Old 09-02-2020, 11:27 PM #31
jeroweezy's Avatar
jeroweezy jeroweezy is offline
jeroweezy will become famous soon enough
jeroweezy's Avatar
Originally Posted by cmoekim View Post
You can reuse your OEM metal brackets/hardware with the Metra kit. First, you'll have to drill out the alignment nibs so they sit flush with the plastic Metra brackets (you still use these to mount the dash kit to the head unit), but that should leave you with enough holes lined up with the threaded DIN mounting points on the Pioneer to screw/bolt the whole assembly together.
Trying to picture how to do tbis...couldnt i just take the plastic metra bracket off and reuse the metal bracket with less screws? Im sure it would be secure. Just finished my install..needs to be tweaked a bit. I think i can go one notch lower on the display. Think OP is a tad lower on his screen than mine.
Also need to get new yellow clips..mine wore out during install... Lots of trial and error
Sent from my ONEPLUS A6013 using Tapatalk
jeroweezy is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 12:47 AM #32
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
Following this thread closely...
want to do this!
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 11:20 AM #33
jeroweezy's Avatar
jeroweezy's Avatar
Originally Posted by Dude View Post
Looks great...can you comment on how much of the vents are covered in that position? Curious if a 10” would work and it appears to fit right in the space between the vent and lower controls.
I can drop it maybe quarter of an inch lower. If you look at OP post and compare mine i think his is at the lowest. The way i have it i can still feel a good amount of air blowing. I also see the "nubs" on the underside of the OEM bracket. I will attempt to reuse it for more stuffness
Old 09-03-2020, 01:51 PM #34
jeroweezy's Avatar
jeroweezy's Avatar
Looks like the 9" is max display and the original poster pic shows it even with the bottom of the vents. Looks much better than the Alpine unit.
Can you take a few pics of the OEM bracket modifications when you do them? Not really clear on this...do yo find your current install is stable?
Yea i can take photos. Its stable but if i were to forcfully pull it out i can get it off from the metra kit. only thing holding it is plastic clips
Old 09-03-2020, 02:03 PM #35
cmoekim cmoekim is offline
cmoekim is on a distinguished road
Here's a pic of the OEM brackets used in conjunction with the plastic Metra ones. You may need to drill out or grind down some alignment nibs so they sit flush. I decided to use both together because I wanted to keep the ability to reinstall/remove as a single assembly like OEM. I have a standard double DIN and don't have any direct experience with the newer floating style head units, but it looks to me like the best course of action may be to install the chassis first reusing the OEM brackets and skipping the metra ones all together, install the trim piece over the chassis, then mount the floating display last.
Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_2150-2-jpg
cmoekim is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 03:21 PM #36
jeroweezy's Avatar
jeroweezy's Avatar
Awesomene ill be doing this as well
Old 09-03-2020, 10:01 PM #37
snacksattacks snacksattacks is offline
snacksattacks is on a distinguished road
Originally Posted by Deimos View Post
This is Pioneer's competitor to the Halo 9.
Pioneer Link
Unboxing video
If you're interested in vids or something specific (like Gaia), just message me on IG @bookstorerunner and I'll see what I can do. Don't message me here as I won't see it.
This won't be an install thread as there are many like it and it's very straight forward if you've done this before. Maestro's supplied harness and wiring diagram makes it pretty easy. Although I will note: when you are installing it, there are two plugs that are keyed and only go one way that plug into the OEM+ speaker and sub harness instead of the stock harness (they will hang loosely and are unused).
Last week I got my hands on the just released Pioneer 9" DMH-WT7600NEX as well as a Maestro RR to retain steering wheel controls.
I installed this on 2019 TRD ORP, with OEM Audio+ Reference 500 and fully soundproofed doors and floorboard with Noico 80mil.
I bought it off Crutchfield due to the generous return policy (60 day). It arrived on a Monday and I had it installed by the following Wednesday.
Since there was no pre-assembled "kit", I pieced together everything separately.
Total cost for the above items came out to USD $1337.66. Labor was free as I did it myself.
I used this Halo9 install video for the interior: link
I bought additional items like an antenna usb adapter but ultimately did not use them. I never listen to FM or Sirius radio and the usb adapter didn't plug into my usb port on the bottom.
If you are an OEM+ user like me, depending on when you bought it, you may have to flash the amp/signal processor under the seat - I've yet to do this as they are sending me a dongle that I am yet to receive. While I've adjusted the EQ and speaker settings to my taste, I still want to have this done.
Pictures of it installed:
OBD Readout
Pros
  • 720P, looks very sharp compared to the stock unit.
  • style and thin bezel, compare this to images to of the Halo9 and it blows it away in my opinion
  • Size ;). 9" fills the gap very nicely, however there is certainly room for the 10" model
  • Carplay is nice and works as it should (I have Gaia installed but have yet to actually use it on a trip)
  • EQ adjustability, stock left a lot to be desired and this fills the gap
  • Came with a screen protector already installed
  • Multiple adjustment points to get the angle you want
  • Wireless Carplay is nice, but I still prefer to plug in my phone
  • Gauges are interchangeable and display loads of diagnostic information (can't find trans temp however)
  • It's fast and responsive, startup time is comparable to stock, buttons do what I tell it
  • Not flimsy and doesn't feel cheap, feels like quality
Cons
  • Stock low-res rear view camera is immediately made apparent, this is not a knock on the receiver, but because it's so sharp (relatively speaking), the rear view camera looks pretty bad. I'll look into upgrading this when I replace my rear bumper
  • The larger screen means you can't be heavy handed when inserting your key, I jumped in the car quickly and my key hit the screen (lightly, no scratch left), but something to be aware of.
  • The USB adapter to retain the stock USB port does not appear to work on my model 4runner and appears to work for early model 5th gen's, someone can please correct me if I'm wrong and direct me to the correct part # and I will correct this. For now I just ran the USB and 3.5m jack in the original USB port's place (I took it out and it's two wires hanging out there)
  • At night, you can turn off the screen and still play music, however the touch sensitive buttons on the left side are still illuminated, it's a pleasing glow, but I would like the ability to turn all the illumination off
  • Pioneer CarAVAssist iOS app does not appear to work properly and does not want to sync with my receiver, this is minor and I don't use the factory interface as I use Carplay, but still, I'd like this option to be there. This will be used in the future to update the firmware of my receiver, so I'd like to get this to work sooner rather than later. I'll look into this further as I suspect it's user error. However after working in the UI/UX software design field over 8 years, this should be easier.
  • Not a knock on the receiver, but I am skeptical of the Metra kit's attachment point, especially when off road and things bouncing around. Next time I'm back there I'll try to remember to get a shot of it
I've only had it a week and probably have clocked a grand total of 4-5 hours of drive time with (if that), so I'll be sure to update this thread with additional photos and long term impressions, especially with extended trips as things heat up in summer and as I venture off-road with it.
Anyways, hope this was helpful for anyone looking into this.
Looks bomber
snacksattacks is offline   Reply With QuoteReply With Quote
Old 09-04-2020, 11:51 AM #38
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
had a pioneer before that i liked, eventually installed a alpine x208u. now eying the 10"
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 03:15 PM #39
jcrown7's Avatar
jcrown7 jcrown7 is offline
Real Name: Jared
jcrown7 will become famous soon enough
jcrown7's Avatar
Real Name: Jared
Did the factory 4R XM antenna/tuner work with this HU or will it require the standalone add-on?
The price-point on this one is definitely more enticing than the Halo.
*'16 Trail - JBA UCAs, Toytec BL, Dobinsons FR, Radflo LT Rear, (~3.5F/4R total lift) 285/70 (/75s next), mix of HeftyFab/SSO steel goodies
jcrown7 is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 07:44 PM #40
pickett pickett is offline
pickett is on a distinguished road
For those using Crutchfield....did anyone use their harness service and did it include wiring all the Maestro?
Also....how did you wire the parking brake?...or does this unit still have the bypass feature in the software (touch screen to turn off)?
Just purchased via Crutchfield and opted not to have them do the wiring. Why make this easy! Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+
Will try to post pics of the install after the weekend.
pickett is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 10:39 PM #41
jeroweezy's Avatar
jeroweezy's Avatar
i did not use crutchfields wiring....this unit does have the bypass in software
Old 09-26-2020, 07:04 PM #42
Installed last weekend and have been driving with it for a week. Very happy so far. Have noticed a tiny bit of sluggishness in the default UI but I use CarPlay all the time and outside of a minor issue that happened once (very easy to fix by unplugging the phone and plugging back in) it is awesome.
Amazing display, love having CarPlay in the truck. Solid look and solid construction. Will check back in in a few weeks and post some pics.
Old 10-01-2020, 07:26 PM #43
Deimos Deimos is offline
Deimos will become famous soon enough
Originally Posted by BrandonJ View Post
Does the screen dim well for night time driving? I know that was some of the complaints with the Alpine.
It does dim, but not well enough. This is something I would like to see improved as I want things to get dark. I can turn off the display but eh, this is lacking.
Deimos is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 12:53 AM #44
Sagi28 Sagi28 is offline
Sagi28 is on a distinguished road
Pioneer Link
Unboxing video
If you're interested in vids or something specific (like Gaia), just message me on IG @thegraverunner and I'll see what I can do. Don't message me here as I won't see it.
OBD Readout
Pros
Cons
Do you have any side angle pictures? Wondering how much it sticks out and if it is flush where you can’t see the pocket etc.
Thanks
Sagi28 is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 02:16 PM #45
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
Thanks
Just finished installing this on my wife's 4Runner so I figured I would grab you a couple side shots etc. Not to hijack this thread as its not an install thread but wanted to give some comments as I went into this "blind" - took me about 4 hours over 2 days. Note a couple of the side shots do not show the black back cover installed - you can not see the silver mounting rails and screws with the cover on (photo #3)
*I think the OPs photos make this head unit look a little more "tucked" to the dash then it actually is, I don't think it looks bad installed and prefer this to the T8/T9 or Alpine options from a visual standpoint but it is still and always will be "tablet on the dash"
*There are a lot of parts to move over from the OEM headunit to the Metra dash kit - the vents, vent adjusters and emergency flashers - this likely comes to no surprise to anyone who did an ounce of research but like I said above - I thought it looked good, was tired of the OEM radio locking up and it was something the wife wanted for Christmas so I went to Crutchfield , ordered the kit and winged the install (the directions are terrible imho)
*This does block just a bit of the vents even in the lowest setting, I think the 10" would look far to big but to each there own
*There is a RATS NEST of wires now, I assume this is standard with aftermarket Headunits but as this was my first install I was shocked how many wires, dongles, adapters it takes to do this - its not what I would call "clean" but I think it is what it is in this world.
*You have to flash the Idatalink Meastro RR - was easy but did not realize I would have to do that going into this
*The metra dash kit black matches very well with factory paint, no would would notice imho
*I did not reuse the OEM mounts even though I did grind off the alignment "knobs" - the Metra/Pioneer mounts seem solid enough but I kept the OEM incase I change my mind
*I tucked the GPS receiver behind the unit, not sure if you are supposed to do this but the signal strength said "ok" after install and it appears to work - does not matter much to me as we will be using Apple Car Play 99% of the time
*Overall the install was not to bad but its very intimidating the amount of wires/adpters/connections - I did not find the IdataLink or Crutchfield instructions all that clear as far was what gets used and what does not so is was a bit trial and error
*Wired and Wireless Carplay seems to work fine - I will be installing a wireless charger under the lower cubby in the dash so we can just place phones there and charge/Wireless Carplay
*As the OP mentioned the OEM backup camera appears pretty grainy on the screen (cameras fault not the Unit) - I think it looks worse in person then the photo I attached shows.
*I have not had a chance to play with settings so it might be changeable but only have 4 icons across on the screen makes them "large and in your face" imho
Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6127-jpg  Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6104-jpg  Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6115-jpg  Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6129-jpg  Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6141-jpg  Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6143-jpg  Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+-img_6144-jpg
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
display , dmh-wt7600nex , floating , installed , pioneer
New Pioneer floating head unit - anyone tried this? MillerPKA 5th gen T4Rs 47 04-12-2022 02:43 PM
XPEL Clear Bra Installed - Impressions WTERUNNER 5th gen T4Rs 19 09-17-2018 12:41 PM
FS: WA - JL Audio 500/1 and Pioneer 8" sub in box toomuch50 For Sale: Non-T4R Items 1 06-07-2014 12:44 AM
audio display on????? baldilox 5th gen T4Rs 6 09-26-2013 09:59 PM
Ultra-Gauge installed: First impressions... Martinjmpr 3rd gen T4Rs 11 12-27-2010 07:30 PM
