Old 02-14-2021, 08:18 PM #61
jppower's Avatar
jppower jppower is offline
jppower is on a distinguished road
jppower's Avatar
Originally Posted by cmoekim View Post
Here's a pic of the OEM brackets used in conjunction with the plastic Metra ones. You may need to drill out or grind down some alignment nibs so they sit flush. I decided to use both together because I wanted to keep the ability to reinstall/remove as a single assembly like OEM. I have a standard double DIN and don't have any direct experience with the newer floating style head units, but it looks to me like the best course of action may be to install the chassis first reusing the OEM brackets and skipping the metra ones all together, install the trim piece over the chassis, then mount the floating display last.
Any reason not to just skip the metra brackets?
jppower is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 05:35 PM #62
Deimos Deimos is offline
Deimos will become famous soon enough
Haven't logged on in awhile. I recently installed the ICS bracket, so while the bezel was off, I trashed the metra bracket and used the OEM bracket after a little bit of drilling. Works way better now.
Occasionally the unit does not want to connect to my iphone, turns out it was just my cable. So I replaced that.
I updated the firmware on it finally, but had to go the long route (downloading to a USB stick and uploading via the USB port). The Pioneer iOS app to do this is useless. Note, there was a recent firmware update on 2/12/21, I've yet to install that one. This solves some connectivity issues others have been having on Android Auto (I don't use that).
Deimos is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 06:11 PM #63
Whippersnapper02's Avatar
Whippersnapper02 is a name known to all Whippersnapper02 is a name known to all Whippersnapper02 is a name known to all Whippersnapper02 is a name known to all Whippersnapper02 is a name known to all Whippersnapper02 is a name known to all
The only thing really holding me back from purchasing is connectivity issues. My current Pioneer Avic 8000NEX has been a pain in the ass since new in 2014. It wont respond to steering wheel control track skipping or even direct headunit skipping at times. I get resetting and complete loss of any control or connectivity at times. I don't want a repeat of it.
Old 03-05-2021, 07:16 PM #64
umidkusername umidkusername is offline
umidkusername will become famous soon enough
out of curiosity, when you bought the different pieces did they say they weren't compatible with your vehicle?
I don't know about the 2019, but in the 2020 Pro with the JBL stuff, there is no kit. If you go to Crutchfield they recommend you don't mess with anything. I wonder if there's a sharp difference between your edition and the 2020 Pro. I would imagine it can't be that much different.
umidkusername is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 09:04 PM #65
Mr Rutherford's Avatar
Mr Rutherford Mr Rutherford is offline
Real Name: Sir Reginald Featherbottom Rutherford III
Mr Rutherford is on a distinguished road
I have this unit, installed about 2 months ago. Love it so far, only issue started a couple of weeks ago is when turning on the unit it doesn't automatically go to carplay unless I hit the OK button every time. I think it happened after an IOS update which would not be the units fault.
Mr Rutherford is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:18 PM #66
NColmore NColmore is offline
NColmore is on a distinguished road
Tip for getting everything flush can be found here at the 9:30 mark. He made a hybrid of the single and double din. If you go to his second video, it looks phenomenal
2020 Toyota 4 Runner starts with a DMH WT7600NEX Installer Diaries 321 part 1 - YouTube
NColmore is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:25 PM #67
I was able to use the OEM metal brackets but the pocket doesn't fit between them so it's open but you can't see it unless you look from the side.
display , dmh-wt7600nex , floating , installed , pioneer
New Pioneer floating head unit - anyone tried this? MillerPKA 5th gen T4Rs 36 12-01-2020 05:07 PM
XPEL Clear Bra Installed - Impressions WTERUNNER 5th gen T4Rs 19 09-17-2018 12:41 PM
FS: WA - JL Audio 500/1 and Pioneer 8" sub in box toomuch50 For Sale: Non-T4R Items 1 06-07-2014 12:44 AM
audio display on????? baldilox 5th gen T4Rs 6 09-26-2013 09:59 PM
Ultra-Gauge installed: First impressions... Martinjmpr 3rd gen T4Rs 11 12-27-2010 07:30 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
