Old 06-11-2020, 02:12 AM #1
Deimos Deimos is offline
Deimos will become famous soon enough
Pioneer 9" DMH-WT7600NEX Floating Display Installed: First Impressions w/OEM Audio+
This is Pioneer's competitor to the Halo 9.
Pioneer Link
Unboxing video
If you're interested in vids or something specific (like Gaia), just message me on IG @thegraverunner and I'll see what I can do. Don't message me here as I won't see it.
This won't be an install thread as there are many like it and it's very straight forward if you've done this before. Maestro's supplied harness and wiring diagram makes it pretty easy. Although I will note: when you are installing it, there are two plugs that are keyed and only go one way that plug into the OEM+ speaker and sub harness instead of the stock harness (they will hang loosely and are unused).
Last week I got my hands on the just released Pioneer 9" DMH-WT7600NEX as well as a Maestro RR to retain steering wheel controls.
I installed this on 2019 TRD ORP, with OEM Audio+ Reference 500 and fully soundproofed doors and floorboard with Noico 80mil.
I bought it off Crutchfield due to the generous return policy (60 day). It arrived on a Monday and I had it installed by the following Wednesday.
Since there was no pre-assembled "kit", I pieced together everything separately.
Total cost for the above items came out to USD $1337.66. Labor was free as I did it myself.
I used this Halo9 install video for the interior: link
I bought additional items like an antenna usb adapter but ultimately did not use them. I never listen to FM or Sirius radio and the usb adapter didn't plug into my usb port on the bottom.
If you are an OEM+ user like me, depending on when you bought it, you may have to flash the amp/signal processor under the seat - I've yet to do this as they are sending me a dongle that I am yet to receive. While I've adjusted the EQ and speaker settings to my taste, I still want to have this done.
Pictures of it installed:
OBD Readout
Pros
  • 720P, looks very sharp compared to the stock unit.
  • style and thin bezel, compare this to images to of the Halo9 and it blows it away in my opinion
  • Size ;). 9" fills the gap very nicely, however there is certainly room for the 10" model
  • Carplay is nice and works as it should (I have Gaia installed but have yet to actually use it on a trip)
  • EQ adjustability, stock left a lot to be desired and this fills the gap
  • Came with a screen protector already installed
  • Multiple adjustment points to get the angle you want
  • Wireless Carplay is nice, but I still prefer to plug in my phone
  • Gauges are interchangeable and display loads of diagnostic information (can't find trans temp however)
  • It's fast and responsive, startup time is comparable to stock, buttons do what I tell it
  • Not flimsy and doesn't feel cheap, feels like quality
Cons
  • Stock low-res rear view camera is immediately made apparent, this is not a knock on the receiver, but because it's so sharp (relatively speaking), the rear view camera looks pretty bad. I'll look into upgrading this when I replace my rear bumper
  • The larger screen means you can't be heavy handed when inserting your key, I jumped in the car quickly and my key hit the screen (lightly, no scratch left), but something to be aware of.
  • The USB adapter to retain the stock USB port does not appear to work on my model 4runner and appears to work for early model 5th gen's, someone can please correct me if I'm wrong and direct me to the correct part # and I will correct this. For now I just ran the USB and 3.5m jack in the original USB port's place (I took it out and it's two wires hanging out there)
  • At night, you can turn off the screen and still play music, however the touch sensitive buttons on the left side are still illuminated, it's a pleasing glow, but I would like the ability to turn all the illumination off
  • Pioneer CarAVAssist iOS app does not appear to work properly and does not want to sync with my receiver, this is minor and I don't use the factory interface as I use Carplay, but still, I'd like this option to be there. This will be used in the future to update the firmware of my receiver, so I'd like to get this to work sooner rather than later. I'll look into this further as I suspect it's user error. However after working in the UI/UX software design field over 8 years, this should be easier.
  • Not a knock on the receiver, but I am skeptical of the Metra kit's attachment point, especially when off road and things bouncing around. Next time I'm back there I'll try to remember to get a shot of it
I've only had it a week and probably have clocked a grand total of 4-5 hours of drive time with (if that), so I'll be sure to update this thread with additional photos and long term impressions, especially with extended trips as things heat up in summer and as I venture off-road with it.
Anyways, hope this was helpful for anyone looking into this.
Deimos is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 03:01 AM #2
jaemz's Avatar
jaemz jaemz is offline
jaemz will become famous soon enough jaemz will become famous soon enough
jaemz's Avatar
damn, that looks pretty slick. how is the glare in the sun?
ig // @ja.emz
'17 trd off road premium
jaemz is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 05:36 AM #3
shdw03 shdw03 is offline
shdw03 will become famous soon enough shdw03 will become famous soon enough
I like it. Want to try that modular unit with a custom mount
shdw03 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 12:13 PM #4
Not as bad as you would expect, I can't say I've noticed this but most of the time I've driven and used it is in prime sunset with the glare on it in some fashion.
Old 06-11-2020, 02:00 PM #5
Par02 Par02 is offline
Par02 is on a distinguished road
Are you out of gas or is it not reading the fuel gauge?
Par02 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 02:25 PM #6
Whippersnapper02's Avatar
Whippersnapper02 Whippersnapper02 is online now
This looks better than the Alpine option that seems to block the vents no matter how low you have it. I'm still meh about the floating screen look.
I used the PAC USB-TY1 for my USB.
Whippersnapper02 is online now   Reply With QuoteReply With Quote
Old 06-11-2020, 02:39 PM #7
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
So OEM+ and the Pioneer = $4000?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 06-11-2020, 02:45 PM #8
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Looks nice as it doesn’t cover much of the vents or obstruct the knobs.
How many CarPlay icons does it have across ? Compared to the t9, it has 5 across.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 03:20 PM #9
$3,203 as I do not have the seconday sub+amp (although I suspect this will be in the future)
Old 06-11-2020, 03:25 PM #10
At the time I was out and headed to the gas station
Old 06-11-2020, 03:45 PM #11
cmoekim cmoekim is offline
cmoekim is on a distinguished road
You can reuse your OEM metal brackets/hardware with the Metra kit. First, you'll have to drill out the alignment nibs so they sit flush with the plastic Metra brackets (you still use these to mount the dash kit to the head unit), but that should leave you with enough holes lined up with the threaded DIN mounting points on the Pioneer to screw/bolt the whole assembly together.
cmoekim is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 04:27 PM #12
bigradiohead bigradiohead is offline
bigradiohead is on a distinguished road
Where did you put the microphone? I'm looking for ideas on where to place mine when I install.
bigradiohead is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 04:42 PM #13
Great point! That'll give me something to do to clean up the install.
Old 06-11-2020, 04:45 PM #14
The clip they supplied has a large opening, but it inserts nicely overhead on the visor, I opened and closed the visor multiple times to ensure just the right amount of wire was pulled through the A pillar.
Old 06-11-2020, 05:31 PM #15
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Looks nice, I've always been a Pioneer fan. I just recently bought an Alpine Halo 9 for a bit less money, but this definitely looks like a nice radio
display , dmh-wt7600nex , floating , installed , pioneer
New Pioneer floating head unit - anyone tried this? MillerPKA 5th gen T4Rs 47 04-12-2022 02:43 PM
XPEL Clear Bra Installed - Impressions WTERUNNER 5th gen T4Rs 19 09-17-2018 12:41 PM
FS: WA - JL Audio 500/1 and Pioneer 8" sub in box toomuch50 For Sale: Non-T4R Items 1 06-07-2014 12:44 AM
audio display on????? baldilox 5th gen T4Rs 6 09-26-2013 09:59 PM
Ultra-Gauge installed: First impressions... Martinjmpr 3rd gen T4Rs 11 12-27-2010 07:30 PM
