar nights sleep. Again this is going to be a pricier option and on the same level as the Exped so I would just go the Exped route.
jlensky5656 is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 12:38 AM #34
delloro's Avatar
delloro's Avatar
All the way; no.
Got it, thanks!
Old 06-19-2020, 12:41 AM #35
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
All the way; no.
I'm tempted to sort of make a support base (almost like a side table) to fit in the gap. Means a container would fit even more awkwardly, but you could fit a smaller container and/or stuff other random things there. And maybe it could adjust to wherever the front seats may be...
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 04:50 PM #36
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
Originally Posted by mteolus View Post
Damn, cheap at Wal-Mart but they don't have them here. $30 at REI. Everyone else is about $30.
After doing some research (still need to actually test fitment), based on the measurements of the Rubbermaid 8gal action packer, you can achieve the same fitment with the Frontrunner Wolfpack box with the Hi-Lid.
Frontrunner Wolfpack with hi-lid will cost ~$10 more but I would rather use those as they are more modular if i ever want to install on my roof rack.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 10:49 AM #37
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Amazon.com : Sea to Summit Comfort Deluxe Si Mat - Regular Wide - Self-Inflating Camping & Backpacking Sleeping Mat, Blue : Sports & Outdoors
Cheaper & thicker than the MegaMat, and completely self-inflating. Like having a true mattress in the back.
The size is perfect - fridge, battery, other crap on one side of the truck, this fits perfectly on the other side.
rageandlove is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 01:35 PM #38
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
I'm not suggesting that this is the best for anyone here but worth a look.
The 'Super Paco' seems to be highly regarded in overlanding groups. To me it looks very hot (I'm also in AZ). I have all ultra light gear myself that includes a double inflatable pad that I think is 4" - it has one of those half sleeping bags that attaches over the top. I don't know that UL gear is worth it either but it's probably shaved off 100lbs or so of stuff to haul around
Super Paco Sleeping Pad | NRS
NorthPark is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 01:46 PM #39
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
That looks really good, but like so many items I’ve seen lately on Amazon:
“Currently unavailable
We don't know when or if this item will be back in stock.“
car , foam , material , mattress , sleeping
Air Mattress WEAK_E90 General Discussions 16 06-30-2021 08:02 PM
Air Mattress for 3rd Gen TorqueOfTheDevil 3rd gen T4Rs 48 09-20-2018 11:50 PM
air mattress options kevinpt 4th Gen T4Rs 1 03-08-2014 01:45 PM
Air Mattress in 4Runner? flynnstone 5th gen T4Rs 9 10-22-2013 05:33 PM
What is the best material to use for a sleeping platform?? martin.1991911 Off-Roading 8 05-01-2013 10:34 AM
